Gallery plug leak - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #1 of 24 (permalink) Old 04-20-2016, 02:03 PM Thread Starter
Gallery plug leak
I need to stop cleaning my bike. Last time, I knocked off the rubber cover on the oil cooler wiring because it had dried up and cracked.
Cleaning her up last night, I noticed oily spots on the front of the engine below the starter. Quick research here points to the gallery plugs. I can see one, centered in the engine over the starter. Is there another plug?
Thanks!
Gone in 60 is offline
post #2 of 24 (permalink) Old 04-20-2016, 02:42 PM
Supernova
Forchetto's Avatar
There are four in all. Two of them are inside the engine cases and invisible, and another two are below the starter motor. We've had a thread about them a few days ago, see post 5 which also has a link to a more thorough description by me and lots of useful advice from other members:
https://www.triumphrat.net/air-cooled...last-week.html
Forchetto is offline
post #3 of 24 (permalink) Old 04-20-2016, 05:24 PM Thread Starter
Thank you very much! Looks like an easy project. Not quite like splitting my BMW in two to fix a rear main seal leak.
post #4 of 24 (permalink) Old 04-21-2016, 09:27 AM
Main Motorcycle: '02 Bonneville 100yr anv.
Back2-2's Avatar
Other Motorcycle: 2006 Honda 450X
It really is pretty easy and once you have done it you will be glad you took the time to fix them. I am real fussy about leaks. As posted go by Forchetto - read the postings a few days ago and you will have the job covered with no problems.
“Its all about motorbikes. Always has been, always will be”
Neil in AZ
Back2-2 is online now
post #5 of 24 (permalink) Old 04-21-2016, 04:16 PM
Legend
The fix is easy. The access is difficult.
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes RC, no snorkel, inlet enlarged, 118/40/NBZT needles/1 shim/3 turns, Ikon 7610s, Ricor Intiminators, Barnett green clutch springs, Michelin Pilot Activs, D9 gauge panel, tachometer.
Baltobonneville is online now
post #6 of 24 (permalink) Old 04-21-2016, 04:58 PM Thread Starter
Question, I couldn't tell from the previous posts. There's the one countersunk plug visible above the starter, with two button-head hex screws pointing upward on either side of it. Are those plugs as well? They don't appear to be leaking. Are the other plugs visible once the starter is out of the way?
Almost looks like the big one in the middle could be accessed with a large Allen wrench without removing anything, but with little leverage space.
post #7 of 24 (permalink) Old 04-22-2016, 01:44 PM Thread Starter
Well, I answered my own question once the starter was loose, and I saw the second plug. Challenging to get to, but with extensions and u-joints was able to get to them over and under the starter. Wrapped them with Teflon tape and reinstalled.
Interesting that taking a closer look, oil looked like it was sweating out along the joint between the oil pan and block, and those screws were a bit on the loose side. Snugged them up as well.
I'll pick up some oil over the weekend, fill it up and keep my fingers crossed.
Thanks for your help, guys!
post #8 of 24 (permalink) Old 04-22-2016, 01:58 PM
Supernova
Forchetto's Avatar
Funny how often we get loose or even missing screws from the sump plate, I wouldn't have thought that particular area was prone to any more vibration or stress as anywhere else in the engine and there are 11 bolts altogether in there. Worth checking at every oil/filter change, I think. Torque is 12Nm (8.8 Ft/lbs).
Last thread with a missing bolt in there just a week ago:
https://www.triumphrat.net/air-cooled...sump-bolt.html
post #9 of 24 (permalink) Old 04-22-2016, 03:54 PM
Main Motorcycle: 2014 Silver Bonneville
Other Motorcycle: Looking for older project
Perhaps from the gasket compressing over time? I did my clutch springs in the fall and the clutch cover bolts had almost no torque when I removed them. I retorqued all the cover bolts, never thought about checking the sump though. I had to do my gallery plugs last fall as well.
Lins is offline
post #10 of 24 (permalink) Old 04-22-2016, 04:08 PM
Supernova
Forchetto's Avatar
Good point, that's likely the reason. Car manufacturers are abandoning gaskets in lots of engine joints nowadays. Just looking under a new car you'll see bright orange silicone gasket paste oozing out of lots of joints.
There's another advantage to the makers in that the gasket compound can be applied by robots, no stockage or lining up of complex solid gaskets or anything.
Oil gallery plugs (Dull and boring) Forchetto Air Cooled Twins Technical Talk 29 09-23-2018 08:18 PM
Did my gallery plugs last week... geof33 Air Cooled Twins Technical Talk 6 04-15-2016 01:06 PM
Oil drain plug crush washer issue foxj Air Cooled Twins Technical Talk 31 01-05-2016 11:06 AM
Rusty Spark Plug Broadsman Hinckley Classic Triples 4 12-19-2015 03:01 AM
Oil leak - 14' with <3000 miles david CU Street Triple Forum 11 07-12-2015 07:50 PM
