Sprocket and alignment - Triumph Forum: Triumph Rat Motorcycle Forums
 7Likes
post #1 of 13 (permalink) Old 04-04-2019, 07:07 AM Thread Starter
Main Motorcycle: 2012 t 100
Seant100's Avatar
Does this sprocket look worn out?
Seant100 is offline
post #2 of 13 (permalink) Old 04-04-2019, 08:03 AM
Main Motorcycle: '03 Bonneville T100
coachconnor's Avatar
Other Motorcycle: 74 Honda 450 long gone
I'd say so. Also, it looks awful dry of lube.
BonnieJon likes this.
19t, BC Sleepers, 42 pilots, Thrux needles & springs, 135 mains, K&N, Dart screen, air box bafflectomy, Barnett greens, TEC shocks
Wonderous apparitions - provided by magicians. J Fogerty
coachconnor is offline
post #3 of 13 (permalink) Old 04-04-2019, 08:46 AM
Main Motorcycle: 1977 Triumph Bonneville
Other Motorcycle: 1996 Ducati 900ss/cr
Extra Motorcycle: 2007 Ducati S4RS
Scalloped on the edges, teeth starting to bend, next time you replace the chain replace the sprocket.
duc96cr is offline
post #4 of 13 (permalink) Old 04-04-2019, 04:41 PM
Main Motorcycle: 2015 Triumph Thruxton
yrunvs's Avatar
To do it right you'll want to replace both sprockets and the chain altogether. Either go with OEM or these guys have nice package deals.
https://sprocketcenter.com/
TTP Tune#3, NH Toga's.
I'm no Gynecologist but hey I'll take a look.
yrunvs is offline
post #5 of 13 (permalink) Old 04-05-2019, 09:48 AM Thread Starter
Seant100's Avatar
I ordered new sprockets and a new x ring chain going up 1 tooth on the front should get it tuesday
yrunvs and Back2-2 like this.
Seant100 is offline
post #6 of 13 (permalink) Old 04-05-2019, 10:43 AM
Main Motorcycle: Leather office chair
TTRIgnitionSystems's Avatar
Other Motorcycle: Red velour-ish recliner
Curious - why the gearing change? You're going to lose some bottom end grunt and gain some top speed / lower revs at a given road speed.
"Teaching Old Bikes New Tricks"
Shift Sensors - Quick Shift Controllers
North American Distributor for Shifting ContRoll
=> Bolt-on / Plug-in QS kits for Triumph Daytona & Street Triple
=> Bolt-on / Plug-in Reverse (GP) Shift kit for Triumph Daytona & Street Triple
Details in my vendor thread => New Dealer - TTR Ignition Systems
TTRIgnitionSystems is offline
post #7 of 13 (permalink) Old 04-05-2019, 02:28 PM
yrunvs's Avatar
I think you answered your own question.
IMHO 19t up front works great I love it. I never search for that elusive 6th gear.
mick 85 and markwn like this.
yrunvs is offline
post #8 of 13 (permalink) Old 04-05-2019, 04:23 PM
Main Motorcycle: 2015 Scrambler
Boy Racer's Avatar
I tried it and found the bike just lost that something special about it, so I went back to the stock setup.
Maybe it's getting to that '6th gear' feeling to quickly that makes it special...............
Boy Racer is offline
post #9 of 13 (permalink) Old 04-05-2019, 04:26 PM
Main Motorcycle: Bonneville T100 SMQ SE
Tornado99's Avatar
Other Motorcycle: 1974 Norton Commando 850
I can't tell from the photo as it's not square to the teeth. You should see asymmetric curve on the teeth....ultimately you get a shark's tooth appearance. Also, if you grab the chain halfway long the rear side of rear sprocket, try pulling the chain directly rearward away from the sprocket...more than slight movement tells you the rear sprocket teeth and/or chain is worn.
2013 T100 Steve McQueen; +NH Togas; -SAI; -O2; +Breathe; +TTP#3; +Avon RoadRiders; +Iron&Resin Sidebag; +Kisan Auto-Off Indicators & BrakeLight Flasher; +MatchlessClueless LED Brake & Indicators; +LED 3000 Lumens Headlamp; +DeCosse Keyless system
Tornado99 is offline
post #10 of 13 (permalink) Old 04-06-2019, 11:43 AM
Main Motorcycle: 2012 Triumph Bonnie SE
Other Motorcycle: 1964 Lambretta 125 Li
Extra Motorcycle: 1947 Salsbury "85"
How about a less fuzzy picture?
Olliepup is offline
Chain and Sprocket Replacement - Part 1 champ87 Maintenance Tips and Tricks for your Sprint 62 04-02-2015 06:01 PM
primary sprocket alignment problem HanktheCrank Classic, Vintage & Veteran 10 11-27-2014 06:26 PM
Chain/Rear Sprocket Alignment mikejackmin Air Cooled Twins Technical Talk 7 05-26-2011 07:25 AM
primary sprocket alignment damonallen Classic, Vintage & Veteran 6 07-01-2010 12:36 PM
Rear sprocket alignment Blaine Maintenance & Workshop Talk 2 04-21-2003 11:02 PM
