Seized Engine - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 37Likes
post #1 of 54 (permalink) Old 03-02-2019, 04:46 PM Thread Starter
Plattys's Avatar
Seized Engine
Hello, I have a question on a possible seized engine and I would love any input. I have 2015 Scrambler with just over 5k on her, the choke was left on by mistake for 45 minutes while ideling....it was a frigid morning. The motor began to smoke and was immediately shut off. As it would not start I changed the plugs, checked fuel and tried to jump her...nothing. A local bike mechanic picked her up yesterday and subsequently told me the engine is seized and I can either sell it for parts or look for a used scrambler engine. I’m having trouble believing the motor could melt down so quickly, especially as I saw no loss of oil. It is essentially a new and beautiful bike so I would hate to sell for parts. Has anyone heard of this happening, should I take this guys word for it, he does seem to know likes pretty well...any advice greatly appreciated! Sp
Plattys is offline
post #2 of 54 (permalink) Old 03-02-2019, 05:06 PM
Main Motorcycle: Bonneville
1job's Avatar
Other Motorcycle: It changes all the time
Extra Motorcycle: Street Scrambler
If you left the bike idling on the sidestand for more than a few minutes you melted the oil pump gears which are plastic. On the sidestand the gears are not in the oil. I have seen this more than once. Your motor is toast.
Forchetto likes this.
1job is offline
post #3 of 54 (permalink) Old 03-02-2019, 05:27 PM
Main Motorcycle: '98 T595 Daytona
Other Motorcycle: 2014 Ninja 1000ABS
This is the wrong site for this query. You need to post this in the air cooled twins tech subforum. This site is for issues with the forum itself, not motorcycle related. As a guess, you may have a seized oil pump, not the engine. Repost and you will obtain experienced folks to help you out.
Back2-2 likes this.
Felony is offline
post #4 of 54 (permalink) Old 03-02-2019, 11:04 PM
Main Motorcycle: 2007 Bonnie T100
bonza's Avatar
Other Motorcycle: Jeep Wrangler
letting an air cooled engine idle for 45 minutes risks overheating the engine as there is no air movement to take away the heat regardless if the choke is on or off
chances are as 1job posted, you have destroyed the two plastic gears that drive the oil pumps and possibly have seized it
clutch side cover will have to come off to check the gears then take it from there
Hedge, a former member did the same, resulting in the need for a complete engine rebuild. I think he detailed the event in the "other" forum
I dont know how long you can let these engines idle for without air movement, but I personally would draw the line at 15 minutes
2007 Tuxedo T100.
Dom Tourers, TTP breathe, DNA filter,baffle gone, 40/140/1 shim 3 turns, TTP igniter tune, Hagon Nitros, Thruxton Bars, Halcyon bar end mirrors, Pingel fuel valve, Monza gas cap, Burton seat, Avon Roadriders
bonza is offline
post #5 of 54 (permalink) Old 03-03-2019, 02:03 PM
Legend
I keep a big fan in the garage that I put on it when I have the motor running, for example for carb synchronization.
As I recall, Hedge's attempts to get to the bottom of his issues with the motor involved multiple mechanics and more work, aggravation, and money than the motor was worth, although I think that he eventually got it fixed. Then he sold it.
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes RC, no snorkel, inlet enlarged, 118/40/NBZT needles/1 shim/3 turns, Ikon 7610s, Ricor Intiminators, Barnett green clutch springs, Michelin Pilot Activs, D9 gauge panel, tachometer.
Baltobonneville is offline
post #6 of 54 (permalink) Old 03-03-2019, 04:11 PM
Main Motorcycle: 2002 Triumph America
Wire-Wheels's Avatar
Other Motorcycle: 1995 Triumph Sprint
Extra Motorcycle: 2000 Triumph Legend TT
I don't believe there IS a choke on a 2015, so that has nothing to do with it. Loss of oil pressure, yes. ...J.D.
Wire-Wheels is offline
post #7 of 54 (permalink) Old 03-03-2019, 04:38 PM
No choke, fast idle lever. Carb versions just dump more fuel.
Felony is offline
post #8 of 54 (permalink) Old 03-03-2019, 08:02 PM
Main Motorcycle: 2008 Bonnie Black Special
PieMan's Avatar
The twin engines can be idled at factory spec idle speed for half an hour with no problems, but at fast idle for 45 minutes! That would be one hot engine and as has been said, melted oil pump gears are a likely cause of the seizure.
SpeedTrip07 likes this.
Mike (UK)
https://www.triumphtwinpower.com
PieMan is offline
post #9 of 54 (permalink) Old 03-04-2019, 06:55 AM Thread Starter
Plattys's Avatar
There is a choke on a 2015. Thank you for the replies. I guess I now need to make the decision of either rebuilding the engine or trying to find one used...which comes with another set of complications.
Plattys is offline
post #10 of 54 (permalink) Old 03-04-2019, 08:42 AM
What you are referring to as a choke on your bike is simply a fast idle control even though your engine is fuel injected. Doesn't matter as far as your engine issues. If there was a true choke the engine would have stalled out probably before any damage could occur. On carb versions, the choke lever is an enrichment circuit. Dumps more fuel vs restricting air flow. Manufacturers should really stop using the term choke for modern bikes and cars. Just an aside. Sorry for your engine woes. Most fuel injected bikes have auto control over fast idle cold start up. I guess Triumph thought the lever was quaint like the dummy carb/throttle bodies. That, and the FI system is rather rudimentary.
Felony is offline
Check engine light ON? Just phone your ECM... Forchetto Air Cooled Twins Technical Talk 32 06-13-2016 08:43 PM
Seized engine Sean1959 Classic, Vintage & Veteran 16 04-25-2015 08:21 PM
Gas milage? Code Man Classic, Vintage & Veteran 49 01-13-2015 09:58 PM
TBS engine removal TexasTBird Hinckley Classic Triples 3 01-17-2014 05:11 AM
SeaFoam?? oz_955i Daytona Deliberations 14 05-27-2009 08:00 AM
