Seized Engine - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
 20Likes
post #11 of 41 (permalink) Old 03-04-2019, 09:42 AM
Legend
Main Motorcycle: 2008 Bonneville Black
Driftless Admin
BonnieBlack's Avatar
Other Motorcycle: Spousal 2009 Bonnie Black
Might be worth calling Pinwall at https://pinwallcycle.com about engine availability. Or ask your mechanic to check them out. https://pinwallcycle.com/
BonnieBlack is offline
post #12 of 41 (permalink) Old 03-04-2019, 10:44 AM Thread Starter
Plattys's Avatar
Thanks again for all the advice, Pinwall has a crankcase available...I’ll need to check with my mechanic today and see the full diagnosis oon the engine. Would really like to salvage the bike if financially viable as it’s essentially new otherwise....Sp
Plattys is offline
post #13 of 41 (permalink) Old 03-04-2019, 11:42 AM
Main Motorcycle: 2014 Thruxton
Location: Colorado, USA. Kerala, India. Thailand (winters)
Other Motorcycle: KDX200
Extra Motorcycle: 1964 Royal Enfield 350
Originally Posted by Plattys View Post
Thanks again for all the advice, Pinwall has a crankcase available...Iíll need to check with my mechanic today and see the full diagnosis oon the engine. Would really like to salvage the bike if financially viable as itís essentially new otherwise....Sp
Where are you located?
TomJ is offline
post #14 of 41 (permalink) Old 03-05-2019, 09:50 AM Thread Starter
Plattys's Avatar
I’m based in Brooklyn and Connecticut, the bike is currently at a shop in Ct. and I’m waiting to hear from the mechanic today to see if it can be saved for a reasonable price. As mentioned, it is otherwise a new machine. Sp
Plattys is offline
post #15 of 41 (permalink) Old 03-05-2019, 10:39 AM
Iím based in Brooklyn and Connecticut, the bike is currently at a shop in Ct. and Iím waiting to hear from the mechanic today to see if it can be saved for a reasonable price. As mentioned, it is otherwise a new machine. Sp
Damn. If you were closer, I have a line on an engine. Prob not worth shipping out there though.
TomJ is offline
post #16 of 41 (permalink) Old 03-05-2019, 06:37 PM
Main Motorcycle: Thunderbird LT
I struggle to believe this could happen on a modern bike. I'm not doubting you but I'd have thought there would be a safety cut-out or similar. An old carb bike would have just stalled. Sucks to have a ruined bike for something so simple.
BasilM is offline
post #17 of 41 (permalink) Old 03-06-2019, 07:07 AM Thread Starter
Plattys's Avatar
Yes, I take full ownership for the stupidity of leaving the choke engaged for 45 minutes but I never thought it would cook the engine, at most I assumed I fouled the plugs or something. Looking at a 3 grand rebuild or an engine replacement. The mechanic says there is literally nothing from the old engine to be salvaged. I may just have to walk away. I guess it’s worthwhile to contact Triumph even though a warranty expired?
Plattys is offline
post #18 of 41 (permalink) Old 03-06-2019, 08:47 AM
Legend
Driftless Admin
There's no warranty issue here, Triumph won't help you pay for this. Fixing this one will be expensive but a lot cheaper than buying a another one. You could sell it as-is, but I think you'd make more money if you fixed it and then sold it.
post #19 of 41 (permalink) Old 03-06-2019, 08:54 AM
Main Motorcycle: '98 T595 Daytona
Other Motorcycle: 2014 Ninja 1000ABS
I doubt Triumph would do anything even if the bike was under warranty. You basically left the engine running at a high idle with very little air flow to cool the engine and the engine oil. The oil pump gears are not metal and this issue of overheating the engine and melting the gears is well documented on this forum. The high idle lever is no different than opening up the throttle. It does not cause the mixture to go rich, which would have fouled the plugs and maybe have stalled out the engine. High idle lever, not a choke. You made a mistake, it happens.
Felony is online now
post #20 of 41 (permalink) Old 03-06-2019, 09:23 AM
Main Motorcycle: 2016 KTM 1290 sd SE
steve59's Avatar
Other Motorcycle: 2012 K1600 GTL
Extra Motorcycle: 13S3-se/06R3/11Storm
Plastic oil pump gears inside an engine! Can somebody tell me the advantages of using plastic gears over metal please? I feel for anybody that loses an engine from over idle
steve59 is offline
Check engine light ON? Just phone your ECM... Forchetto Air Cooled Twins Technical Talk 32 06-13-2016 08:43 PM
Seized engine Sean1959 Classic, Vintage & Veteran 16 04-25-2015 08:21 PM
Gas milage? Code Man Classic, Vintage & Veteran 49 01-13-2015 09:58 PM
TBS engine removal TexasTBird Hinckley Classic Triples 3 01-17-2014 05:11 AM
SeaFoam?? oz_955i Daytona Deliberations 14 05-27-2009 08:00 AM
