Gallery plug leak - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #11 of 24 (permalink) Old 04-23-2016, 11:14 AM
Main Motorcycle: 2015 Thruxton//2005 Savag
Yup I work parts for a dealer and ready-made gaskets are a thing of the past. Techs use black or red silicone depending on application.
CheatPete is offline
post #12 of 24 (permalink) Old 04-23-2016, 02:27 PM
Main Motorcycle: '09 T100 EFi
lambroving's Avatar
Other Motorcycle: Monster 796 ABS "Pantah"
Extra Motorcycle: K100RS 16/ABS
Permatex "The Right Stuff" no doubt. Used in the auto industry for sump reseals, etc. for 20+ years...
'09 T-100 Forest Green / New England White, TORs, Intiminators & fork tubes raised 15mm, Chrome Ikon 7610 - SP8 Shocks, Custom Sargent Saddle, OEM Chrome Grab Rail, Conti Road Attack 2 EVO's 110/80VR19 & 150/70VR17, 7" Cibie lens and uprated H4 bulb.
lambroving is online now
post #13 of 24 (permalink) Old 04-26-2016, 07:26 PM Thread Starter
Well, finally got some time to clean up all of the oil on my bike and refill the oil. Went for a test ride, and am still seeing oil streaks under the engine. I think it may be the oil line going in next to the drain plug.
I imagine I need to remove and reseal the fitting that goes into the oil sump. Teflon tape ok for this? Thanks
Gone in 60 is offline
post #14 of 24 (permalink) Old 04-26-2016, 08:28 PM
Main Motorcycle: '02 Bonneville 100yr anv.
Back2-2's Avatar
Other Motorcycle: 2006 Honda 450X
For the oil line itself - That is an O-ring seal for the B-nut to the fitting mating surface. I suspect the fitting is then threaded into the engine case and would have a sealant.
“Its all about motorbikes. Always has been, always will be”
Neil in AZ
Back2-2 is online now
post #15 of 24 (permalink) Old 04-27-2016, 11:23 AM Thread Starter
Yes, that fitting looks like it's held with sealant. For anyone who has had to remove and reseal it, does tape work?
Gave everything a final snug, and am hoping that might have helped.
post #16 of 24 (permalink) Old 04-27-2016, 12:55 PM
Supernova
Forchetto's Avatar
No sealant specified in service manual, just an "O" ring and tighten to 15Nm.
Forchetto is offline
post #17 of 24 (permalink) Old 04-27-2016, 03:02 PM Thread Starter
Thanks, Forchetto. That would apply for the cooler line going into the fitting. I'm wondering about where the fitting screws into the sump. There's residue of the same type of glue sealant that is used on the gallery plugs. Not sure if anyone has had to remove and reseal the fitting.
post #18 of 24 (permalink) Old 04-27-2016, 03:14 PM
Supernova
Forchetto's Avatar
All the manual says is to renew the copper washer and tighten to 45NM. They call that fitting an "adapter". The washer is described as
Part number T3550905 - WASHER. M18X21.9 OD. COPPER
post #19 of 24 (permalink) Old 04-27-2016, 04:49 PM Thread Starter
Got it, there must be a washer behind it where it mates to the sump.
Thank you sir!
post #20 of 24 (permalink) Old 04-27-2016, 06:08 PM Thread Starter
Guess I could have looked at the parts list for the cooler online...
Oil gallery plugs (Dull and boring) Forchetto Air Cooled Twins Technical Talk 29 09-23-2018 08:18 PM
Did my gallery plugs last week... geof33 Air Cooled Twins Technical Talk 6 04-15-2016 01:06 PM
Oil drain plug crush washer issue foxj Air Cooled Twins Technical Talk 31 01-05-2016 11:06 AM
Rusty Spark Plug Broadsman Hinckley Classic Triples 4 12-19-2015 03:01 AM
Oil leak - 14' with <3000 miles david CU Street Triple Forum 11 07-12-2015 07:50 PM
