Chain Rub - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
post #1 of 14 (permalink) Old 10-24-2013, 06:21 PM Thread Starter
Main Motorcycle: 2012 Bonneville -Gold!
Other Motorcycle: 76 T140
Chain Rub
2012 Mag Wheel Bonneville. Aprox 1600 miles.
I sat down to lube my chain this afternoon and when I took off the chain guard noticed a grind mark where the chain has risen up and ground down the side of it. It's right where the bend is to allow for shock clearance. No damage to chain noted and it's not a massive amount of grinding, maybe 1mm deep or so. Checked my chain slack and it is just about 1" of slack which, if my calculations are correct, is dead nuts in between the 20-30mm mark the manual states. I don't feel a lot of drive line lash when riding which would indicate a loose chain. It has to have happened in the last 400 miles or so as that's the last time I lubed the chain and did not notice it then. Only thing new on the bike is that I put on some used Hagon shocks. Though I can't imagine that would allow the chain to rise up (stock length).
Any ideas? Should I run the chain tighter? I've checked the chain slack every time I've lubed the chain and with exception of this last one has been every 200 miles. No change in slack at all.
L8*Apex is offline
post #2 of 14 (permalink) Old 10-24-2013, 06:48 PM
Other Motorcycle: 1970 TR6R: SOLD....
Extra Motorcycle: 1999 Yamaha Virago 1100
I would not tighten the chain. You could end up with even bigger problems with sprocket and/or seal wear on the front sprocket. Anyway, if I read it right, the wear is on the upper run of the chain, which is where it is, usually, under tension; there could be a rub, I suppose, on deceleration when the upper run is looser. I'd check the chain alignment and the chain guard itself, as it may be slightly bent towards the chain.
Just the opinion of the "village idiot", that's all: Jim
Jim Ballard
jimballard is offline
post #3 of 14 (permalink) Old 10-24-2013, 06:58 PM
Main Motorcycle: '06 Triumph Bonneville
P-twin's Avatar
Location: West of the east coast & east of the west coast
+1 to checking the alignment especially seeing the problem is in one specific spot. Are the has marks lining up on both sides of the guides? You can also take a long screwdriver, pen, thin rod...whatever....and lay it on top of the chain start at the rear sprocket - line it up to the inside collar of the collars and make sure it runs straight down the chain
P-twin is offline
post #4 of 14 (permalink) Old 10-24-2013, 07:00 PM Thread Starter
I suppose the chain guard could be bent but I purchased the bike brand new and looks normal to me. I've been trying to imagine in my mind if the top side of the chain comes up under high speed conditions or under deceleration as you stated.
When looking at the chain with the guard over it the indentation for the shock on the guard does sit slightly over the chain. Bike runs great so I suppose I could just bend the chain guard slightly outwards but it just seems weird to me that it would do this.
L8*Apex is offline
post #5 of 14 (permalink) Old 10-24-2013, 08:10 PM
Main Motorcycle: 2010 Bonneville Black
I have the same grind marks my is a 2010 bonneville. I'm not sure where it comes from I took some pics and to me it looks like my guard isn't bent and there would have to be a lot of slack in the chain to rub but what do I know.
thomb25 is offline
post #6 of 14 (permalink) Old 10-24-2013, 08:21 PM Thread Starter
I was just about to post pics but that is exactly what mine looks like. Chain looks good, concerned that it will damage the chain at some point although the guard is much softer metal.
L8*Apex is offline
post #7 of 14 (permalink) Old 10-24-2013, 08:23 PM
P-twin's Avatar
Chain slap is more significant than what a lot may think. Here is some with the bike only at 30mph
P-twin is offline
post #8 of 14 (permalink) Old 10-25-2013, 12:45 AM
Main Motorcycle: '12 Bonneville SE
Other Motorcycle: '14 Street Triple R
Extra Motorcycle: '14 Honda CTX700N
My chain guard has a similar marking. Chain looks fine. I'm at only 1200 miles so far. Using pro motion tool, the alignment is very slightly off (barely noticeable). I plan to adjust when chasing needs to be tightened. Right now, tightest spot measures about 28mm.
jazzyj is offline
post #9 of 14 (permalink) Old 10-25-2013, 07:46 AM
Main Motorcycle: '13 BMW F700GS
Had the same on mine but only noticed it when I tightened the chain and realigned the rear wheel. Even after doing both I was able to pull the chain straight up and see it hit the guard, so I just bent the guard to where the chain is properly under it.
simplespirit is offline
post #10 of 14 (permalink) Old 10-26-2013, 09:27 AM
Main Motorcycle: 203 T100
Other Motorcycle: 1968 Truimph Daytona
Extra Motorcycle: 2006 Ducati Multistrada
Yeah, the guard is softer than the chain. No way will your chain suffer. Do not tighten it beyond factory specs, or you'll soon be replacing some expensive bearings.
Hard work may pay off some day, but laziness always pays off right now.
Bill
View my photo album
billstokes is offline
Chain rub?? DaveG Hinckley Classic Triples 16 01-26-2011 05:29 AM
Fun with chain rub strip and clutch cable... johnnycactus Triumph SuperSports 3 05-04-2008 01:38 AM
trying to replace the chain rub strip on my TT HELP ? Loun Triumph SuperSports 6 07-22-2007 07:39 PM
Timing chain rub block Timan Speed Triple Forum 4 01-21-2007 06:17 PM
new chain rub gaurd installation punisher Triumph SuperSports 3 08-31-2004 10:54 PM
