Thruxton throttle cables - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 11 (permalink) Old 05-25-2014, 04:40 PM Thread Starter
Main Motorcycle: Triumph Thruxton
Other Motorcycle: CRF450 Supermoto,
Has anyone ever tried to pop off the plastic ends off the twist grip end of thruxton throttle cables, I need longer cables, I suspect they may be glued ?
Banditwat is offline
post #2 of 11 (permalink) Old 05-25-2014, 11:56 PM
Supernova
Forchetto's Avatar
Which bit do you mean?, there's nothing glued-up on the throttle cable assembly AFAIK:
Forchetto is offline
post #3 of 11 (permalink) Old 05-26-2014, 04:18 AM
Main Motorcycle: 2003 Bonneville T100
Perhaps he's referring to the 90-degree turns with the adjustment widgets for each cable. Otherwise... ???
StMcK
Steve McKing is offline
post #4 of 11 (permalink) Old 05-27-2014, 03:58 PM Thread Starter
I was referring to the plastic 90`s at the twistgrip end and I figured it out, they simply screw off (anticlockwise). I bought cables from the UK for a Bonnevile America but needed these end pieces to work with my Thruxton twistgrip and flattrack bars.
post #5 of 11 (permalink) Old 05-27-2014, 04:42 PM
Main Motorcycle: 2007 bonnie black
killian101's Avatar
Other Motorcycle: 68 BSA (RIP)
Extra Motorcycle: 2015 Daytona
why do you need longer cables? unless you have 1in riser and western bars, stock cables should fit just about any bars.
killian101 is offline
post #6 of 11 (permalink) Old 05-28-2014, 05:09 PM Thread Starter
The original thruxton bars are very low clip ons, I have fitted dirt track bars that are very high, hence the longer cables.
post #7 of 11 (permalink) Old 05-28-2014, 07:47 PM
killian101's Avatar
Bonnie length, email NB too, they come in all colors
http://www.newbonneville.com/html/co...able_pack.html.
Though, you should be able to reroute those cables...are you cables from 1in bars or 7/8?
post #8 of 11 (permalink) Old 05-29-2014, 09:19 AM
Main Motorcycle: all of them
Other Motorcycle: Thruxton Tiger 800,
Extra Motorcycle: T140, BSA B50, BSA A65,
$200 for cables!!!!!!
drlapo is offline
post #9 of 11 (permalink) Old 05-29-2014, 12:57 PM
Supernova
Forchetto's Avatar
I know, incredible, mind you it says "They come pre-lubed for silky smooth operation"
A bit like condoms...
post #10 of 11 (permalink) Old 10-25-2015, 04:51 PM
DIY
DIY's Avatar
Sorry to revive an old thread, but I cant figure out how to get the 90 degree plastic ends off. The OP mentions twisting them off but I cant see how that's possible seeing as the heads on the end of the cable are too wide to pass through the plastic.
I bought a British Customs Throttle Housing and the 90 degree plastic at the lever end is interfering with the installation. My cable looks exactly like pic Forchetto posted above.
DIY is offline
Thruxton carbureted throttle cables - what other bikes' cables would work? msomerstein Air Cooled Twins Technical Talk 5 05-23-2013 06:01 PM
Throttle Cables Woolly Classic, Vintage & Veteran 7 01-19-2008 11:13 AM
Throttle CAbles on an 06 ST dogarajo Sprint Forum 2 09-25-2007 12:15 PM
throttle cables bonnebill Classic, Vintage & Veteran 1 07-01-2007 02:32 PM
