Correct Oil Filter? - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 10Likes
post #21 of 47 (permalink) Old 01-26-2017, 10:56 AM
Legend
I don't need tools to get my oil filter off, although I might in the future if the arthritis in my right hand gets worse.
For a few years the Purolator Pure One premium filter had a rough-textured paint on it, great for getting a grip. They were an ugly mustard color but some leftover spray paint took care of that in a few minutes. Unfortunately, the textured paint is gone, and they are now one of the brands with a convex face plate that is unusable on these bikes.
maydaymike likes this.
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes RC, no snorkel, inlet enlarged, 118/40/NBZT needles/1 shim/3 turns, Ikon 7610s, Ricor Intiminators, Barnett green clutch springs, Michelin Pilot Activs, D9 gauge panel, tachometer.
Baltobonneville is offline
post #22 of 47 (permalink) Old 01-26-2017, 01:04 PM
Main Motorcycle: 2012 Scrambler
Luxlamf's Avatar
Other Motorcycle: 2002 VROD
Originally Posted by MushyPeas View Post
Wix makes an excellent filter, but if you go with Wix definitely opt for the shorter one.
Wix 51356 - Diameter = 2.685 Length = 3.402
Wix 51358 - Diameter = 2.685 Length = 2.782
WIX does make a great filter, they are the ones who make to OEM filters now apparently as the old ones where Filtech. Never really know the reasons behind a giant Corp changing a vendor out on something such as this after many years, most would assume it's due to financial reasons especially since they still fit the new water cooled bikes).
and the WIX filter you mention above is only $10 on Amazon so that would be a no brainer for me, Cheaper than the dealer and delivered to the house for free? I usually do not go for other brands but since WIX is the manufacturer of the OEM I dont need the $5 Trumpet logo on the outside.
https://www.amazon.com/WIX-Filters-5.../dp/B000C9WL6A
gunny_hiway likes this.
Luxlamf is offline
post #23 of 47 (permalink) Old 01-26-2017, 03:36 PM
Main Motorcycle: Bonneville T100. 2006
Other Motorcycle: Wifes car
Extra Motorcycle: Bus
Red face
I use a strip of sand paper to hold the filter. Gives enough grip to get it moving easy enough. Although I do my own servicing so its not done up over tight anyway. Give it a try.
Baltobonneville likes this.
2006 Bonneville T100. Arrows 2-2. Airbox Baffle removed. K+N filter. TTP Bellmouth. TTP BlueFlame coils. TTP jetting kit. Crank case breather moved. 120 mains. 40 pilots. 3 Turns idle jet.
Jonnys Bonnie is offline
post #24 of 47 (permalink) Old 01-26-2017, 04:09 PM
Main Motorcycle: 2015 Triumph Thruxton
yrunvs's Avatar
I do all my own service I use Microgard oil filters from O'rielly's and I have never used an oil wrench, hand tighten on and bare hand off- never had a leaky filter.
TTP Tune#3, NH Toga's.
I'm no Gynecologist but hey I'll take a look.
yrunvs is online now
post #25 of 47 (permalink) Old 01-26-2017, 04:26 PM
Main Motorcycle: 2018 T120
MushyPeas's Avatar
Other Motorcycle: 2014 T100 Black
Extra Motorcycle: 2016 Africa Twin DCT
Microgard is private label manufactured by Wix. My brother-in-law is a recently retired executive at O'Reilly's. He started with O'Reilly back in 1983, when they had something like 20 stores. He's the one who turned me onto Wix filters a long time ago. It was great having him in the business. If I ever had a question about a brand, he could give me all kinds of background info.
MushyPeas is offline
post #26 of 47 (permalink) Old 01-26-2017, 04:30 PM
MushyPeas's Avatar
P.S. No, I am not a Wix employee, commissioned salesman, or fanboy. But I have used a lot of filters in my life and Wix impresses the heck out of me.
The Triumph OEM filter is now produced by Filtron, a Wix affilate in Poland.
If you can find a better filter for $10.......Buy it.
post #27 of 47 (permalink) Old 01-26-2017, 04:38 PM
yrunvs's Avatar
Microgard is as good as Wix (maybe the same with a different name) at a third of the price with the exact same filtering properties...20 microns. Here' the one you want.
MGL51358
post #28 of 47 (permalink) Old 01-26-2017, 04:40 PM Thread Starter
g0bgb's Avatar
Originally Posted by Paul49 View Post
The Triumph OE filters changed size back in 2005 from 68mm to 65mm, I remember this 'cos I had only recently bought the Triumph filter tool at £12, then a few months later I had to buy the smaller filter tool. The 65mm fitted all models just the same. I use Mahle OC575, not 'cos they're cheaper but 'cos imo they're a good filter.
Thanks Paul49 I thought i was going insane Triumph did change them, Had to resort to brute force to get the old one off, large srewdriver and hammer and it was the smaller 65mm one proper triumph , replaced it with Hiflofiltro HF 191,68mm either size fits, and i do object to Triumph charging more than double for its filters just cos its got Triumph printed on the side who's gona see it hidden under your engine, dont know who makes the Triumph one but I bet they are less than half the price, anyway all this was because I was fitting the TTP Safe Start idler boss reinforcement, but you drop all the oil out when you take that clutch cover off, but all done now
Thanks for everyones help
MIKE
Paul49 likes this.
2004 790cc BONNY RED,Tec 2-2 with baffles cut off , UNI filter, snorkel removed, jenks Velocity Stack,
125 / 40 Jets, Standard NAGB Needles, No Shims, Pilot screws 2.5 turns out, AI removed, Pieman stage 1 Mods with 8200 rev Limit
g0bgb is offline
post #29 of 47 (permalink) Old 01-26-2017, 05:05 PM
MushyPeas's Avatar
MGL51358
See post #25
It is the same filter. Buy whichever one is cheaper.
post #30 of 47 (permalink) Old 01-26-2017, 05:48 PM
Luxlamf's Avatar
All you "Hand Tighteners" out there obviously do not have bikes where the filter is buried and sideways....
Luxlamf is offline
What's that little wire next to the oil filter? Bonneville63 Air Cooled Twins Technical Talk 2 10-14-2016 01:53 PM
New Part # for Oil Filter fuzzyfrank Air Cooled Twins Technical Talk 15 04-11-2015 08:20 PM
multiple punch marks on crankshaft - this a problem? jonkster Classic, Vintage & Veteran 186 03-12-2015 09:00 PM
Nightmare Oil Change jalalski Sprint Forum 17 02-24-2015 08:51 PM
Trailer bike? Check oil filter! Rollinslow84 Sprint Forum 2 02-19-2015 09:27 AM
