Spray Paint and Clear Coats - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
post #11 of 15 (permalink) Old 03-08-2008, 12:12 PM Thread Starter
Main Motorcycle: 2007 Bonneville
Powder Coating is out of the question because there are 2 small dents that i had to bondo.
I guess i'll hit it with a 1500grit, then 2 more quick coats of high gloss black.
Let it cure and buff the **** out of it with mothers 3 step.
If that doesnt work, then i'll bust out the clear coat and give it a try.
A pile of stock parts from a 2005 Bonnie Black, 1969 Trident, and a 1959 Panhead.
SCL18 is offline
post #12 of 15 (permalink) Old 03-10-2008, 01:27 AM
Supernova
Main Motorcycle: Speed Triple
Catenaccio's Avatar
Other Motorcycle: CBR1100XX
Extra Motorcycle: Piaggio MP3
Here's a decent link explaining some of the finer steps in creating perfect paint finishes...
http://www.customclassictrucks.com/h...obs/index.html
Catenaccio is offline
post #13 of 15 (permalink) Old 03-10-2008, 11:27 AM Thread Starter
There are so many ridges on this headlight bucket that is is **** near impossible to wet sand w/1500 grit and not get to bare metal in a just a few passes.
I've decided to just let it cure, hit it with mothers 1-3 and hope for the best.
Is 4 days enough for the paint to cure (inside my apartment at 65-75 degrees and hardley any humidity)?
SCL18 is offline
post #14 of 15 (permalink) Old 03-10-2008, 12:01 PM
Legend
Main Motorcycle: Kawasaki Versys 1000 LT
sweatmachine's Avatar
Other Motorcycle: ex 904cc Bonnie beast
I think you'll be ok, just be careful handling the painted parts, and especially when installing. Spray paint seems to take weeks to harden up.
sweatmachine is offline
post #15 of 15 (permalink) Old 03-10-2008, 12:36 PM
Main Motorcycle: a great one
I've had good luck combining the sprays, i.e., Clear Coat AND Gloss Black at the same time.
Note that I've only done this on smaller projects - brackets, side covers, frame, etc. I've never tried a rattle can job on a tank.
I HAVE painted whole cars and trucks, but that's for a different story, and does not apply here. We're talking about rattle cans for this thread!
Major Disclaimer: Try this on an experimental Project first!!!
First you give the project a few VERY thin mist coats of the black, wait a few minutes for it to get tacky...
Then have one spray can in each hand, alternate between Black and Clear, ending with more clear being sprayed than black.
Pause every 20 seconds or so, and let it dry a little to get tacky. 5 or six thin coats, after letting each successive one tack up, is much better than 1 or 2 thick coats.
Always wet sand with some type of backing, rubber pad, foam rubber, etc. Your fingers or palm make a bad backing.
"Color Sanding" is wet sanding very carefully with 1500 to 2000 grit paper, checking your work constantly, the idea being to achieve a mirror smooth finish - no orange peel, runs, high/low spots. This is followed by polishing with compound, swirl remover and glaze polish. Stay away from corners and sharp edges, as these areas tend to hold thinner amounts of paint.
The result will be a foot deep, see yourself good enough to shave by, shiny. Again, practice on something unimportant, as it does take a little practice. Worst case? Strip it down and try again. Not the end of the world.
"Those who are defensive do not understand;
those who understand are not defensive."
(Lao Tzu)
"Knowledge without Mileage equals bull - sh!t" (Henry Rollins)
Gob-ny-geay is offline
TT Silver Spray paint for seat cowl hammer784 Triumph SuperSports 13 01-28-2008 04:11 PM
Spray paint can had my name again NewOldSkool Air Cooled Twins Technical Talk 13 10-05-2007 02:38 AM
Paint spray Ninjaboy Triumph SuperSports 1 05-19-2007 09:24 AM
Color-matched Spray Paint meinschaft Maintenance & Workshop Talk 4 11-16-2006 03:40 PM
Lucifer orange spray paint jackn Tiger Chat 11 03-18-2005 03:21 AM
