Paddock stand bobbins - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
post #1 of 13 (permalink) Old 08-17-2014, 09:47 AM Thread Starter
Main Motorcycle: GSXR 750
Other Motorcycle: Soon to be a bonnie
Hi. I'm new to paddock stands. Does anyone know what size a bonnieville SE bobbin takes. Some websites say 6mm and some say 8mm. To be honest I don't even know where they fit.
I have after market silencers so hopefully they won't be in the way.
Sent from Motorcycle.com Free App
randallstu is offline
post #2 of 13 (permalink) Old 08-17-2014, 11:34 AM
Main Motorcycle: 2015 Tiger 800 XRx
tntriumph's Avatar
The only paddock stand bobbins I've ever seen are these from Free Spirits which mount on a rod that runs through the hollow rear axle.
http://tinyurl.com/njr2nmu
See you somewhere down a twisty road....
tntriumph is offline
post #3 of 13 (permalink) Old 08-17-2014, 05:00 PM
Main Motorcycle: 2010t100 67 ttspecial rep
mike-tt special's Avatar
Other Motorcycle: 91 zxr750(805cc)
hi stu
I could not find a bolt on solution to the paddock stand problem on our bonnies that looked good and that would enable me to use the stand in the proper way
the rod through the wheel spindle method doesn't allow you to remove the rear wheel which is probably the main reason for a paddock stand beside lubing the chain and the cup type adaptors that go under the swing-arm are very precarious
so this is my solution, it's not a simple bolt on solution but I think it look as if it came from the factory like this, and more importantly it works as a stand bobbin should
I used 2 off M8 mild steel pipe socket coupling that I welded to the underside of the swing-arm, the bobbins just screw into these in the conventional manner I then had the swing-arm powder coated
[IMG]
[IMG]
who wudda thought id wanna bonneville!
Last edited by mike-tt special; 08-18-2014 at 06:08 PM. Reason: i confused my pipe fittings nipple with a socket
mike-tt special is offline
post #4 of 13 (permalink) Old 08-17-2014, 06:07 PM
Main Motorcycle: 2011 Bonneville SE
Other Motorcycle: 1998 Triumph Trophy
Extra Motorcycle: 1998 Triumph Trophy
My solution was to get a Pit Bull SS Rear Stand. It's not cheap, but it works great. The supports that hold the swing arm are easily adjustable, and rock solid.
I do like the bobbin idea that Mike did. That mod may be in the Bonnie's future.
Ace2044 is offline
post #5 of 13 (permalink) Old 08-17-2014, 06:32 PM
Ripper's Avatar
This is hoping that you are in Birmingham UK and not Alabama - Give these guys a go - they manufacture their own, so even if you don't see anything listed they will still help you:
http://www.jaybeebikerbits.co.uk/index.php/
Arrow 2-2, Snorkel/Baffle removed, DNA filter, TTP Tune#3, TEC piggy back gas shocks, 5.5" risers with drag bars, LED Lighting, Hazards, Oberon Footpegs, Burton Seat, D9 bracketry, Hands Free Keyless ignition.
Ripper is offline
post #6 of 13 (permalink) Old 08-17-2014, 08:41 PM
Main Motorcycle: Black Thruxton 08
Other Motorcycle: WhiteTiger Sport 13
I used a pit bull type race stand but the 'paddles' that you place under the s/arm are precarious when lifting and lowering solo. So I drilled and tapped to 6mm just below and forward of the rear axle slot and bolted on some bobbins. Quite easy to do, no welding and painting etc. Just drill and tap. The rear section of the s/arm is solid steel hence no problems there. The rectangular section is likely to be hollow so not good there. The location is about the same as Mike TT above but maybe 25mm higher. With the bobbins using the paddock stand is much more secure.
Cheers, Simmo
Ride it while you can.
Simmo is offline
post #7 of 13 (permalink) Old 08-18-2014, 03:28 PM Thread Starter
Thanks for your replies - has given me some options. I'm after one of these for my garage http://www.sportsbikeshop.co.uk/moto...ent_prod/92416
post #8 of 13 (permalink) Old 09-08-2016, 05:56 AM
Main Motorcycle: Thruxton R
Tricolour's Avatar
Other Motorcycle: Bimota DB9S
Extra Motorcycle: Morini Corsaro
I use one of these stands on my Thruxton R but I don't use inserts with bobbins on the 8mm swing arm as they raise the bike too high.
I just used a 10mm st/st rod through the holes in the stand and the axle.
I machined some 18mm diameter x 75mm long aluminium inserts with a 10mm diameter hole through the middle.
These fit through the holes in the stand and fill the space from the stand to the axle.
Takes out any 'bow' in the 10mm rod.
Works ok and is a one hand easy action to raise the bike.
A quick visit to my garage - a pix is worth a thousand words.
Tricolour is offline
post #9 of 13 (permalink) Old 05-30-2019, 08:14 AM
Main Motorcycle: Triumph Scrambler '15 EFI
Hugo7's Avatar
Bit of a dredge, but I came across this thread while looking for bobbins.
Is there any reason that you couldn't just replace the shock bolt with 8mm bobbins in the bottom shock bolt hole?
A bit like:
Hugo7 is offline
post #10 of 13 (permalink) Old 05-31-2019, 08:49 AM
Main Motorcycle: Triumph Bonneville 2008
TILL_PT's Avatar
Other Motorcycle: Yamaha DT MX 125cc 1980
Extra Motorcycle: Yamaha TDM 850cc 1998
If you could find one with the same thread Theoretically would not be a problem at all, would continue to attach to sprung weight.
08 Bonnie
+ Tec Sprint Exhausts / TTP EFI Remap Map #6 / Breathe Airbox Intake / DNA Air Filter / NGK Iridium Sparkies
- Air Baffle / Snorkel / O2 Sensors / AI System
TILL_PT is offline
Swingarm paddock stand bobbins t70mb T3 Sport / Touring Forum 3 08-12-2014 01:07 PM
Rear Paddock Stand or Centre Stand Demonic Speed Triple Forum 20 08-01-2012 12:16 PM
955i paddock stand bobbins neil1052 Speed Triple Forum 0 09-27-2006 11:41 PM
rear wheel stand (paddock stand) for TBS Hinckley Classic Triples 5 08-29-2004 01:43 PM
Paddock stand vs. center stand questions Solace Sprint Forum 6 04-01-2004 09:31 PM
