Starting problem - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 6 (permalink) Old 02-24-2015, 03:35 AM Thread Starter
Main Motorcycle: 2016 Triumph Scrambler
VodkaAndPickles's Avatar
Other Motorcycle: RIP, my 2012 Scrambler
Starting problem
I have had this issue twice already:
In very cold weather (today, it was 0 Fahrenheit, or -18 Celsius), the oil is so thick that it is difficult to pull in the clutch lever. If the clutch is pulled in to the handlebar when I turn on the ignition and the fuel pump starts to prime, the fuel pump stops priming. It starts priming again if I let go of the clutch a little.
Twice, the battery has been dead and I've heard only clicking. After jump starting it, the battery was fine until the onset of really cold weather again. I had to jump start the bike again today.
Why the interruption in the fuel pump priming? Is there an issue with my clutch switch? Why is my battery dying literally overnight, but is fine as long as the temperature is not quite that low? Is it because the oil is so thick?
VodkaAndPickles is offline
post #2 of 6 (permalink) Old 02-24-2015, 05:00 AM
Supernova
Forchetto's Avatar
That clutch switch is not the finest quality item. Try removing it from the lever perch and exercising its little spring-loaded plunger to see if it's stiff. Instructions on how to test and or remove the switch here:
https://www.triumphrat.net/twins-tech...ty-switch.html
This is what it looks like when removed, notice the plunger I'm talking about:
In very cold weather and thick oil (especially if you're using a higher viscosity than recommended), the starter demands a lot more current than normal. If there's any weakness in the connections to the battery or solenoid or if the battery itself is marginal it'll show up as trouble starting.
Forchetto is offline
post #3 of 6 (permalink) Old 02-24-2015, 12:59 PM Thread Starter
Using the recommended Castrol 10W-50. Was gonna change it to Amsoil 10W-40 at the beginning of January, before the real cold set in, but got lazy...
post #4 of 6 (permalink) Old 02-24-2015, 01:32 PM
Main Motorcycle: 2007 thrux
mjsmilford's Avatar
why the need to pull clutch lever to start? are efi bikes different than carb? as long as mine is in neutral, starter will work.
Mike
2007 triumph thruxton
mjsmilford is offline
post #5 of 6 (permalink) Old 02-24-2015, 01:37 PM
Main Motorcycle: '98 T595 Daytona
Other Motorcycle: 2014 Ninja 1000ABS
In neutral with the lever out, the clutch is still engaged with the input shaft of the gearbox. Easier on the battery to disengage the clutch and thus the gearbox shaft. That's my take on it anyway for the carb version or for any bike.
Felony is offline
post #6 of 6 (permalink) Old 02-24-2015, 01:52 PM
Supernova
Forchetto's Avatar
From around 2009 all the Bonnies need to have the clutch lever pulled in to enable starter. There's an interlock switch as described on link post 2.
T595 starting problem 300M Daytona Deliberations 3 03-18-2015 07:07 AM
multiple punch marks on crankshaft - this a problem? jonkster Classic, Vintage & Veteran 186 03-12-2015 08:00 PM
Thruxton problem threepot Air Cooled Twins Technical Talk 12 02-28-2015 02:48 PM
front brake switch problem - lateral thinkers required! pa59ul T3 Sport / Touring Forum 10 02-19-2015 01:04 AM
Do I have a front brake disc problem? brock29609 Air Cooled Twins Technical Talk 6 01-31-2015 08:03 PM
