Charging Voltage - Triumph Forum: Triumph Rat Motorcycle Forums
 11Likes
post #1 of 33 (permalink) Old 02-22-2018, 04:46 PM Thread Starter
Main Motorcycle: '01 Bonneville
RichBinAZ's Avatar
Other Motorcycle: '91 GSX1100G
Extra Motorcycle: '14 FZ-09
Charging Voltage
Hi, I did check out the sticky file on electrickery etc, but as I had to charge the battery again recently. Thought I would present this issue to the crowd. I'm sure someone knows whats going on. Perhaps this is normal?
Symptom, Charging seems to be mostly OK at idle and can reach 14V just above idle, but as the revs rise the charging voltage drops into what I think is the poor range ~ 12.5V
Check out the video
https://youtu.be/GEc54fnPpYc
RichB in AZ
RichBinAZ is offline
post #2 of 33 (permalink) Old 02-22-2018, 08:22 PM
Main Motorcycle: 08 t100
Other Motorcycle: 08 Thruxton
Extra Motorcycle: 72 Norton comando
Looks like a Regulator/Rectifier problem. But before you buy a new one check connections at the R/R harness to frame harness for burns or loose fit, check all connections including battery cables. You may also want to check the alt. AC output, search how to do that on this forum or U tube.
BonnieBlack likes this.
rweb is online now
post #3 of 33 (permalink) Old 02-22-2018, 10:23 PM
Supernova
Forchetto's Avatar
Classic symptom of a failing rectifier/regulator.
BonnieBlack and RichBinAZ like this.
Forchetto is offline
post #4 of 33 (permalink) Old 02-22-2018, 10:59 PM
Main Motorcycle: '09 T100 EFi
lambroving's Avatar
Other Motorcycle: Monster 796 ABS "Pantah"
Extra Motorcycle: K100RS 16/ABS
Interestingly, your favorite RR155 on the Electrex site shows "catalog suspended"..., so I guess I'm screwed if mine ever packs it in...
'09 T-100 Forest Green / New England White, TORs, Intiminators & fork tubes raised 15mm, Chrome Ikon 7610 - SP8 Shocks, Custom Sargent Saddle, OEM Chrome Grab Rail, Conti Road Attack 2 EVO's 110/80VR19 & 150/70VR17, 7" Cibie lens and uprated H4 bulb.
lambroving is online now
post #5 of 33 (permalink) Old 02-23-2018, 11:54 AM Thread Starter
RichBinAZ's Avatar
Thank you - thought it looked suspicious - and explains why I was getting a flat battery even after running the bike.
In the threads i was looking at the yamaha seemed a favorite replacement, although the wiring could be a bit of a challenge.
OK, more searching. - 5 wire regulator rectifier
RichB in AZ
post #6 of 33 (permalink) Old 02-23-2018, 01:18 PM
Supernova
Forchetto's Avatar
Just looked, seems to be out of stock:
http://www.electrexworld.co.uk/acata...5.html#SID=439
post #7 of 33 (permalink) Old 02-23-2018, 02:01 PM
Main Motorcycle: 2013 Steve McQueen # 653
Other Motorcycle: Yamaha FZ6R
Try - roadstercycle.com - for your improved regulator needs in USA.
Tom
RichBinAZ likes this.
tdnathens is offline
post #8 of 33 (permalink) Old 02-23-2018, 02:13 PM Thread Starter
RichBinAZ's Avatar
Hmmmm.... Over $200 for genuine Triumph part that will fail again OR (amazon links below)...
https://www.amazon.com/Voltage-Regulator-RMSTATOR-Universal-Shindengen/dp/B01N7BPY4D/ref=sr_1_3_sspa?s=automotive&ie=UTF8&qid=1519410955&sr=1-3-spons&keywords=mosfet+voltage+regulator&psc=1Is 50Amps going to be enough? 350W/13V = 27A That should fry any battery or wire harness
https://www.amazon.com/Regulator-Rectifier-1998-2013-540-4-019-1A-540-4-027-1A/dp/B01MZXLRLW/ref=sr_1_6?s=automotive&ie=UTF8&qid=1519410955&sr=1-6&keywords=mosfet+voltage+regulator It has a name Triumph and Ducati attached to it, which makes it worth much more.
Now I have to consider if they are knock-offs or what???
I Imagine you just tie the extra reds together (bonnie black with red stripe wire) and blacks together (bonnie black with white stripe-ground) to get it back to 5 wires. Does it matter how the yellows are connected to the Triumph black wires?
Another fun project - still haven't finished the oil cooler lines yet (found some hose, but clamps I'm not happy yet)
RichB in AZ
post #9 of 33 (permalink) Old 02-23-2018, 02:37 PM
Main Motorcycle: '16 Bonneville T100 Black
justinlself's Avatar
Other Motorcycle: KLR650
What about http://bellacorse.com/shop/custom-pa...tor-rectifier/
Forchetto likes this.
2016 Triumph Bonneville T100 Black (2/18/17)
1997 KLR650 (5/28/14 - present)
2016 WI to AK trip NOMEAD
FB Motoblog: Eskimotorrad
justinlself is offline
post #10 of 33 (permalink) Old 02-23-2018, 07:42 PM
Legend
The one from Bella Corse is the one you want. Plug and play.
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes RC, no snorkel, inlet enlarged, 118/40/NBZT "Thruxton" needles/1 shim/3 turns, Ikon 7610s, Ricor Intiminators, Barnett green springs, Michelin Pilot Activs, D9 gauge panel, tachometer.
Baltobonneville is offline
Triumph T160 charging system confusion 2wheelride Classic, Vintage & Veteran 21 09-26-2016 11:44 PM
regulator/rectifier issues??? Enrique Cabrera Tiger 1050 - Mods & Workshop 14 04-14-2016 07:22 PM
2003 S3 Charging help needed Tobycatz Speed Triple Forum 21 02-18-2016 06:53 PM
Charging System Diagnostics - Rectifier/Regulator Upgrade DEcosse Speed Triple Forum 14 09-07-2015 07:52 PM
The Fallacy of Open-Circuit Voltage Mr.Pete Classic, Vintage & Veteran 34 04-27-2015 02:01 PM
