Barend mirrors Biltwell Tracker - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 6Likes
post #11 of 30 (permalink) Old 02-24-2017, 09:10 PM
Main Motorcycle: '07 Tiger1050
rode2rouen's Avatar
Other Motorcycle: "78 Kawasaki KZ750B
I get "frugal", but I want value for my $$$!
I've been running Napoleons for over 30 years.......$65-$70 a pair and they last as long as the bike.
Since I've retired, the ZooperCommuter is for sale.
Rex
rode2rouen is offline
post #12 of 30 (permalink) Old 02-24-2017, 11:12 PM Thread Starter
Main Motorcycle: '16 Bonneville T100 Black
justinlself's Avatar
Other Motorcycle: KLR650
I'm fairly certain I found a solution with this thick reinforced rubbery hose from the hardware store. I got two pieces for free, an inch or so. I split it and cut maybe 3/8ths off it, then wrapped it around just one metal expansion sleeve (the smallest one). Pushed it into the handlebar flush, tightened up the bolt. The entire assembly is impossible to pull out, requires force to rotate (which will endlessly "tighten"... However if rotating" lefty loosey", the bolt will eventually back out of the conical wedge nut. I don't see this being an issue while riding, but I'm sure loctite will really help. The hose is never coming out unless you use compressed air!
Sent from my Z963U using Tapatalk
2016 Triumph Bonneville T100 Black (2/18/17)
1997 KLR650 (5/28/14 - present)
2016 WI to AK trip NOMEAD
FB Motoblog: Eskimotorrad
justinlself is offline
post #13 of 30 (permalink) Old 02-26-2017, 10:52 AM
axe
Main Motorcycle: Bonneville 2013
Just cut a full length slot along the length of the larger insert. This slot should give you just enough space to squeeze the insert together making a smaller diameter. Should slide right in.
axe is offline
post #14 of 30 (permalink) Old 02-26-2017, 12:13 PM Thread Starter
That a good idea. I'll see how the hose works out for awhile first (it's really in there, flush with the bar)
post #15 of 30 (permalink) Old 03-20-2017, 08:22 PM Thread Starter
I did get the left mirror in fine but the right didn't wanna cooperate. I ended up losing the tapered expansion nut inside the bar, but...
I didn't see a way to remove the inner rubber hose inside the bar since the sleeve is inside it sooo I thought I'd try shimming the bolt with tape and tap the mirror assembly in.. ended up pushing the hose and sleeve an inch deeper. Fack! At this point, I'm either getting a new right side grip n(since this has a hole for mirror in it), or repeating the **** up on the other side and getting a different pair of barend mirrors.
post #16 of 30 (permalink) Old 03-22-2017, 12:14 PM
Main Motorcycle: 06 Triumph Bonneville
aka.jacen's Avatar
Other Motorcycle: Shovelhead project bike.
I had similar mirrors that I got to mount with a different 1 in adapter from bike master. also I wasn't pleased with how well those mirrors held their position so I got new mirrors and used a new way of adapting them to 1inch bars. Here's a post I created for it.
https://www.triumphrat.net/showthread.php?t=763754
Sent from my SM-G920V using Tapatalk
justinlself likes this.
2006 Bonneville with 08 T100 motor. 790 cams and igniter, Airbox delete, 140 mains, 42 pilot, Thruxton needles(1 shim), . Emgo reverse cones.
aka.jacen is offline
post #17 of 30 (permalink) Old 03-22-2017, 03:58 PM
Main Motorcycle: Bonneville T100. 2006
Other Motorcycle: Wifes car
Extra Motorcycle: Bus
Hi justinlself
I bought something similar from ebay, and had the same problem with 1" bars.
My solution was similar to yours. It was impossible to make them fit with the supplied fitting.
I had some ground anchor bolts which the supplied bolt would fit into, and then used a small section of car breather hose to make up the difference. Works a treat.
I know they are Chinese , but apart from the dodgy fitting the mirror parts and the bar end seem to be very good.I am very pleased with them for the price.
I wanted the Oberon ones that I had seen at the carol nash bike show, but couldn't justify the £100 price tag.
http://www.ebay.co.uk/itm/2322250550...%3AMEBIDX%3AIT
I see that they have changed the description now further down the page to 7/8ths
2006 Bonneville T100. Arrows 2-2. Airbox Baffle removed. K+N filter. TTP Bellmouth. TTP BlueFlame coils. TTP jetting kit. Crank case breather moved. 120 mains. 40 pilots. 3 Turns idle jet.
Jonnys Bonnie is online now
post #18 of 30 (permalink) Old 03-26-2017, 11:49 AM
Main Motorcycle: 2018 T120
MushyPeas's Avatar
Other Motorcycle: 2014 T100 Black
Extra Motorcycle: 2016 Africa Twin DCT
Rex
I have never seen bar end mirrors on a KLR. Interesting
MushyPeas is offline
post #19 of 30 (permalink) Old 03-26-2017, 12:05 PM
rode2rouen's Avatar
That's what the guy that bought it said.
He took it for a test ride and when he returned he said, "Now I get the mirrors!"
Rex
post #20 of 30 (permalink) Old 03-26-2017, 12:34 PM
MushyPeas's Avatar
Rex
Where I take my KLR bar end mirrors wouldn't last long. But for on road, I get it. I have them on my Scrambler.
Sent from my Pixel using Tapatalk
Napoleon B/E mirrors on 7/8" Biltwell Bars RaceDweeb Air Cooled Twins Technical Talk 5 08-14-2016 12:10 AM
Biltwell Tracker bars Bluepig Air Cooled Twins Talk 9 07-30-2015 05:00 PM
