MotoGadget m-Unit Installation - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
  • 1 Post By michaelreuss
post #1 of 6 (permalink) Old 11-01-2014, 09:25 PM Thread Starter
Main Motorcycle: 2007 Bonneville
Question MotoGadget m-Unit Installation
Is this a pretty common thing to do? It looks wicked cool and a great way to tidy up all of the electrical wiring mess in the head lamp.
As I read the instructions (http://motogadget.com/media/download...l_en_3.2_k.pdf) you basically create a new wiring harness, run everything from the switches to the unit and then the unit out to the battery and earth.
2007 Bonneville | FCR 39mm | TTP Stage 1 Fire Starter | Stock Cams/Pistons/Head | Dominators | K&N pods | Intiminators & .90kg/mm linear springs | Ikon 7610 (heavy) | m-Unit v2 w/ custom wiring harness | m-switches |
extractable is offline
post #2 of 6 (permalink) Old 11-01-2014, 10:03 PM
Main Motorcycle: Bonneville 2013
izzythedan's Avatar
I was having a look at the m-unit too. I like gadgety things like that. I wonder if it'd work with an EFI Bonnie.
izzythedan is offline
post #3 of 6 (permalink) Old 11-01-2014, 10:32 PM
Main Motorcycle: 2013 Scrambler Black
You buy the mTri for efi bonnies. Search the forum here, quite a few people have talked about them.
hehehemann is offline
post #4 of 6 (permalink) Old 11-04-2014, 03:13 PM
Main Motorcycle: 2001 Bonnie
Other Motorcycle: 2002 Bonnie
Extra Motorcycle: 1250 K8 Suzuki Bandit
Member Northern Thrux used one in his fabulous build, sadly he sold it and I don't know if he is still on the forums. There was a post about the M-Unit few weeks ago.
Here is his original build thread, all 34 pages, some amazing work within. https://www.triumphrat.net/twins-tech...ld-log-34.html
fullplat1 is offline
post #5 of 6 (permalink) Old 11-04-2014, 03:45 PM
NDR
Let me know if you decide to move forward with this.
I've asked a custom harness maker to give me a quote for a complete harness to accommodate both a Motogadget Chronoclassic and M-Unit.
NDR is offline
post #6 of 6 (permalink) Old 05-19-2019, 08:20 AM
michaelreuss's Avatar
M-Unit and M-Lock installed
Revisiting an old thread here. Just in case someone is researching this: I just had it done, installed an M-Unit and M-Lock on my T100 EFI 2009.
Took the mechanic I asked (and who‘d never done it before) some 15 work hs. Total cost: 300 USD for the M-Unit Blue, 130 for the M-Lock, 50 for the harness, 500 for the work, so roughly 1000 USD.
guitargeek62 likes this.
michaelreuss is offline
Wiring a Thruxton with a motogadget m-unit NorthernThrux Air Cooled Twins Technical Talk 10 08-02-2017 03:08 AM
Motogadget Installation Absolutz Air Cooled Twins Technical Talk 12 04-11-2015 10:25 AM
Heads Up Display Unit Installation w/ Pictures TripleThreat Speed Triple Forum 34 11-01-2006 02:55 PM
SportVue Heads Up Display Unit Installation TripleThreat Maintenance & Workshop Talk 5 03-30-2006 06:45 PM
