Pirelli Angel GT on Thruxton - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 12 (permalink) Old 01-21-2015, 07:36 PM Thread Starter
Main Motorcycle: Thruxton
Yes another, another tire thread! BUT these are relatively new tires. Is there anyone out there using the 150/70 - 110/80 set up? I spoke with Pirelli rep and stock rims are within spec for this set up. It seems that the Sport Demon 150/70 17 have been discontinued.
Cheers
mpozz is offline
post #2 of 12 (permalink) Old 01-21-2015, 09:28 PM
Main Motorcycle: 2013 Triumph Thruxton
Other Motorcycle: '12 BMW R1200R
Extra Motorcycle: '13 Honda CB500X
I had Pirelli Angel ST tires on my Trophy when I had it, and thought they were a fantastic tire. My Thruxton will be getting the Angel GTs once the factory tires are used up.
Sent from Motorcycle.com Free App
cide1 is offline
post #3 of 12 (permalink) Old 06-02-2015, 05:15 PM
Main Motorcycle: 2016 T120
Nickolarge's Avatar
Other Motorcycle: 1981 Moto Guzzi V50 Mk3
Bumping this thread as I am thinking of fitting these soon and looking for some feedback.
Nickolarge is offline
post #4 of 12 (permalink) Old 06-02-2015, 10:56 PM
GDM
Main Motorcycle: Bonneville Modified 2005
Other Motorcycle: Bonneville T100 2006
Extra Motorcycle: Honda CB750 1972
I put a set on my Sprint GT and they are great
GDM is offline
post #5 of 12 (permalink) Old 06-10-2015, 05:08 PM
sportbikemark's Avatar
bump again...anyone?
sportbikemark is offline
post #6 of 12 (permalink) Old 06-11-2015, 10:27 AM Thread Starter
I'm surprised as well that there was such limited response about these tires. Perhaps it is because they are not "classic" looking enough. As per the specs and reviews from other bikes, they seem to be an excellent tire for Thruxton style of riding
mpozz is offline
post #7 of 12 (permalink) Old 03-11-2019, 04:32 AM
Main Motorcycle: 2015 Thruxton Ace
Murat K.'s Avatar
Cheers
I'm looking for a set of new tires for my 2015 Thruxton 900. I was about to get the Pirelli Sport Demons (150/70 - 110/80 setup) (not discontinued by the way) but my tyre dealer recommended Angel GTs (same setup) instead. There are a lot of recommendations of the Sport Demons for our bikes, but couldn't find much about Angel GTs...
Did you go with the Angel GTs at the end? If you did, would you recommend them? I don't ride everyday, so long life is not important for me. I need a tyre with soft compound and good grip/handling..
Current Ride: '15 Thruxton Ace
Mods: BC Predators, BC Air Box Removal (K&N Pod Filters), Air Injection (SAI) Removal, O2 Sensor Removal, TTP EFI Tune, BC Cateye Fender Eliminator Kit, BC Black Bullet Turn Signals
Previous Ride: '11 H-D Sportster 48
Murat K. is offline
post #8 of 12 (permalink) Old 03-11-2019, 10:50 AM
Main Motorcycle: All
pmorritt's Avatar
Other Motorcycle: one at a time
The Pirelli Corsas were used up in 4k miles on my TTR. Replaced with Angel GT and havent noticed any difference in dry or wet conditions. Double or triple the miles wouldnít hurt either.
Masquerading every day as a normal person is exhausting.
pmorritt is online now
post #9 of 12 (permalink) Old 03-11-2019, 11:03 AM
Main Motorcycle: 2013 Thruxton
Other Motorcycle: I wish!
mpozz, please see my review, part 2, in the thread below.....
https://www.triumphrat.net/air-coole...-part-1-a.html
Would still confidently recommend them. I had same issue of limited availability, and pleased I settled on these after much research and reading. Only thing I would add is that they are very tire pressure sensitive. Once you have the pressures set to your liking, be sure to maintain said pressures. Has a significantly adverse effect on handling if falling more than 2-3 psi below your target pressure. Possibly a common issue with many brands!
Ride safe, Thruxty.
2013 Thruxton: Hagon 2810, Ricor Intiminators; STS; AI & O2 removed; 2>1 baffle remove; airbox snorkel and restrictor removed; TTP; Tail Tidy; Eastern Beaver Relay; LED Indicators; Tubeless Rim Conversion; Pirelli Angel GTs 110/80-18, 150/70-17
Thruxty is online now
post #10 of 12 (permalink) Old 03-11-2019, 04:01 PM
Main Motorcycle: Buell xb12x
Other Motorcycle: 04 sprint
Extra Motorcycle: flst
ive ran Angel ST on my Sprint ST and now running the GT's on it. Also have a set of GT's to mount up on the Buell XB12X. Best mileage of any tire i've ran. Have been fully satisfied with the performance as well. They offer an "A" for heavy weight touring as well but did not opt for those, even though do a lot of 2 up. They are good for me.
smorris is offline
Anyone tried Pirelli Angel GT's taximan62 Speed Triple Forum 28 05-15-2015 03:10 AM
Pirelli Angel ST wasabi Sprint Forum 148 07-28-2011 12:46 PM
Pirelli Angel St Tires bobbitts Sprint Forum 1 06-07-2010 12:32 AM
Pirelli Angel ST Berman95 Sprint Forum 8 02-07-2010 08:33 PM
Pirelli Angel ST's ? Dekerf Speed Triple Forum 1 05-26-2009 07:52 AM
