Cold weather starting issues - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
  • 1 Post By endoscopy
  • 1 Post By SkipII
post #1 of 8 (permalink) Old 01-15-2016, 10:32 AM Thread Starter
Newbie
Main Motorcycle: Triumph Scrambler
Mbennettphoto's Avatar
So I am riding a 2015 Triumph Scrambler that is 1 year old with original battery. I have two separate and mildly annoying things happening.
First, when it is below 30ish degrees overnight the bike tends to not want to start. The preignition stuff will all work, but then when the starter button is pressed, it just clicks. I can jump this with an antigravity micro start and its good to go.
The second thing happens around 10 degrees, I will put the key in the ignition, turn it... and nothing. It acts as if the key is simply not there. My solution around this has been to either get out a low powered heat gun... or hot water.
I have yet to diagnose the exact area that brings the bike to life but I usually try to warm up around the ignition, the clutch control (this will sometimes freeze and act as if the clutch isnt being pulled in) and the battery area. After about a minute preignition will do its thing and then i can jump the bike.
While I have this lovely work around, something seems off. Any ideas?
Sometimes it's a little better to travel than to arrive. - Robert M. Pirsig
Mbennettphoto is offline
post #2 of 8 (permalink) Old 01-15-2016, 10:37 AM
Main Motorcycle: 2016 THRUXTON S/GREEN
Other Motorcycle: FZ 09
Extra Motorcycle: 2016 FZ07
Read the many posts on the "click" mine does it cold or warm, high fully charged battery. I either wait for the instruments to return to 0 or simply hold the starter button. A lot of psycosymantalization on this one. Low battery charge, relay etc. have been accused but all my friends with the EFIs have the same periodic "problem, we work around it.
vitesse is offline
post #3 of 8 (permalink) Old 01-15-2016, 04:40 PM
Main Motorcycle: Ducati 998
Other Motorcycle: Ducati 998 BMW R1100s
Vitesse is correct, and to be an ass, I'm expressing my concern that one, especially from Boston, starts a sentence with an adjective. Not proper old boy.
TVR1979 is offline
post #4 of 8 (permalink) Old 01-16-2016, 07:52 AM
Main Motorcycle: 2006 T100
endoscopy's Avatar
Other Motorcycle: 1969 TR6R
Don't chill out so much
Mr. Mbennettphoto,
I would discontinue the use of hot water. That's just asking for further trouble. Besides corrosion, there is the possibility of a freeze crack of some part of the bike. Make sure the clutch switch is operating as it should, and not partially frozen.
Vitesse's reply was spot on. Their are a lot of previous posts about this issue.
Mr. TVR1979,
So you must know by now that starting a sentence with so is like OK and grammer is so not important and that like everyone just says what like they want.
Namaste,
Charles
Hedgepig likes this.
endoscopy is offline
post #5 of 8 (permalink) Old 01-20-2016, 08:11 PM
Main Motorcycle: 09 Bonneville t100
Other Motorcycle: it's gone-650 yahama
Extra Motorcycle: I wish for a Enfield
I had this problem and it was fixed by disassembling the starter button housing and cleaning the contacts with a point file.The starter button contacts look exactly like the points in my old 50 chevy and cleaned up the same way.They are a substantial item and easy to access (don't lose any little parts while doing the job-like the little spring)
stevemorris7 is offline
post #6 of 8 (permalink) Old 01-21-2016, 12:17 AM
Main Motorcycle: 2016 Triumph Scrambler
VodkaAndPickles's Avatar
Other Motorcycle: RIP, my 2012 Scrambler
I've had this problem in temperatures of 0-10 Fahrenheit. I attribute it to the extremely thick oil at those temperatures (the clutch is hard to pull in) combined with a most likely less than optimal state of battery charge. Perhaps using 10W-40 or even 5W-40 instead of 10W-50 would alleviate things. However, the previous poster's suggestion is certainly worth investigating, and it'll be something I do if I have this problem in the future.
VodkaAndPickles is offline
post #7 of 8 (permalink) Old 01-21-2016, 07:23 AM
Main Motorcycle: 2013 Bonneville Mag Wheel
Other Motorcycle: 2014 Indian Chief Vintage
Correction obsession
Someone can spend their whole lives correcting the increasing misuse and misspelling of words on forums.
Some of the most common on this site:
"to" instead of "too"
"breaks" instead of "brakes."
"milage" instead of "mileage"
their, there
fare, fair
cite, site, sight
Many more...
The new Bonnevilles have a safety anti-theft device where riders have to properly insert the spelling of "catalytic" and "cylinder" or the bike won't start.
Anyway, if my experience with my 2013 Bonneville is typical, these bikes just get cranky in the cold. Beyond that, it is not unusual at all that hitting the starter switch often will be rewarded with only a click. I've been told that the ECU is hunting for the TPS reading. I find if I just stay on the switch, rather than let go of it and try it again, it clicks once or twice more and then starts.
TTP#3 tune, Norman Hyde silencers, gaiters, Hagon progressive shocks, RaceTech linear fork springs, Baldwin Thruxton-style seat, bafflectomy, TTP Breath, K&N Filter, O2 removal, Motone headlight bracket and ignition relocation bracket, Scottoiler
SkipII is offline
post #8 of 8 (permalink) Old 01-21-2016, 08:43 AM
Main Motorcycle: 2010 Scrambler EFI
patrickcol's Avatar
LOL, 'So' is not an adjective anyway Mr Pedantic, it's a submodifier
Coming from the UK, my first thoughts were why the hell would anyone want to start a bike in -30 degrees; but of course you're talking Fahrenheit, a mild frost.
There's no such thing as a five minute job.
patrickcol is offline
Gas mileage in cold weather JOHNTBS Air Cooled Twins Technical Talk 9 12-19-2015 12:56 PM
Cold Weather Gear - What's in your wallet? Wakinyan Thunderbird Cruiser Chat 5 10-08-2015 07:02 AM
Starting issues - 2010 Roadster scribbler2300 The Rocket Science Forum 2 09-15-2015 05:59 AM
Starting issues. Clicks, then starts sappy13 Daytona Deliberations 2 04-19-2015 11:21 PM
Daytona 600 starting issues Phillym Triumph SuperSports 22 04-16-2015 10:52 PM
