Front calliper Replacement Bonnie 2003 - Triumph Forum: Triumph Rat Motorcycle Forums
 4Likes
post #1 of 18 (permalink) Old 03-04-2019, 03:16 AM Thread Starter
Main Motorcycle: Bonneville T100 03
RRR1306's Avatar
Hi, pulled the front calliper off my 2003 Bonnie T100 and discovered top edge of cylinder at dust seal was damaged. That might explain why piston was pitted and seized and brakes didnít work! Rebuild kit with seals and pistons waiting on the workbench not much good if dust seal canít seal.
Long story short, looking for replacement front calliper on eBay. Saw one from 2015 scrambler at a reasonable price but canít find anything on compatibility. Will it fit? If not what models have interchangeable front callipers? Just want to keep standard rather that do 3 piston or brembo upgrade.
Cheers. Love the Bonnie. Would be better if it stopped when needed
Rod (Sydney)
RRR1306 is offline
post #2 of 18 (permalink) Old 03-06-2019, 04:51 PM Thread Starter
RRR1306's Avatar
I guess my question is 'Are all front brake calipers the same?"
RRR1306 is offline
post #3 of 18 (permalink) Old 03-06-2019, 06:50 PM
6t
Main Motorcycle: The one that I am on
6t's Avatar
Other Motorcycle: 2002 Bonneville America
Extra Motorcycle: Honda RC30
They are for the carbed 'bikes. Scrambler, Bonneville, Thruxton, America and Speedmaster take the same. Some Speedys have twin discs, don't know if rt is same as lt. As for EFi, can't say for sure.
You could try putting a "wanted" add in the classified section, lots of people including me have upgraded and may have the original knocking around. All my stuff is in storage and under snow (that's white powdered frozen water for those in very southern climates) otherwise I'd see what I could find.
RRR1306 likes this.
2002 T100 Anniversary. Lucifer Orange no more, "Scrambled"
Brakes and suspension, various Scrambler parts, speedo/tach in headlamp .
6t is online now
post #4 of 18 (permalink) Old 03-09-2019, 12:43 PM
Main Motorcycle: 2001 Triumph Bonneville
SiFi's Avatar
Where would I find the classified section ?
SiFi is offline
post #5 of 18 (permalink) Old 03-09-2019, 12:57 PM
Main Motorcycle: Triumph Scrambler
Kiwi Tiger's Avatar
Scroll to the top of the page.
Look under tools.
3rd one down
Kiwi Tiger is offline
post #6 of 18 (permalink) Old 03-09-2019, 07:36 PM
Main Motorcycle: 2014 Triumph Bonnie
Other Motorcycle: 1970 Bonnie
You have to have 25 posts before you can use the classified section
DougAU is online now
post #7 of 18 (permalink) Old 03-09-2019, 09:43 PM
Main Motorcycle: '03 Triumph Bonneville
There is a very easy way to cross reference parts.... simply go to BikeBandit and put in the info for the two bikes and see if they have the same part number...
In the case of your '03 Bonnie and the '15 Scrambler, they share the same T2020542 listed part number for the caliper...
I hope that helps...
SCbonneville is offline
post #8 of 18 (permalink) Old 03-10-2019, 04:15 PM
Main Motorcycle: '03 Bonneville T100
coachconnor's Avatar
Other Motorcycle: 74 Honda 450 long gone
A heads up: even though it's a relatively short run of brake line to the caliper compared to an auto, it takes a helluva lot of pumping the brake lever to bleed the brakes. Unless you have a Mity Vac suction reservoir. ... Which I don't.
19t, BC Sleepers, 42 pilots, Thrux needles & springs, 135 mains, K&N, Dart screen, air box bafflectomy, Barnett greens, TEC shocks
Wonderous apparitions - provided by magicians. J Fogerty
coachconnor is offline
post #9 of 18 (permalink) Old 03-10-2019, 05:00 PM Thread Starter
RRR1306's Avatar
Thanks guys
RRR1306 is offline
post #10 of 18 (permalink) Old 03-11-2019, 10:08 AM
Main Motorcycle: 2016 T120
TrueSavage's Avatar
This is what I was going to suggest, but I would like to add this for others using this method.
I don't have enough experience with Triumph to know what they're like,but Honda was bad for constantly superseding part numbers, so 2 bikes may still have the same parts even though the P/Ns are different. The online breakdowns are not always good at keeping up with that. So if the 2 were different I would run the part numbers through Google. Sometimes I would find that the older P/N did change up to the newer one.
It does not matter where you go, how you got there, or how long it took you, someone on a Triumph Bonneville has done it before you. If you didn't do it on a Triumph, it doesn't really matter anyway.
TrueSavage is offline
New front calliper bleed issues Simon B Air Cooled Twins Technical Talk 4 04-22-2016 01:59 PM
Replacement America Front Fender... Help! Help! Help! FCB Air Cooled Twins Talk 0 10-08-2014 05:17 PM
The Bonnie Tales #2: Henry & Ken Bonnie06Tangerine Ride / Trip Reports 12 04-08-2010 07:12 PM
bonnie america front axle same as regular bonnie? smcquilling Air Cooled Twins Technical Talk 1 01-07-2010 12:01 PM
"The Bonnie Tales" #1: The Sunday Roast Bonnie06Tangerine Ride / Trip Reports 20 08-05-2009 06:12 AM
