Tire mounting bead mounting trick - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 7 (permalink) Old 08-13-2015, 03:33 PM Thread Starter
Main Motorcycle: Bonneville black 2007
sonicboom's Avatar
Other Motorcycle: Honda CBR600RR
Extra Motorcycle: Honda CB500F
Mounted and balance a rear tire the other day using my Harbor Freight tire mounting device.
Once the tire was mounted to the rim everything had gone almost too smooth up to that point which made me think I was getting good at this. Then came the tire inflating and trying to get the beads to both pop into place. Aired it up to like 60 pounds no joy.
I end up using a tie down strap and got it as tight as I could get it around that tire. Re-inflated and that tire popped on by the time I hit like 32 PSI. What a great trick to get the tire to pop onto the beads.
Hope this can save someone a headache who mount their own tires.
This Harbor Freight tire mounter is great, works like a charm. I also purchased the No Mar mounting bar which helps on my Guzzi mags.
The mounting bar which is nice with mags can be found here...www.NoMarTireChanger.com
sonicboom is offline
post #2 of 7 (permalink) Old 08-13-2015, 04:16 PM
Main Motorcycle: 2009 Scrambler
b0rderman's Avatar
Send a message via AIM to b0rderman
Sounds like a great trick...the one time I had to reseat my bead with air I took some advice to remove the valve stem core to get a few more PSI into the tube/tire...that worked too but your 32psi solution seems much better.
How do you balance your tires afterwords?
b0rderman is offline
post #3 of 7 (permalink) Old 08-13-2015, 05:43 PM Thread Starter
sonicboom's Avatar
I'm using the Harbor Freight static tire balancer. Darn thing works great. I just found a video on line showing how to use a static balancer. You can also find some good video stuff on line with great tips on mounting and de-mounting tires. After watching a few videos you figure out the best way that works for you.
post #4 of 7 (permalink) Old 08-13-2015, 10:34 PM
Main Motorcycle: 09 Street Triple
Other Motorcycle: SV650 Race bike
Extra Motorcycle: "13 Kawasaki C14
Try using some Ru-Glyde from Napa to lubricate the beads when you are mounting and dismounting the tires. Not only does this allow the tire to seal faster, it provides enough slip to get it to start seating as soon as you mount so you don't have to use the strap trick.
Ru-Glyde takes all the work out of it.
JonBon3 is offline
post #5 of 7 (permalink) Old 08-14-2015, 03:10 AM
Main Motorcycle: 2007 Bonnie T100
bonza's Avatar
Other Motorcycle: Jeep Wrangler
wish I read this yesterday as I changed a rear tyre and couldn't get the bead to seat.
was at service station using their air and several attempts of inflating then letting it down then re-inflating to 60 psi all to no avail. had to go back home and squish some washing up detergent onto the bead, back to the service station and voila... it popped into place
2007 Tuxedo T100.
Dom Tourers, TTP breathe, DNA filter,baffle gone, 40/140/1 shim 3 turns, TTP igniter tune, Hagon Nitros, Thruxton Bars, Halcyon bar end mirrors, Pingel fuel valve, Monza gas cap, Burton seat, Avon Roadriders
bonza is offline
post #6 of 7 (permalink) Old 08-14-2015, 09:38 AM Thread Starter
sonicboom's Avatar
The more lube the better I'm finding out.
When I purchased the No Mar mounting bar they gave me a free sample of No Mar Tire Lube, it's sort of a jell and works for mounting. The other thing that works well is just dishwashing soap in a spray bottle mix with water. I've used windex and that works good also.
post #7 of 7 (permalink) Old 08-14-2015, 10:05 AM
Main Motorcycle: '98 T595 Daytona
Other Motorcycle: 2014 Ninja 1000ABS
I have the NoMar machine and use their lube. Supposedly better than water/soap since you don't want water/moisture trapped inside the wheel. Whatever works. I also have a bucket of a gel lube that is white that I purchased at an auto parts store. I recently managed to install tires on my Chevy using the NoMar. It did help to have a friend really press down on the opposite side of the bead into the drop center to mount the tire. They all popped easily with a small compressor.
Felony is online now
Avon distanzias on a Thruxton. Help! Jackwood Air Cooled Twins Talk 10 04-01-2016 12:20 AM
Tire balancing-How much lead is too much? T Dad Speed Triple Forum 15 08-12-2015 04:25 PM
Belt Chirping and Metzeler Rear Tire hdud Thunderbird Twin - Technical Talk 0 06-21-2015 10:08 AM
Beware new tyres! al1 Biker Hang-Out 78 05-19-2015 05:39 PM
Mounting new tires... Bead Lubricant IpswichT900 T3 Sport / Touring Forum 8 03-19-2015 10:11 PM
