Rubber boot over oil temp sensor on cooler - Triumph Forum: Triumph Rat Motorcycle Forums
 4Likes
post #1 of 11 (permalink) Old 03-31-2016, 05:57 PM Thread Starter
Hi all,
Detailing my '12 T100 last night after catching some rain on the way home from work. Going over the bike, I knocked off a rubber boot that fits over the oil fitting going into the top of the cooler on the left side of the bike. The boot covers the top of the sensor and the wires coming out of it. Being very thin rubber, it looks like it was a bit dried up and starting to crack.
I can't find the part on the fiche for any part of the bike. The cooler, lines, banjo bolts, etc are listed, but the rubber boot isn't shown or listed. Calling the local dealer, he searched on his end, and can't find that part as being available. He's going to check with the service department and call me back.
Anyone with a late model T100, do you guys have this boot on your bike? I'm curious to see if anyone else's is missing, or if anyone has tried to hunt one down. Thanks!
Lone Commuter of the Apocalypse
2012 Bonneville T100
2013 Honda CB1100
Gone in 60 is offline
post #2 of 11 (permalink) Old 03-31-2016, 06:59 PM
Main Motorcycle: Bonneville T100 SMQ SE
Tornado99's Avatar
Other Motorcycle: 1974 Norton Commando 850
Mine was still present (2013 T100) but barely when I acquired the bike 1 year ago. It has since disintegrated and crumbled away. I have been riding without it for 6+ months now. Been thinking about adding something to provide strain relief to the wires...a bead of black silicone sealant should do but would need to be a neat application in that high-viz area. Other idea is to use rubberized "rigging" tape...also know as "Plumbers Tape"...it's self-amalgomating and it pretty decent in exposed areas.
2013 T100 Steve McQueen; +NH Togas; -SAI; -O2; +Breathe; +TTP#3; +Avon RoadRiders; +Iron&Resin Sidebag; +Kisan Auto-Off Indicators & BrakeLight Flasher; +MatchlessClueless LED Brake & Indicators; +LED 3000 Lumens Headlamp; +DeCosse Keyless system
Tornado99 is online now
post #3 of 11 (permalink) Old 03-31-2016, 07:30 PM Thread Starter
So I'm not alone. The part seems to be unobtainium. The dealer I.D.d the part by looking at a new bike in the showroom but it's not available for sale apparently. They're calling Triumph to see if one can be obtained. Not going to cry if I can't replace it. Wonder if some heat shrink would be an option.
post #4 of 11 (permalink) Old 03-31-2016, 07:46 PM
Main Motorcycle: '09 T100 EFi
lambroving's Avatar
Other Motorcycle: Monster 796 ABS "Pantah"
Extra Motorcycle: K100RS 16/ABS
Maybe it comes with the lead for the oil temperature switch? #T2500347
'09 T-100 Forest Green / New England White, TORs, Intiminators & fork tubes raised 15mm, Chrome Ikon 7610 - SP8 Shocks, Custom Sargent Saddle, OEM Chrome Grab Rail, Conti Road Attack 2 EVO's 110/80VR19 & 150/70VR17, 7" Cibie lens and uprated H4 bulb.
lambroving is online now
post #5 of 11 (permalink) Old 03-31-2016, 07:59 PM
Main Motorcycle: 2006 T100
endoscopy's Avatar
Other Motorcycle: 1969 TR6R
Give the boot the boot
That's a good idea. The rubber boot there, and on the oil pressure switch are worthless, and only serve to hold moisture. They are really not needed except to keep the wires from flapping around, and provide some glamour.
Another method would be to get some heat shrink around the wire/s to tidy it up and actually give some strain relief.
Charles
endoscopy is offline
post #6 of 11 (permalink) Old 03-31-2016, 09:56 PM
Tornado99's Avatar
Charles
Not sure where the connector end of the oil temp sensor lives...might be a pain to get at it inorder to place a heat shrink tube over it and slide down the wires to the temp sensor end.
I'll wait for enlightenment on that .....
post #7 of 11 (permalink) Old 03-31-2016, 10:08 PM Thread Starter
Well, fixed... since I work for a company that makes electronic components, and have access to some very nice heat shrink in all sizes, after hours I removed the sensor, slid a piece of heat shrink over it, screwed the sensor back in, and shrunk it over the sensor, bending the long end 90 degrees over so it pretty much looks like the original piece, and seals much better to the sensor, so no moisture would be able to get in. Quick and easy fix.
endoscopy and brit-twinrider like this.
2013 Honda CB1100
post #8 of 11 (permalink) Old 03-31-2016, 10:20 PM
Main Motorcycle: 2015 Bonnie T100
DennisD's Avatar
Other Motorcycle: FS: 2014 Triumph TrophySE
Extra Motorcycle: 2014 Honda CB1100E
Send a message via Yahoo to DennisD
Subscribe
Glad to be here with so many other Triumph enthusiasts!
DennisD is offline
post #9 of 11 (permalink) Old 04-01-2016, 01:37 AM
Tornado99's Avatar
Is there a crush washer under the sensor? Should be replaced if sensor is removed...I know the banjo fittings on the oil cooler hoses will leak unless the crush washers are renewed at each removal.
post #10 of 11 (permalink) Old 04-01-2016, 01:37 PM Thread Starter
Yes, good point. I have a pretty good collection of crush washers and had one the same size.
t120 oil not returning - rebuilt engine oskar866 Classic, Vintage & Veteran 29 03-31-2016 04:33 AM
A few newb questions: Mr.Dudecool Classic, Vintage & Veteran 17 08-13-2015 02:34 AM
Fumoto quick oil drain valve (Long & Boring) Forchetto Air Cooled Twins Technical Talk 36 05-02-2015 09:49 PM
Oil temp in OIF bikes. TR7RVMan Classic, Vintage & Veteran 20 04-22-2015 02:41 PM
Little Rubber Thingie-me-widget top of Oil Cooler Sensor... Tornado99 Air Cooled Twins Technical Talk 8 04-15-2015 02:21 PM
