Installation of TTP SafeStart - Triumph Forum: Triumph Rat Motorcycle Forums
 14Likes
post #1 of 21 (permalink) Old 02-02-2017, 10:51 AM Thread Starter
Main Motorcycle: '03 Bonneville T100
coachconnor's Avatar
Other Motorcycle: 74 Honda 450 long gone
The instructions are very good; however, are there any short cuts or tips you guys have come up with? I'm not sure this will be successful as I don't have a cheesy garage band to play buzzy rock in the background as I work. From every bike or car building program on TV or you tube I've seen, the sound track is crucial to any successful operation from changing oil to fabricating a superbike from tin cans and a lawnmower engine.
19t, BC Sleepers, 42 pilots, Thrux needles & springs, 135 mains, K&N, Dart screen, air box bafflectomy, Barnett greens, TEC shocks
Wonderous apparitions - provided by magicians. J Fogerty
coachconnor is offline
post #2 of 21 (permalink) Old 02-02-2017, 11:08 AM
Main Motorcycle: 2004 Thruxton
Other Motorcycle: 1954 BMW R25/3
Extra Motorcycle: 1971 CB350
It's really straightforward and works great if you follow Pieman's directions. Given that JB Weld is just an epoxy-based adhesive, it cannot be overstated how important it is to get all surfaces clean, clean, clean.
TIP: order a new clutch cover gasket before taking on the work. If you don't have any garage bands in your music collection, I think you need to question your choice of marques. FWIW, putting on some Iggy will suffice (and is preferred in some cases).
beemerrich is offline
post #3 of 21 (permalink) Old 02-02-2017, 11:24 AM
Main Motorcycle: Triumph Bonneville T100
Piercems3's Avatar
the directions that come with the kit are easy to follow. If you have an older model, watch for the oil breather tube and put in a new seal while you are in there since they can leak. The new gasket will be good to have, and be patient while cleaning everything. My only regret is that I didn't put in upgraded clutch springs and now I get to go back and do it again.
Also, don't forget the wavy washer!
Piercems3 is offline
post #4 of 21 (permalink) Old 02-02-2017, 11:30 AM
Main Motorcycle: 1068cc '05 Thruxton
H3CT1C's Avatar
Beemerrich is 100% correct - Iggy is quite good enough. Would recommend staying away from progressive or psychedelic rock, though... anything might happen.
Oh yeah. And cleanliness is next to Godliness. I fitted my SafeStart at engine rebuild so the surfaces were
* M E T I C U L O U S L Y *
clean. Use a can of brake cleaner and a whole bunch of lint-free rags.
~'05 Thruxton~Sport Evolution 1100cc~FCR 39mm~813 cams~shim-under-bucket~+1.5mm valves~45mm headers~Ignitech CDI~m-Lock~m-Unit~Acewell CA85~F3 Frankenfork~Hagon Nitros~Pretech caliper~520 chain~wide 17" rims~sticky rubber~
H3CT1C is offline
post #5 of 21 (permalink) Old 02-02-2017, 12:03 PM
Main Motorcycle: '02 Triumph Bonneville
LapinAgile's Avatar
I'm going to do this also soon + Barnett green springs.
But here's some Clean Bandit music to help you hurry through the job:
After listening to this, any other music or even a Harley will sound good...............
'02 Bonneville - AI removed, 152MJ's, 42's 1.5 turns out, Air Box Gone/Uni Filters, TPS removed/capped, NH Togas, Nology Coil, Hotwire plug wires, TTP SafeStart, TTP Firestarter, D9 Bracket, Pingel petcock, 19 tooth sprocket, Michelin Pilot Actives.
LapinAgile is online now
post #6 of 21 (permalink) Old 02-02-2017, 01:05 PM
Legend
The instructions are good. I'll add this:
It will be messy, no matter how careful you are. Equip yourself with clean rags or sturdy paper towels, cotton swabs, and a can of acetone.
Clean the area to be epoxied thoroughly with paper towels to remove all the oil, then clean thoroughly again with acetone. Don't take shortcuts or rush it. It should be pristine so that the epoxy will adhere as well as possible.
Test-fit the part to be sure that it fits and that you understand how it goes in.
After installation and before it sets, remove as much excess epoxy as you can get with your fingers or whatever works, then clean any area where it shouldn't be with acetone until all the epoxy is removed. I had to clean out the interior of the opening (where the idler shaft sits), because I'd managed to get epoxy in there. I also cleaned the face of that area where some epoxy oozed out.
Have one more look, then let it sit for 24-48 hours before installing the cover and refilling with oil.
This was the end result before I closed up. Note that the starter was out for a different reason and need not be removed to do this job.
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes RC, no snorkel, inlet enlarged, 118/40/NBZT needles/1 shim/3 turns, Ikon 7610s, Ricor Intiminators, Barnett green clutch springs, Michelin Pilot Activs, D9 gauge panel, tachometer.
Baltobonneville is offline
post #7 of 21 (permalink) Old 02-02-2017, 02:25 PM
Main Motorcycle: 2015 Triumph Thruxton
yrunvs's Avatar
Without some screaming obnoxious long haired good time rock and roll on the boom box I would strongly suggest that you not try this upgrade on your own!!
TTP Tune#3, NH Toga's.
I'm no Gynecologist but hey I'll take a look.
yrunvs is offline
post #8 of 21 (permalink) Old 02-02-2017, 04:48 PM Thread Starter
Brake cleaner and new cover gasket in hand. I'll get on this on Monday. Got a few other projects to wrap up then away we go.
post #9 of 21 (permalink) Old 02-02-2017, 05:29 PM
Originally Posted by LapinAgile View Post
But here's some Clean Bandit music to help you hurry through the job....
God that's awful.
post #10 of 21 (permalink) Old 02-02-2017, 09:37 PM
Main Motorcycle: 04 T100 blue/white (his)
Wooly's Avatar
Other Motorcycle: 07 T100 red/black (hers)
Extra Motorcycle: 1971 Yamaha DT2 250
While you have it apart, it is also an opportunity to replace some of the shaft seals.
I replaced the gearbox shifter seal and also the small seal at the top of the clutch release arm.
These were easily obtained from a bearing supply shop for a couple of dollars.
Also replaced the O ring on the breather tube that exits the crankcase as the old one looked to be flattening a bit.
Have fun, it's quite an easy job.
Phil.
Wooly is offline
A non-mechanically inclined guy's rave about TTP Tune #3 JCinPA Air Cooled Twins Technical Talk 6 10-24-2016 09:02 PM
FuelBot2.0 Installation on D600 andrewed1 Triumph SuperSports 6 08-22-2016 06:58 PM
DIY Arrow 2-1 Installation on Scrambler RamesesThe2nd Air Cooled Twins Technical Talk 8 03-24-2016 08:09 PM
Scrambler w/mods, tune from TTP? MyFingID Air Cooled Twins Technical Talk 3 06-28-2015 06:53 AM
Review about TTP Inline Air Cooled Twins Talk 22 06-15-2015 04:11 PM
