cold starting the Bonneville - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
post #1 of 9 (permalink) Old 08-03-2015, 09:30 AM Thread Starter
Main Motorcycle: BMW R1150GS
Ian Porter's Avatar
Other Motorcycle: 2013 Scrambler
Extra Motorcycle: 2014 Bonnevile-the wife's
not sure if this is a problem or a feature of the Bonneville,
On my wife's 2014 Bonnie when starting from cold it often fails to turn over on the first press of the button, just partially turns the engine as if it can't overcome compression.
second (or occasionally third) press it fires up and runs fine all day long.
we were used to this on her old BMW 650 single and that was just where the engine stopped on the stroke stopping the decompresser valve kicking in on first press
could this be the same on the Bonnie?
odd thing is I've never had it on my 2013 Scramber
Ian Porter is offline
post #2 of 9 (permalink) Old 08-03-2015, 09:57 AM
Main Motorcycle: 2016 THRUXTON S/GREEN
Other Motorcycle: FZ 09
Extra Motorcycle: 2016 FZ07
Common, if you are talking about the little semi spin then nothing when pressing the button. All input so far says it is low battery, to me that is impossible, mine has done this after full charge, from brand new 13. I cleaned the contacts etc. now i wait for the gauges to set themselves, dial goes right then settles at base 0 I press the button then, most times it starts. There is a supposed "fix" if you search, it is hard lining a resistor in the starter relay loom. Do a search, I remember Forchetto commented on it. I can't remember the link.
vitesse is offline
post #3 of 9 (permalink) Old 08-03-2015, 10:04 AM Thread Starter
Ian Porter's Avatar
I guessed it would be a common 'issue' but no way is it battery related on this bike, like you we've had the bike from essentially brand new and it's always done it
post #4 of 9 (permalink) Old 08-03-2015, 01:09 PM
Supernova
Forchetto's Avatar
No decompressor valve on the Bonnie. Several fixes on this beauty of a 37-page thread. I'll take you to the latest mod, rragos's diode mod:
https://www.triumphrat.net/twins-tech...ml#post6158521
Other mods and comments within the rest of the thread.
Triumph's explanation for this start delay effect on post 110:
https://www.triumphrat.net/twins-tech...ml#post2448585
This is another (mealy-mouthed and frigging useless) reply from Triumphs Faecesbook page concerning this type of starting problems:
https://www.triumphrat.net/twins-tech...-facebook.html
Forchetto is offline
post #5 of 9 (permalink) Old 08-03-2015, 02:05 PM
Thanks I'm going to do that Radio Shack resister one where you cut into the wire with a splice and install the bit. You commented on it a while ago. Thanks as always.
vitesse is offline
post #6 of 9 (permalink) Old 08-04-2015, 12:43 AM
Main Motorcycle: 2016 Triumph Scrambler
VodkaAndPickles's Avatar
Other Motorcycle: RIP, my 2012 Scrambler
Mine has just started doing this.
VodkaAndPickles is offline
post #7 of 9 (permalink) Old 08-04-2015, 03:25 AM
Main Motorcycle: 2010 Bonneville T100
Ridgy's Avatar
Other Motorcycle: 1975 Norton Commando MK 3
Faecesbook!!! That's a keeper!!!
Ridgy is offline
post #8 of 9 (permalink) Old 08-05-2015, 05:54 AM
Main Motorcycle: 2005 Yamaha Majesty 400
RJ64's Avatar
Other Motorcycle: 2007 Honda VTX1800N
Extra Motorcycle: 2013 Triumph Bonneville
For a second there I thought this was about pulling the "choke" knob out to the first click. Mine will at times do what has been described but if I pull the knob out it fires up every time.
Sent from Motorcycle.com Free App
RJ64 is offline
post #9 of 9 (permalink) Old 08-06-2015, 08:32 AM
Mine does this too every now and then, good to know I'm not alone!
CaptCaveman is offline
Bonneville starting issue--technical rbneil Air Cooled Twins Technical Talk 11 04-09-2017 02:09 PM
Mag Wheel Bonneville - Starting Transition to Cafe Racer blackrod Air Cooled Twins Talk 10 07-25-2016 09:49 AM
Los Angeles to Vancouver on a Bonneville deadhand Air Cooled Twins Talk 26 09-02-2015 02:24 PM
Cold blooded problems strug Air Cooled Twins Technical Talk 8 07-17-2015 02:03 PM
2006 Bonneville t100 Headlight & Starting Problem Dberto Air Cooled Twins Technical Talk 4 05-28-2015 04:54 PM
