Carburetor leaking fuel - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 2Likes
  • 1 Post By pdennison87
  • 1 Post By mick 85
post #1 of 10 (permalink) Old 02-20-2016, 06:25 PM Thread Starter
Main Motorcycle: 2007 Triumph Bonneville
pdennison87's Avatar
As some of you who have read my other posts know, I laid my bike down a while ago and I am getting into the repairs.
I didn't fire my bike up for a while, so I was letting it idle to recharge the battery. I stepped away for a few minutes, and when I came back there was a considerable amount of fuel on the ground. I shut the bike off and wasn't able to identify exactly where the leak(s) came from. It's hard to judge how much fuel was lost, the stain on the concrete was about 1 foot by 2.5 feet. Maybe half a quart at most?
Part of the damage in the crash was a bent outrigger (footpeg/clevis mounting bracket), which has the fuel tank breather tube and carburetor breather tube clipped into it. To keep those tubes away from the exhaust, I had them tucked into the frame facing upwards (rather than downwards, which is their normal position). When I untucked them, maybe a 1/4 ounce of fuel poured out of them.
Here is my dilemma. In order to find out where the fuel was leaking I need to fire the bike up. However, I have read that if the carburetor is leaking fuel, its possible that fuel has mixed in with my oil. Obviously I do not want to run the bike if that has happened.
Is there a way to get some oil on my finger to smell it to see if it smells of gas? Forgive me if this is a stupid question, but it seems like removing the oil drain bolt is the only way to actually get at the oil, and I don't want to drain it. I tried removing the oil filler cap and sniffing, but it smells too much like fuel around the bike in general to tell.
What would you guys do in this circumstance?
Thanks for the continuing help, this community has already been a huge help on some of the other problems I am dealing with since the crash.
- Paul
Paul
pdennison87 is offline
post #2 of 10 (permalink) Old 02-20-2016, 07:11 PM
Main Motorcycle: 03 T100
mikeinva's Avatar
put a long screw driver down the oil fill hole. allso with the vent lines faceing down turn fuel back on if no fuel runs out of the vent tubes the carbs should be ok
mikeinva is offline
post #3 of 10 (permalink) Old 02-21-2016, 10:34 AM
Main Motorcycle: '02 Bonneville 100yr anv.
Back2-2's Avatar
Other Motorcycle: 2006 Honda 450X
Be certain that the breather hose coming off the "T" connector between the two carb bodies is not plugged or pinched. It should be facing down as to not hold any fuel trapped in it from the crash. If that vent tube is plugged you will have fuel flooding back into the air box and out any and all places possible.
I doubt you have fuel in the oil, I suspect it is either a stuck float or pitched vent or plugged vent tube causing the over flow of fuel.
Hope that makes a little sense and can possibly help.
“Its all about motorbikes. Always has been, always will be”
Neil in the Black Hills
Back2-2 is offline
post #4 of 10 (permalink) Old 02-21-2016, 01:41 PM Thread Starter
Thank you gentlemen, I'll let you know how it goes
Paul
post #5 of 10 (permalink) Old 02-22-2016, 10:37 AM
Main Motorcycle: 203 T100
Other Motorcycle: 1968 Truimph Daytona
Extra Motorcycle: 2006 Ducati Multistrada
"I suspect it is either a stuck float or pitched vent or plugged vent tube causing the over flow of fuel."
These would be my guesses, too. I'd check the floats first.
Hard work may pay off some day, but laziness always pays off right now.
Bill
View my photo album
billstokes is offline
post #6 of 10 (permalink) Old 02-22-2016, 10:52 AM
Main Motorcycle: TT140
Float Drop = This shows me flow I turn the petcock onto prime (if vacuum assist)
Float Level = This shows me how close I am to shutting the fuel off or I look at the float line and carb line is horizontal and off.
Float UP = This closes the float needle and no leak should occur or I have debris between needle and seat.
As stated, I push a thin long something down into the crankcase level, pull the implement out and the oil should act like water and drip oil like it's going out of style, not one big blob hanging on the tip. Make sense gas thinning out the oil?
TT140 is offline
post #7 of 10 (permalink) Old 02-23-2016, 11:37 PM Thread Starter
Thanks, TT140 and others, we got a big snow dump, just waiting for some better weather to get into it.
TT140 likes this.
Paul
post #8 of 10 (permalink) Old 02-23-2016, 11:54 PM
Main Motorcycle: 2007 BMW Dakar
Other Motorcycle: 1982 Yamaha XT550
Extra Motorcycle: 2010 Triumph Thruxton
My '82 Yamaha XT550 has dual carbs that spit gas out of the carbs if I don't treat it right.
It's usually a needle and seat issue fixed with a good cleaning (a good cleaning!) and when I had the parts handy, the replacement of the needle and seat. One year the tang on my floats needed adjustment but in my case when my carbs leak it just needs a cleaning.
I think it's time you got to know your carburetor.
Google cleaning and replacing a needle and seat on a motorcycle carburetor.
Buy needle and seat spares. I'd buy new floats as well. What the hell, buy a refresh kit for your carb that includes new gaskets.
Then take the carb off your bike, take it apart and fix it. (look on youtube for advice) It's fun.
When you put it back on your bike and it fires up and doesn't leak anymore you'll feel like a million bucks.
Good luck!
futura is offline
post #9 of 10 (permalink) Old 09-19-2019, 11:30 AM
The carburetor is the main mechanical part of the bike and it should be clean. I got some nice information at https://happywrench.com/2019/08/05/clean-carburetor/ for keeping carburetor in better condition.
jit78898 is offline
post #10 of 10 (permalink) Old 09-19-2019, 01:27 PM
Main Motorcycle: Triumph Bonneville SE
mick 85's Avatar
Or the engine, or the gearbox, or the clutch ?
Baltobonneville likes this.
Born to be mild
mick 85 is offline
Fuel in airbox – tested all usual suspects MarkLondon99 Air Cooled Twins Technical Talk 34 05-30-2016 11:05 AM
Fuel Gauge Retrofit '02-'06 Daytona 955i strych9 Daytona Deliberations 7 10-19-2015 02:06 PM
TT600, acts like it's running out of fuel earlier and earlier urbex Triumph SuperSports 5 10-15-2015 11:58 AM
Potential fuel pump plate issue.... Captain Bob Daytona Deliberations 3 04-22-2015 09:29 AM
