Need help on carbed Bonnie! - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 12Likes
post #11 of 42 (permalink) Old 07-16-2018, 04:35 PM Thread Starter
Main Motorcycle: Bonneville T100 2005
Other Motorcycle: Yamaha SR400
Thanx for this advice! I'm still trying to find any air leakage but don't understand how to do in better. Checking all the cables and tubes don't give a result. But seems that the problem should be somewhere here
Pingwinst is offline
post #12 of 42 (permalink) Old 07-16-2018, 05:00 PM
Main Motorcycle: 08 t100
Other Motorcycle: 08 Thruxton
Extra Motorcycle: 72 Norton comando
Was the bike not being used for a long time before the problem started?
rweb is online now
post #13 of 42 (permalink) Old 07-17-2018, 03:34 AM Thread Starter
Bike stays for a half a year in garage, but after that is starts and goes normally for about 200 kilometers, then CDI unit died and I've change it to Triumph Twin Power and at the same time problem appears
post #14 of 42 (permalink) Old 07-17-2018, 10:41 AM
I'm still thinking pilot circuit problem, needs cleaning again, air leak or bad needle and seat (leaking) as @steventhechef suggested. Usually plug wires, coils will show up more under load or at hi RPM than at idle. All ignition parts, except igniter can be tested with an ohm meter.
rweb is online now
post #15 of 42 (permalink) Old 07-18-2018, 07:07 PM
Main Motorcycle: 2006 Bonneville T100
road dog's Avatar
Other Motorcycle: 2002 ThunderBird 900
Extra Motorcycle: 1982 CB900F SuperSport
My 2006 is having a very similar problem. Sputters under 2K and one sided popping on decel. Also thought it was a fuel problem, but it wasn't. Waiting for a new Nology coil to arrive now. As already said... likely your ignition coil causing the misfire.
road dog is offline
post #16 of 42 (permalink) Old 07-19-2018, 03:49 AM Thread Starter
Thanks for info'! I for now this problem is not solved? How do you understand that it's about coil?
post #17 of 42 (permalink) Old 07-19-2018, 05:42 PM
road dog's Avatar
In my case it's just process of elimination. I eliminated the carbs, same as you have. OEM coils are common to break down and mine is 12 yrs/38K miles used. Still waiting for my new coil, but will let you know tomorrow if it fixed my misfire or not.
road dog is offline
post #18 of 42 (permalink) Old 07-19-2018, 06:05 PM
Main Motorcycle: '03 Bonneville T100
coachconnor's Avatar
Other Motorcycle: 74 Honda 450 long gone
For suspected problems, oversimplified rule of thumb: running rough on both cylinders = fuel / vacuum
one cylinder not firing = coils / wires
shuts off all at once and re-fires again and goes dead again = ignitor
coil can give a good reading and not fire when under load ignitors will faill intermittently before going completely dead sometimes.
19t, BC Sleepers, 42 pilots, Thrux needles & springs, 135 mains, K&N, Dart screen, air box bafflectomy, Barnett greens, TEC shocks
Wonderous apparitions - provided by magicians. J Fogerty
coachconnor is offline
post #19 of 42 (permalink) Old 07-20-2018, 09:25 PM
road dog's Avatar
New coil did NOT correct my problem.
road dog is offline
post #20 of 42 (permalink) Old 07-21-2018, 02:05 PM
Main Motorcycle: '01 Bonneville
RichBinAZ's Avatar
Other Motorcycle: '91 GSX1100G
Extra Motorcycle: '14 FZ-09
Because it's misfiring on one cylinder, then turning back on - like kid playing with light switch.
If carb / air leak, then it would be constant problem
If Ignition pick-up or ignition computer it would be both cylinders cutting out or randomly switching from side to side
The ignition coil may test OK cold, but when it gets hot, problems show up.
LapinAgile likes this.
RichB in AZ
RichBinAZ is offline
Scottoiler on Carbed Bonnie Demonic Air Cooled Twins Talk 6 05-01-2016 03:09 PM
Looking for exact Yuasa battery for carbed Bonnie Mingo09 Air Cooled Twins Talk 19 04-26-2016 10:34 AM
New 1100cc Triumph caf mapesd Air Cooled Twins Talk 303 02-07-2015 05:50 PM
