Dropped Metallic Rod Into Oil Filler - Page 4 - Triumph Forum: Triumph Rat Motorcycle Forums
 210Likes
post #31 of 256 (permalink) Old 03-17-2019, 04:08 PM
Main Motorcycle: '02 Triumph Bonneville
LapinAgile's Avatar
Here's a mechanical grabber from Amazon and they have others on the page also. I'd certainly practice with it, and have a beer first, before trying it.
https://www.amazon.com/dp/B07GGPD5NL...detail_0?psc=1
I do like the idea of draining the oil first, in situ of course, without moving the bike at all. Me, I'd do anything to try to get a look at where the end, or top, is before trying. It may even be lodged on a 'shelf' and might fall further if clumsily disturbed.
Do you have an idea of the length of the rod? You seem to remember which direction it fell which is helpful.
Best of luck!
'02 Bonneville - AI removed, 152MJ's, 42's 1.5 turns out, Air Box Gone/Uni Filters, TPS removed/capped, NH Togas, Nology Coil, Hotwire plug wires, TTP SafeStart, TTP Firestarter, D9 Bracket, Pingel petcock, 19 tooth sprocket, Michelin Pilot Actives.
LapinAgile is online now
post #32 of 256 (permalink) Old 03-17-2019, 04:08 PM
Main Motorcycle: 2015 Triumph Thruxton
yrunvs's Avatar
I was typing when you posted what you bought so I was a bit late in my advise. Good luck and keep us posted
TTP Tune#3, NH Toga's.
I'm no Gynecologist but hey I'll take a look.
yrunvs is offline
post #33 of 256 (permalink) Old 03-17-2019, 04:12 PM
yrunvs's Avatar
That rod is about 6 inches long so it might have gotten hung up near the top.
yrunvs is offline
post #34 of 256 (permalink) Old 03-17-2019, 04:15 PM Thread Starter
Zix
Main Motorcycle: 2004 Triumph Bonneville
Zix's Avatar
Originally Posted by bsgrimes View Post
You try hitting the starter motor? Might shoot right back out the hole....or mangle your bottom end.
*This is a joke. Do not start bike without retrieving rod.
Sent from my iPhone using Tapatalk
Thank God I didn't panic that much!
Zix is offline
post #35 of 256 (permalink) Old 03-17-2019, 04:16 PM Thread Starter
Zix
Zix's Avatar
Would taking off the engine cover be an option, too?
Zix is offline
post #36 of 256 (permalink) Old 03-17-2019, 04:20 PM
Main Motorcycle: 2014 Triumph Bonnie
Other Motorcycle: 1970 Bonnie
I learned a long time ago to stay out of the insides of an engine so I'm wondering is it possible for that rod to make its way to the bottom? My money would be on its hung up somewhere, but I dont know.
Also to the OP, take the key out of the ignition, you dont need any more accidents at this point!
DougAU is offline
post #37 of 256 (permalink) Old 03-17-2019, 04:23 PM Thread Starter
Zix
Zix's Avatar
I can't see the rod at all. It seems like I was a bit *too* adept at getting it to where it touches oil.
Thank you everyone for the encouragement. I feel much better knowing I have you all for support.
Back2-2 likes this.
Zix is offline
post #38 of 256 (permalink) Old 03-17-2019, 04:23 PM
Legend
Main Motorcycle: 2008 Bonneville Black
Driftless Admin
BonnieBlack's Avatar
Other Motorcycle: Spousal 2009 Bonnie Black
No, there's no access from the sides. Not great access from the bottom either to be honest. The bottom of motor isn't all open above the sump, there are a couple decent size windows though, with the crank above those. But, one thing at a time, first get a good visual on the rod and figure out where it is.
Almost wondering if something really sticky wouldn't help. Like fly paper wrapped around a dowel? But whatever you do, don't add to the problem and let something like that fall in Like the attachments that come with that endoscope, don't use them!
You are safe to put the bike in neutral and roll it to the side of the garage if need be. You don't want to turn the motor for sure, or let the rod fall deeper. But you ought to be alright doing that if need be.
bsgrimes likes this.
BonnieBlack is offline
post #39 of 256 (permalink) Old 03-17-2019, 04:28 PM Thread Starter
Zix
Zix's Avatar
Okay! I've ordered the endoscope and grabber. I'm going to drain the oil before I use them - just to make sure I get the best view possible.
BonnieBlack likes this.
Zix is offline
post #40 of 256 (permalink) Old 03-17-2019, 05:48 PM
Main Motorcycle: 1068cc '05 Thruxton
H3CT1C's Avatar
Seriously, don't be worried about taking off the oil sump if you need to: the biggest hassle is getting the frame rails off! In fact, while the sump is off go ahead and remove (3 bolts) and clean the oil pick-up...
Tim
Sent from my ONEPLUS A3003 using Tapatalk
~'05 Thruxton~Sport Evolution 1100cc~FCR 39mm~813 cams~shim-under-bucket~+1.5mm valves~45mm headers~Ignitech CDI~m-Lock~m-Unit~Acewell CA85~F3 Frankenfork~Hagon Nitros~Pretech caliper~520 chain~wide 17" rims~sticky rubber~
H3CT1C is online now
Complete Instructions for Rebuilding Forks and Changing Fork Oil BombFactory Triumph SuperSports 19 04-04-2018 01:29 AM
Another t140 oil level problem Davewheels Classic, Vintage & Veteran 9 02-17-2018 05:19 AM
Another Thruxton Racing Question - Jonah, dman? greytop Club Cafe' 23 09-12-2008 08:19 AM
help - six inch plastic tube dropped in oil filler Syberian Tiger Chat 8 05-13-2006 12:27 PM
Oil Change Interval? WildRice Triumph SuperSports 4 07-15-2004 10:43 AM
