Replace Speedo Drive with Spacer - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 6Likes
  • 1 Post By Merlin 903
  • 4 Post By Tony_C
  • 1 Post By Tony_C
post #1 of 10 (permalink) Old 04-15-2018, 05:09 AM Thread Starter
Main Motorcycle: Yamaha Fazer 600
Other Motorcycle: Triumph Bonneville T100
Extra Motorcycle: Honda CB200
Hello,
Can anyone tell me if they have seen spacers for sale which would allow me to remove my speedo drive? I have a GPS speedo to install and I know plenty of people use Motogadget speedos so what do they normally do with their old speedo drives? The bike is a 2006 Bonneville T100 865 carb.
I could get a local shop to make one up but it would be easier if I could order online.
Cheers,
Tony
Tony_C is online now
post #2 of 10 (permalink) Old 04-15-2018, 09:52 AM
Main Motorcycle: 2009 Speed Triple
Merlin 903's Avatar
Other Motorcycle: 2009 Scrambler
Extra Motorcycle: 2002 Daytona CE
Merlin 903 is offline
post #3 of 10 (permalink) Old 04-15-2018, 04:45 PM
Main Motorcycle: 2001 Bonneville
miket100's Avatar
Other Motorcycle: 2011 Mag wheel Bonnie
Extra Motorcycle: 2017 Scrambler air cooled
The OE stepped aluminium speedometer spacer from the right hand side of my 2011 mag wheel Bonnie that has LCD guages was a drop in direct fit to the 2001 Bonnie when I fitted GPS speedo to that bike, spacer was readily available from Triumph and besides looking good wasnt very expensive. The mag wheel is wider between the forks than the spoke wheel so it was a surprise it was the right width for my 01 bike.
Sent from my SM-T310 using Tapatalk
2001 790 Bonnie, TTP stg 1 igniter 8,500 limit, Breathe intake DNA filter no AB baffle, CVK 36,#140main,#42 pilot, NAGB needle no shims,Mix out 1.5t, Dunstall 2 to 1, Devon tubeless wheels 18x3.5 front,rear Talon hub 17x4.25
miket100 is online now
post #4 of 10 (permalink) Old 04-16-2018, 01:10 AM Thread Starter
Thanks I like the idea of the mag wheel spacer alot. I'll definitely have a look at that.
I would still be interested to hear what other people have done as well.
Cheers
post #5 of 10 (permalink) Old 04-17-2018, 11:05 AM
Main Motorcycle: 2014 Bonneville T100
dualshowman's Avatar
Other Motorcycle: 2001 Bonneville
Extra Motorcycle: 1988 Yamaha XT 600
I’m not implying that another vendor cannot provide the same or better but...
For $9, I can find no reason not to go with anything other than the Triumph OEM piece. We already know three important things about it: 1) It’s available 2) It’s cheap & 3) It’s repeatable/designed correctly.
Let us know how this works out.
Being There
dualshowman is offline
post #6 of 10 (permalink) Old 10-23-2019, 08:51 AM Thread Starter
Better late than never, I finally got round to fitting the wheel and decided to take the advice and try the spacer from the mag wheel Bonneville. It is a perfect fit and very reasonable at £5 from my local dealership. The part number is T2000313. Thanks!
post #7 of 10 (permalink) Old 10-27-2019, 01:05 PM
Main Motorcycle: 2007 Triumph Scrambler
Balto Scrambo's Avatar
Thanks for the update!
Curious what GPS speedo you are using on your carb'd bike and how you like it? I am looking at options for my 2007.
Balto Scrambo is offline
post #8 of 10 (permalink) Old 10-28-2019, 09:55 AM Thread Starter
I havent actually fitted it yet. I'm in the middle of putting the bike back together and working my way up to the handlebars. I went for a speedo made by Speedhut because I like that it incorporates a tacho into the speedo gauge. It is quite big but I like it, alot of people prefer the minimalist look though. The website is great because you get to customise almost every detail of the gauge.
ID:	660250   Click image for larger version
Back2-2 likes this.
post #9 of 10 (permalink) Old 10-31-2019, 04:08 AM
Askari's Avatar
looks
That looks neat, I dont think it too big. what have you done with the headlight, that could give a slick front end.
Askari is offline
post #10 of 10 (permalink) Old 11-07-2019, 09:04 AM Thread Starter
I havent done much with the headlight yet. I actually quite like the big original one, at the moment I'm planning on a yellow lens and stainless mesh guard. But always open to opinions.
Thanks
The Definitive USD Fork Conversion for Sprints Thread DEcosse Sprint Forum 567 10-15-2019 04:27 PM
Speedo cable length tjkoko Classic, Vintage & Veteran 20 08-18-2017 11:16 AM
Question on Air Box for 1978 T140V speedracer92 Classic, Vintage & Veteran 26 11-18-2016 02:01 AM
Help - Progressive Fork spring spacer length for 2010 T100 Brando Cide Air Cooled Twins Technical Talk 2 08-08-2015 12:26 PM
Speedo Drive Gear Hyates Air Cooled Twins Technical Talk 6 06-23-2015 11:15 PM
