More iffy triumph connections - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 5Likes
  • 5 Post By Jonnys Bonnie
post #1 of 4 (permalink) Old 11-09-2017, 12:36 PM Thread Starter
Main Motorcycle: Bonneville T100. 2006
Other Motorcycle: Wifes car
Extra Motorcycle: Bus
Hi everyone.
A wiring issue, trace and fix that might help someone.
While cleaning and tinkering( I ride all year so lots of that needed) I noticed the clock lights weren't working. Mmmmm. Tried my default diagnostic technique- wiggling the wires No luck. Not surprising really !!. OK. check the fuse. AHA I thinks. New fuse fitted and we have lights, well, nearly. One is not working. So, a little while later after removing fly screen, headlight and clock cups I can get at the offending bulb. Its "blown". New bulb fitted and, oh, still not working. Now its time for the trusty Multi-Meter. I unplugged the connector in the head light bucket from the loom and checked for continuity on the wire. No luck. Broken wire or iffy connector I decide.
I start cutting carefully the loom, wiggle a few wires, and out comes this.
https://www.triumphrat.net/attachment...1&d=1510243971
More cutting and the spaghetti nightmare appears.
https://www.triumphrat.net/attachment...1&d=1510244433
I find the offending connection, cut the shrink wrap off and
https://www.triumphrat.net/attachment...1&d=1510244752
There's the problem. Rather corroded and a bit green.
I stripped the wires, practiced soldering as I've not done it for awhile, happy with the results so away I go. Picture of the finished solder joint ? Not a chance !! LOL. It didn't go very well and I was a bit disappointed. Very lumpy, plastic a bit over heated, but ok. Just.
Everything re-wrapped and put back together and good to go.
Hope it helps.
Jon
ID:	532226   Click image for larger version
ID:	532233   Click image for larger version
2006 Bonneville T100. Arrows 2-2. Airbox Baffle removed. K+N filter. TTP Bellmouth. TTP BlueFlame coils. TTP jetting kit. Crank case breather moved. 120 mains. 40 pilots. 3 Turns idle jet.
Jonnys Bonnie is offline
post #2 of 4 (permalink) Old 11-09-2017, 05:17 PM
Main Motorcycle: '02 Bonneville 100yr anv.
Back2-2's Avatar
Other Motorcycle: 2006 Honda 450X
Excellent trouble shooting !
Thanks for taking the time posting your pic'c and for sharing your problem and resolutions ! Helps all of us.
“Its all about motorbikes. Always has been, always will be”
Neil in the Black Hills
Back2-2 is offline
post #3 of 4 (permalink) Old 11-09-2017, 05:50 PM
Main Motorcycle: 2015 Bonneville Newchurch
Since you have that part of the loom open, I HIGHLY recommend you peel back a little further and solder the green/red wires. There are so many weak points in our loom, but to eliminate all of them, requires a complete tear out. If you ever wire in a RFID, you can tackle that at the time.
But for now, the green/red should be tackled.
Just my .02
CUP1967 is offline
post #4 of 4 (permalink) Old 11-13-2017, 01:21 PM Thread Starter
Thanks @Back2-2 , glad it was worth posting.
@CUP1967 . Yep you are right, there's quite a few iffy looking connections in that part of the loom!!
Jon
Coolant change and Fuel connections Oldmann Tiger Chat 10 08-04-2018 09:32 AM
T595 mystery connections MLW9110 Daytona Deliberations 9 04-16-2017 08:23 PM
Dielectic grease & Electrical Connections BasilM Thunderbird Cruiser Chat 9 04-26-2016 08:27 AM
Instrument connections & aftermarket Ade-955i Air Cooled Twins Technical Talk 7 08-09-2015 04:20 PM
Open hose connections on Idle Speed Housing Mpact Speed Triple Forum 0 06-18-2015 07:08 PM
