Carb Fuel leak...part number help needed - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
post #1 of 10 (permalink) Old 03-11-2017, 11:55 AM Thread Starter
Main Motorcycle: 2001 Bonneville T100
Scot66's Avatar
Other Motorcycle: 1998 Trophy 1200
Hello All! I've developed a serious fuel leak by the left carburetor on my 2001 Bonneville. It seems to be coming from the T-fitting/fuel crossover tube (the one that the fuel line attaches to) where it enters the carb. I am assuming that there is an O-ring on the end of the tube (there is a groove on the end of the tube indicating a place for an o-ring) but there is no illustration of it on the Triumph fiche (very frustrating!). I ordered a new replacement T-fitting in hopes that it would come as a complete assembly with new o-rings, as I couldn't come up with any other solution and of course the dealer couldn't help me since it wasn't shown on the fiche. Does anyone in here know what the part number would be for these and/or where I could find replacements? I've Googled every way that I can imagine and have yet to come up with anything. To say that this is annoying and frustrating is an understatement. I really want to get the bike back on the road soon.
Thans in advance!
Scot
"I was born lost and take no pleasure in being found" - John Steinbeck
Scot66 is offline
post #2 of 10 (permalink) Old 03-11-2017, 12:13 PM
Main Motorcycle: '02 Triumph Bonneville
LapinAgile's Avatar
Hermy's has the cross over pipe with what they call 'U' rings available, part #26. Here's the page:
http://www.triumphestore.com/a/Trium...64731-0-2.html
This is for an '02, but will be the same for an '01.
'02 Bonneville - AI removed, 152MJ's, 42's 1.5 turns out, Air Box Gone/Uni Filters, TPS removed/capped, NH Togas, Nology Coil, Hotwire plug wires, TTP SafeStart, TTP Firestarter, D9 Bracket, Pingel petcock, 19 tooth sprocket, Michelin Pilot Actives.
LapinAgile is offline
post #3 of 10 (permalink) Old 03-14-2017, 06:25 PM Thread Starter
Scot66's Avatar
Thanks for your reply!; However, the diameter of those "U-rings"(those are used on the upper T-fitting which is of a smaller diameter) are different than the ones used on the lower fuel T-fitting.
Thanks again!
Scot
Scot66 is offline
post #4 of 10 (permalink) Old 03-14-2017, 09:09 PM
Main Motorcycle: '07 Tiger1050
rode2rouen's Avatar
Other Motorcycle: "78 Kawasaki KZ750B
My local NAPA store has o-rings, in both metric and imperial sizes, in boxes of assorted sizes so you can buy onesies/twosies. Take your T fitting and get a couple of different sizes.
Rex
rode2rouen is offline
post #5 of 10 (permalink) Old 06-27-2017, 04:00 PM
Main Motorcycle: 2016 Street Triple
Other Motorcycle: 2003 Honda VT 600
Hi Scot - Any luck with the fuel T-connector? I just sprouted a similar leak on the right carb and am preparing for the carb dismount. Thanks!
jarway is offline
post #6 of 10 (permalink) Old 09-10-2017, 11:20 AM
Main Motorcycle: '05 T100
I had this issue after cleaning out my carbs. Separated the carbs and found the O-rings were pretty dried out and cracked. Don't know if the carb cleaner damaged them (seems unlikely given the small amount of cleaner) or it cleaned out some gunk that had been holding back the fuel for a while.
Tried some different sizes and went with AS568-010 (OD: 3/8 in.; ID: 1/4; CS: 1/16) on both sides. Working well so far, snug fit, no leaks.
Would love to know the actual spec sizes if anyone has them though.
TR100 is offline
post #7 of 10 (permalink) Old 09-12-2017, 12:13 AM
That was exactly it! Strangely though the side that leaked came off cleanly while the dried crumbled O-ring that I had to scrape off did not leak (yet). I bought replacements from the local dealer, but didn't measure before installing.
jarway is offline
post #8 of 10 (permalink) Old 05-10-2019, 12:53 AM
KitCloudkicker's Avatar
Did you need to remove the one of the butterfly valves in order to separate the carbs? I'm looking for the replacement screws.
KitCloudkicker is offline
post #9 of 10 (permalink) Old 09-11-2019, 06:51 PM
Main Motorcycle: 2014 Tiger 800XC
freeflynick's Avatar
Other Motorcycle: 2006 Thruxton
Extra Motorcycle: 2002 Daytona 955i
Did you figure this out? I need to get to the o-rings but not sure how to go about separating the carbs.....
freeflynick is offline
post #10 of 10 (permalink) Old 09-12-2019, 01:36 AM
I did not remove the butterflies. There is a bracket, the enricher slide (choke), and one or two central tubes with bolts, take those off to separate the two carb bodies. The T-connector with the o-rings will require some twisting and pulling to pop apart. It's been a while so I may have forgotten something. Just be careful of the enricher slide, there is a spring and bearing the can shoot out.
jarway is offline
FuelBot - Fuel Level & MPG Gauge DEcosse Speed Triple Forum 53 02-10-2018 02:11 PM
Part name or number LurchOnABike Sprint Forum 9 03-10-2016 07:55 PM
Confirm flyscreen part number RideFree Street Triple Forum 1 05-14-2015 03:24 PM
T509 ECM & Fuel Pump relays, Help needed. Jonny UK Speed Triple Forum 3 04-13-2015 10:23 AM
Engine missing / popping after EFI remap jdgullett Air Cooled Twins Technical Talk 55 03-31-2015 06:19 PM
