progressive front fork springs any recomendations - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 11Likes
post #1 of 43 (permalink) Old 02-13-2016, 10:27 AM Thread Starter
Main Motorcycle: harley davidson road king
jackass dave's Avatar
Other Motorcycle: 2006 triumph scrambler
i know once again its not the most taxing or technical question but trawling the internet for progressive fork springs there seem to be about 6-8 options .
can any one recomend something they have fitted or currently use ,its for a scrambler model
jackass dave is offline
post #2 of 43 (permalink) Old 02-13-2016, 11:44 AM
Legend
Stock springs, 5W oil, Ricor Intiminators. With this, I get very little brake dive.
I didn't like the progressive springs. All they are is stiffer springs.
RichBinAZ likes this.
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes RC, no snorkel, inlet enlarged, 118/40/NBZT needles/1 shim/3 turns, Ikon 7610s, Ricor Intiminators, Barnett green clutch springs, Michelin Pilot Activs, D9 gauge panel, tachometer.
Baltobonneville is online now
post #3 of 43 (permalink) Old 02-13-2016, 01:17 PM
Main Motorcycle: T100
Allroads's Avatar
I ended up installing Racetech springs which I believe are not progressive. The ride is much more controlled than with the stock springs, especially at speed. Everything else, oil weight, etc. is to stock spec. I may add their cartridge emulators eventually.
Allroads is offline
post #4 of 43 (permalink) Old 02-13-2016, 04:15 PM Thread Starter
at this point i am willing to listen to all options from every one
post #5 of 43 (permalink) Old 02-13-2016, 04:35 PM
Main Motorcycle: 2014 Triumph Scrambler
Keith B's Avatar
Other Motorcycle: Harley Sportster
Ricor kit is not available in the UK.
We have to buy them from the USA,...which makes them bloody expensive.
I seem to recall that YSS make a copycat version. Someone like Squaredeals would sell them.
25yr old trapped in this 55yr old body.
Keith B is offline
post #6 of 43 (permalink) Old 02-13-2016, 07:26 PM
Main Motorcycle: 2016 Thruxton S
Ashman's Avatar
Other Motorcycle: 850 Norton Featherbed
Extra Motorcycle: 1960 650 Manxman
Send a message via Yahoo to Ashman
This is the way I went with my fork springs also with emulators, made the Thruxton so much better in all aspect of riding and handling, it cost a bit more (about $400 fitted) but well worth it, I ran progressive springs in my Norton but it made the front end to hard and wasn't happy with them at all, I ended up going back to the orginal spring but upgraded the fork cartrides with moden inturnals (Lansdown upgrade kit) to me progressive spring are to harsh, they are cheap but there are better set ups around, spend the money and do it right and your bike will love you for it as well as yourself, but do the front end up and you have to put better shocks on the back if you haven't already done that.
All up I spent $1,100 on my suspenssion upgrades and was the best investment I ever spent on my Thruxton, but I like pushing my bikes to their limits in tight twisty roads but it also made the bike more stable at high speed runs.
Ashley
Ashman is offline
post #7 of 43 (permalink) Old 02-14-2016, 07:37 AM
Main Motorcycle: '01 Bonneville
RichBinAZ's Avatar
Other Motorcycle: '91 GSX1100G
Extra Motorcycle: '14 FZ-09
For a cheap fix, try 15W oil. 15W-40 engine oil works fine.
What was the problem you are trying to fix BTW?
Ride height = shims
Damping = Oil
Or you can spend $$'s or 's
RichB in AZ
RichBinAZ is online now
post #8 of 43 (permalink) Old 02-14-2016, 08:14 AM Thread Starter
trying to sort out a very harsh and choppy ride
post #9 of 43 (permalink) Old 02-14-2016, 11:50 AM
Main Motorcycle: '09 T100 EFi
lambroving's Avatar
Other Motorcycle: Monster 796 ABS "Pantah"
Extra Motorcycle: K100RS 16/ABS
See post #2 above. Cheapest, most effective way to mitigate your complaint. You need to deal with the rear as well. Rear loading and response have an effect on the front.
'09 T-100 Forest Green / New England White, TORs, Intiminators & fork tubes raised 15mm, Chrome Ikon 7610 - SP8 Shocks, Custom Sargent Saddle, OEM Chrome Grab Rail, Conti Road Attack 2 EVO's 110/80VR19 & 150/70VR17, 7" Cibie lens and uprated H4 bulb.
lambroving is online now
post #10 of 43 (permalink) Old 02-14-2016, 01:34 PM Thread Starter
i have a plan for the back
How To: Progressive Suspension progressive springs cb200t Air Cooled Twins Technical Talk 3 03-04-2019 03:11 PM
Progressive fork spring install on 2013 Speedmaster sanckenil Air Cooled Cruisers - America, Speedmaster 5 10-04-2015 09:14 PM
Advice on progressive front springs wheelz Classic, Vintage & Veteran 15 07-11-2015 04:13 PM
Correct spacers for progressive fork springs? SkipII Air Cooled Twins Technical Talk 29 03-30-2015 02:08 AM
Rear Shocks & Front Springs - Progressive 412 vs. Ohlins 36E w/ Progress Fork Springs blackrod Air Cooled Twins Technical Talk 20 03-24-2015 04:00 PM
