Dropped Metallic Rod Into Oil Filler - Page 5 - Triumph Forum: Triumph Rat Motorcycle Forums
 210Likes
post #41 of 256 (permalink) Old 03-17-2019, 05:50 PM
Main Motorcycle: 2015 Triumph Thruxton
yrunvs's Avatar
Originally Posted by Zix View Post
Okay! I've ordered the endoscope and grabber. I'm going to drain the oil before I use them - just to make sure I get the best view possible.
If it was me I would do nothing until I received the scope and took a look. I wouldn't move it or dump the oil or do anything. Like I said the rod could be right there for the taking.
TTP Tune#3, NH Toga's.
I'm no Gynecologist but hey I'll take a look.
yrunvs is online now
post #42 of 256 (permalink) Old 03-17-2019, 09:34 PM Thread Starter
Zix
Main Motorcycle: 2004 Triumph Bonneville
Zix's Avatar
Okay! I'll do that, then! Thank you for your advice, seriously!
Zix is offline
post #43 of 256 (permalink) Old 03-17-2019, 09:34 PM Thread Starter
Zix
Zix's Avatar
Originally Posted by H3CT1C View Post
Seriously, don't be worried about taking off the oil sump if you need to: the biggest hassle is getting the frame rails off! In fact, while the sump is off go ahead and remove (3 bolts) and clean the oil pick-up...
Tim
Sent from my ONEPLUS A3003 using Tapatalk
Let's hope I don't have to, though!
H3CT1C likes this.
Zix is offline
post #44 of 256 (permalink) Old 03-18-2019, 04:20 PM
Main Motorcycle: 2013 Triumph Bonneville
Good Luck, hope you can get it out.
2013 Triumph Bonneville with Mag Wheels
limeyryder13 is online now
post #45 of 256 (permalink) Old 03-18-2019, 05:51 PM Thread Starter
Zix
Zix's Avatar
Thank you!
Zix is offline
post #46 of 256 (permalink) Old 03-18-2019, 06:04 PM
Main Motorcycle: 2015 Thunderbird Storm
Chazzmichaels's Avatar
Other Motorcycle: 2008 Thruxton
Extra Motorcycle: 1998 Thunderbird Sport
Wow, what a thread! Iím anxious about the outcome and not my bike!!
Sent from my iPhone using Tapatalk
Chazzmichaels is online now
post #47 of 256 (permalink) Old 03-18-2019, 09:15 PM
Main Motorcycle: 2014 Thruxton
denoose's Avatar
Other Motorcycle: Mattel Big Wheel
Let us know if you see Jimmy Hoffa in there...he's still missing...
seriously, good wishes for a happy result!
and yes this should be filmed for posterity!
H3CT1C, bsgrimes and Back2-2 like this.
denoose is online now
post #48 of 256 (permalink) Old 03-18-2019, 10:18 PM Thread Starter
Zix
Zix's Avatar
Aren't we all...
Thank you! Yeah, I think it might be required at this point given the amount of attention this has gotten lol
Back2-2 likes this.
Zix is offline
post #49 of 256 (permalink) Old 03-19-2019, 02:30 AM
Main Motorcycle: 2017 T120 Black
Other Motorcycle: 2012 Speedmaster
Extra Motorcycle: 2018 T120 Black (Matt)
Not only do you have to film it, but you must mark the metal rod (once extracted) and sell it on eBay.
Good luck, we're all pulling for you!
ranger995 is offline
post #50 of 256 (permalink) Old 03-19-2019, 08:36 AM
Main Motorcycle: 2018 TIGER 1200 XRT
Duff-on-2's Avatar
Other Motorcycle: 2016 Bonneville T120
This thread is awesome! Netflix should make it into a mini-series.
Here's an idea:
If you can see the rod thru the scope and it's not too deep you might want to try to use a flexible wire or grabber with a TENS pad attached to it to pull it out. The TENS pads have a really sticky gel on the back of them and it might be strong enough to pick up the rod (imagine a frog's tongue). The pad itself is flexible and could be easy cut down, shaped, & attached.
https://www.walmart.com/ip/Electrode...5e&athena=true
Also, I would tie a string to the pigtail wire so you could retrieve it if it happened to come off the grabber!
Duff-on-2 is offline
Complete Instructions for Rebuilding Forks and Changing Fork Oil BombFactory Triumph SuperSports 19 04-04-2018 01:29 AM
Another t140 oil level problem Davewheels Classic, Vintage & Veteran 9 02-17-2018 05:19 AM
Another Thruxton Racing Question - Jonah, dman? greytop Club Cafe' 23 09-12-2008 08:19 AM
help - six inch plastic tube dropped in oil filler Syberian Tiger Chat 8 05-13-2006 12:27 PM
Oil Change Interval? WildRice Triumph SuperSports 4 07-15-2004 10:43 AM
