Dropped Metallic Rod Into Oil Filler - Triumph Forum: Triumph Rat Motorcycle Forums
 210Likes
post #1 of 256 (permalink) Old 03-16-2019, 09:37 PM Thread Starter
Zix
Main Motorcycle: 2004 Triumph Bonneville
Zix's Avatar
Unhappy Dropped Metallic Rod Into Oil Filler
Basically the title... I am so klutzy. Essentially, I was checking the oil of my 2004 Bonneville with the rod from this: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 (which I apparently thought was a great idea) and I dropped it after I put it too far into the hole.
What should I do? I'm basically brand new to motorcycling, and was really trying my best to get into maintaining it, but I still lack common sense
I have all the tools I need to maintain it (I think) so I'm open to suggestions...
Thank you for your help...
Zix is offline
post #2 of 256 (permalink) Old 03-16-2019, 09:40 PM
Main Motorcycle: Bonneville
bsgrimes's Avatar
Go back on Amazon and buy the following:
SE 8036TM-NEW 30” Telescoping Magnetic Pick-Up Tool with 15-lb. Pull Capacity https://www.amazon.com/dp/B000RB3XBA..._WuAJCbQV5NC67
Triumph Bonneville, T100, Speedmaster, America, Thruxton & Scrambler '01 to '15 (Haynes Service & Repair Manual) https://www.amazon.com/dp/178521036X..._IvAJCbPBCN455
And then return the retrieved “oil stick”.
Sent from my iPhone using Tapatalk
Jeffrey2004 and InTheSoup like this.
bsgrimes is offline
post #3 of 256 (permalink) Old 03-16-2019, 10:20 PM Thread Starter
Zix
Zix's Avatar
Thank you so much! I actually already have a Haynes manual! I'm trying to do this the right way >.<
LapinAgile likes this.
Zix is offline
post #4 of 256 (permalink) Old 03-16-2019, 11:42 PM
Main Motorcycle: 07 Triumph Tiger 1050
Cloudy's Avatar
Extra Motorcycle: Triumph Bonneville 2013
Why would you even be using a rod? You have no frame of reference for what is a correct level. Just use the sight glass, basically if there is oil in the glass when the bike is upright your're good to go.
07 Tiger 1050,K&N Filter,Snorkel Removed,Storm GP Exhaust,20550 Frankentune Map,NGK Iridium Plugs,Ricks R/R,Ohlins Rear Shock,Ohlins Front Springs,Bar End Mirrors,LED Spots,Leather Seat Cover,Ebay Levers,Ebay Risers,Custom Bars.
Cloudy is online now
post #5 of 256 (permalink) Old 03-17-2019, 12:01 AM Thread Starter
Zix
Zix's Avatar
That's a really good question :s
Basically... my thought was to check the color of the oil. I'm not going to deny I'm an idiot though!
steventhechef likes this.
Zix is offline
post #6 of 256 (permalink) Old 03-17-2019, 12:05 AM
bsgrimes's Avatar
Get that magnet and pray to god it didn’t get wedged in somewhere difficult.
bsgrimes is offline
post #7 of 256 (permalink) Old 03-17-2019, 12:12 AM Thread Starter
Zix
Zix's Avatar
Already done!
Zix is offline
post #8 of 256 (permalink) Old 03-17-2019, 03:10 AM
Main Motorcycle: 2006 Blue Thruxton
steventhechef's Avatar
Other Motorcycle: 06 Thruxton - wife's bike
and don't forget luck...... you need luck too. But you can't buy that from Amazon
steventhechef
Eggs & Bacon. A day's work for a chicken, a lifetime commitment for a pig.
steventhechef is offline
post #9 of 256 (permalink) Old 03-17-2019, 04:30 AM
Main Motorcycle: My old 1967 '500
Twintorsk's Avatar
In the future, after retrieving said steel rod, you can limit your oil inspections to the regular oil changes! If unsure, change oil and filter
Twintorsk is offline
post #10 of 256 (permalink) Old 03-17-2019, 05:18 AM Thread Starter
Zix
Zix's Avatar
If only I could lol
Right!
Zix is offline
Complete Instructions for Rebuilding Forks and Changing Fork Oil BombFactory Triumph SuperSports 19 04-04-2018 01:29 AM
Another t140 oil level problem Davewheels Classic, Vintage & Veteran 9 02-17-2018 05:19 AM
Another Thruxton Racing Question - Jonah, dman? greytop Club Cafe' 23 09-12-2008 08:19 AM
help - six inch plastic tube dropped in oil filler Syberian Tiger Chat 8 05-13-2006 12:27 PM
Oil Change Interval? WildRice Triumph SuperSports 4 07-15-2004 10:43 AM
