Dropped Metallic Rod Into Oil Filler - Page 20 - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 210Likes
post #191 of 256 (permalink) Old 03-26-2019, 04:41 PM
Main Motorcycle: 2016 Thruxton 1200
CanberraR3's Avatar
Other Motorcycle: 2018 Street Scrambler
Extra Motorcycle: 2016 Tiger 800 XCX
Originally Posted by TrueSavage View Post
I think the suction hose is a good idea, I'm just thinking of ideas of how to generate enough yet still have a small flexible line that will get in there.
Itís been suggested - go back and look.
CanberraR3 is online now
post #192 of 256 (permalink) Old 03-26-2019, 05:21 PM
Main Motorcycle: 01 Triumph Bonneville
Other Motorcycle: 01 HD Night Train
Extra Motorcycle: 87 Honda Super Magna
If I can pull a woman gold bracelet from a sink drain with an ordinary household vacuum with NO attachments...it should pick up an aluminum rod with ease....Your all over thinking the crap out of this
Arrow 2-2...Unrestricted Air box with K&N and TTP Breathe 140 mains with 42 pilots 2 shims
DUCKMAN is offline
post #193 of 256 (permalink) Old 03-26-2019, 05:23 PM
Legend
Main Motorcycle: 2008 Bonneville Black
Driftless Admin
BonnieBlack's Avatar
Other Motorcycle: Spousal 2009 Bonnie Black
I'll have you know, I'm barely thinking at all
BonnieBlack is offline
post #194 of 256 (permalink) Old 03-26-2019, 07:38 PM
CanberraR3's Avatar
Agreed. But itís got to get in through a pretty small hole. There are many factors to think through. Size of the opening, shape and weight of the part, internal obstacles, visibility, dexterity of the user. No point ignoring any of those.
post #195 of 256 (permalink) Old 03-26-2019, 08:05 PM
Main Motorcycle: '02 Triumph Bonneville
LapinAgile's Avatar
Ah...Yes, so many gentle considerations at that last moment -
'02 Bonneville - AI removed, 152MJ's, 42's 1.5 turns out, Air Box Gone/Uni Filters, TPS removed/capped, NH Togas, Nology Coil, Hotwire plug wires, TTP SafeStart, TTP Firestarter, D9 Bracket, Pingel petcock, 19 tooth sprocket, Michelin Pilot Actives.
LapinAgile is online now
post #196 of 256 (permalink) Old 03-26-2019, 08:43 PM
Main Motorcycle: '02 Bonneville 100yr anv.
Back2-2's Avatar
Other Motorcycle: 2006 Honda 450X
The OP'r could just do as a HD guy I worked with did. His metal dip stick on the oil fill plug broke off and fell in the gear box. He just rode it and the gear box chewed it up. He says it shifts way better now than it did before.
While I do not recommend this - I thought it was pretty funny and kind of sums up a HD motorcycle... CLUNK / CUR CHINK.....
Baltobonneville likes this.
ďIts all about motorbikes. Always has been, always will beĒ
Neil in the Black Hills
Back2-2 is offline
post #197 of 256 (permalink) Old 03-26-2019, 09:32 PM
Vacuum may not work...I just put a six inch piece of steel rod about the same diameter down a liter bottle. Neither of my house vacuums would grab the rod. I fired up the compressor and used my vacuum bleeder and inserted the hose into the bottle...i could not grab the rod. There isnt enough surface area to suck on.....
How boring is my life.....
Back2-2 and ranger995 like this.
DUCKMAN is offline
post #198 of 256 (permalink) Old 03-26-2019, 10:45 PM
Main Motorcycle: '70 Daytona
This is all theory of course, it's great you actually built and tested something, but I think the best option would be a hose that is just large enough to fit over the rod. You could use some sloppy duct tape to go from shop vac nozzle to the narrower diameter tube. You would want to wiggle the tube and let it snake down over the rod until the rod is pretty well contained within the hose. I'm not sure Zix has enough visibility and maneuverability to make this happen. If you had all the time and patience in the world you could even play around with tubing that is thin walled such that you leave the vacuum off until the tube is over the rod, then turn on the vacuum so that the tube sucks down around the rod.....
Good luck Zix!
mmanasas is offline
post #199 of 256 (permalink) Old 03-26-2019, 11:00 PM
Main Motorcycle: 72 T120R
Buckshot1's Avatar
Other Motorcycle: 02 Sprint ST
Shrink tubing and a hair dryer?
jstarktt, Steve Ford and bsgrimes like this.
Michael
72 T120R
02 Sprint ST
builder of plunger drill jig
Buckshot1 is offline
post #200 of 256 (permalink) Old 03-27-2019, 12:13 AM
Main Motorcycle: 2006 Blue Thruxton
steventhechef's Avatar
Other Motorcycle: 06 Thruxton - wife's bike
So size is important ........... now
steventhechef
Eggs & Bacon. A day's work for a chicken, a lifetime commitment for a pig.
steventhechef is online now
Complete Instructions for Rebuilding Forks and Changing Fork Oil BombFactory Triumph SuperSports 19 04-04-2018 02:29 AM
Another t140 oil level problem Davewheels Classic, Vintage & Veteran 9 02-17-2018 06:19 AM
Another Thruxton Racing Question - Jonah, dman? greytop Club Cafe' 23 09-12-2008 09:19 AM
help - six inch plastic tube dropped in oil filler Syberian Tiger Chat 8 05-13-2006 01:27 PM
Oil Change Interval? WildRice Triumph SuperSports 4 07-15-2004 11:43 AM
