Tapered steering head bearings - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
post #1 of 22 (permalink) Old 12-26-2018, 09:07 PM Thread Starter
Main Motorcycle: 2014 Thruxton
stoanee's Avatar
Other Motorcycle: For real? Or in my mind?
Installed the tapered bearing kit into steering head of my 2104 Triumph Thruxton. When torqued to remove all play, there is perceptible resistance when the steering head is being rotated (without the forks) just before and just after center. When I slack off the top nut on the steering stem so that the stem is hanging on the top bearing and turn the bottom tree I can feel the resistance. When I push the tree up against the bottom bearing so that the top bearing has no weight on it and turn it, I feel no resistance and everything turns smoothly. This leads me to believe something is not right with the upper 99-3520 bearing. I have cleaned and repacked bearing with synthetic bearing grease twice and I get the same result. I cannot see any obvious damage on the bearing. I am reluctant to put the forks etc back together if the issue persists and I have to disassemble it all to find out what the issue is. When I bought the All Balls kit I found positive reviews but now when googling for problems there does seem to be some issues in quality. I am trying to get the bike as stable as I can and thought this would be a low cost improvement. Any tips out there folks?
stoanee is online now
post #2 of 22 (permalink) Old 12-26-2018, 10:05 PM
Main Motorcycle: '02 Bonneville 100yr anv.
Back2-2's Avatar
Other Motorcycle: 2006 Honda 450X
I know this does not add anything to your issue but - The last time I bought All Balls bearings was my last. They are made in China and I was very disappointed in the quality.
It sounds like you have trouble shot it - Next I would call ABB and see what they have to say.
“Its all about motorbikes. Always has been, always will be”
Neil in AZ
Back2-2 is online now
post #3 of 22 (permalink) Old 12-26-2018, 10:33 PM
Main Motorcycle: '02 Triumph Bonneville
LapinAgile's Avatar
I can't find the thread tonight, but I think I remember someone replacing the originals with Timken tapered roller bearings. Gawd I hope I'm not embarrassed to find in the morning that I'm wrong, but even so they may be able to fit a set. Top quality stuff.
'02 Bonneville - AI removed, 152MJ's, 42's 1.5 turns out, Air Box Gone/Uni Filters, TPS removed/capped, NH Togas, Nology Coil, Hotwire plug wires, TTP SafeStart, TTP Firestarter, D9 Bracket, Pingel petcock, 19 tooth sprocket, Michelin Pilot Actives.
LapinAgile is online now
post #4 of 22 (permalink) Old 12-27-2018, 03:06 AM Thread Starter
stoanee's Avatar
Yes I also remember that but have not found that reference either....
Ya, I shot them an email, I will see what they say.
post #5 of 22 (permalink) Old 12-27-2018, 03:14 AM Thread Starter
stoanee's Avatar
Found this...https://www.triumphrat.net/air-coole...-bearings.html
I will find some and try them out
post #6 of 22 (permalink) Old 12-27-2018, 05:47 AM
Supernova
Forchetto's Avatar
Magnificent and lavisly illustrated thread by @Junipero here:
https://www.triumphrat.net/air-coole...k-springs.html
Forchetto is offline
post #7 of 22 (permalink) Old 12-27-2018, 06:31 AM
LapinAgile's Avatar
THIS is the thread! I worked at Timkens after high school for 2 years before the Army, great job.
post #8 of 22 (permalink) Old 12-27-2018, 08:33 AM
Main Motorcycle: 01 Triumph Bonneville
Other Motorcycle: 01 HD Night Train
Extra Motorcycle: 87 Honda Super Magna
Rotate the bearing 1/4 turn. Does the tight spot move? If it moves the bearing maybe bad...If the tight spot is still in the same place the race is likely not seated correctly in the bore. Coincidentally I am in the middle of doing the All-Balls Conversion right now. I am just waiting on the race removal tool.
Arrow 2-2...Unrestricted Air box with K&N and TTP Breathe 140 mains with 42 pilots 2 shims
DUCKMAN is offline
post #9 of 22 (permalink) Old 12-27-2018, 01:50 PM Thread Starter
stoanee's Avatar
I will pop out race to inspect but all looks good from the outside. Race is evenly seated, I made sure of that. I attached a pic of my race removal tool, a large spiral nail, it works great!
ID:	630326   Click image for larger version
post #10 of 22 (permalink) Old 12-27-2018, 08:55 PM
I ordered the OTC tool. Non of my drifts, chisels or screwdrivers will make contact.
DUCKMAN is offline
Tool for the steering head bearings Coffee_brake Hinckley Classic Triples 6 02-21-2018 10:57 AM
steering head bearings redonly Sprint Forum 10 02-14-2013 07:31 AM
Torque; tapered steering bearings Derby Boy Air Cooled Twins Technical Talk 2 08-18-2011 07:38 AM
head steering bearings jjimmydutch Air Cooled Twins Technical Talk 2 02-08-2010 01:22 PM
Tapered roller steering stem bearings vertwrks Air Cooled Twins Technical Talk 15 03-25-2008 10:06 AM
