Is it normal for brand new engine to weep oil... - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
post #1 of 21 (permalink) Old 05-01-2013, 06:48 PM Thread Starter
Main Motorcycle: 2012 Bonneville SE
I just picked up a brand new 2012 Bonnie SE and it only has 40 miles on it (that i put on between riding home from the dealership and taking it out for a short spin today). I've noticed that there are a few spots around the gaskets (head /valve cover) where it looks like it is weeping a bit of oil. Is this normal during the break in period for a bike?
All of my bikes have leaked oil...but that is because they were all ancient pieces of junk.
I am obsessive and this will drive me crazy until someone tells me its normal (calm down Russ) or that I need to bring it back to the dealer.
Thanks in advance!!!
RussAlan is offline
post #2 of 21 (permalink) Old 05-01-2013, 06:50 PM
Legend
Main Motorcycle: 2008 Bonneville Black
Driftless Admin
BonnieBlack's Avatar
Other Motorcycle: Spousal 2009 Bonnie Black
Can't believe that is still a problem after all this time. Yes, sadly, completely normal. But, happily, nothing but a cosmetic issue.
Have the dealer fix it under warranty, they're used to it I'm sure. No hurry though. Wait for a spate of bad weather so you don't miss much riding
BonnieBlack is offline
post #3 of 21 (permalink) Old 05-01-2013, 06:50 PM
Main Motorcycle: '06 Triumph Bonneville
P-twin's Avatar
Location: West of the east coast & east of the west coast
There are remedies for this but if this bike is THAT brand new, then I would turn around and go straight back to the dealer. It would make me wonder what else on the bike needs attention
P-twin is offline
post #4 of 21 (permalink) Old 05-01-2013, 06:59 PM Thread Starter
What does the fix entail? Is it simply caused by the gaskets not seating properly? Cylinder heads not torqued to the correct amount?
RussAlan is offline
post #5 of 21 (permalink) Old 05-01-2013, 07:02 PM
Main Motorcycle: 2005 Sprint ST
Lordendo's Avatar
Other Motorcycle: 2012 WR250R
On my thruxton they replaced the gasket first and then eventually the whole valve cover. I also had a problem where a plug at the rear of the engine wasn't properly torqued. When I traded it in it was leaking again - probably from the rear, but not sure.....
"He attacked everything in life with a mix of extraordinary genius and naive incompetence, and it was often difficult to tell which was which."
Lordendo is offline
post #6 of 21 (permalink) Old 05-01-2013, 07:03 PM
Main Motorcycle: 08 Thruxton
Wolfpack94's Avatar
Do a search for cam cover leaks and you will get a plethora of info. Historically the issue has been the washers under the shoulder bolts compressing too much. The shoulder bolts only screw in to the shoulder and voila, a very slightly loose cam cover that can weep a wee bit of oil.
Wolfpack94 is offline
post #7 of 21 (permalink) Old 05-01-2013, 07:06 PM
P-twin's Avatar
This is just a guess on my part as I can't actually see the bike but it would not surprise if the dealership used the old style cam cover bolts seals or the cam cover bolts.
Triumph changed out the thickness of the cam cover bolt seals and the bolts because of the weeping issues that these twin were very well known. This solution was a pretty much a sure fire fix to the problem and is why it makes me think that you have a set of the old style bolt seals in there.
Part # T1260309 are the BAD bolt seals that you don't want and will weep on you.
Part # T1260337 are the ones you want that has fixed this problem. My bet is that the dealer had some old stock or whatever reason...but you don't have the right bolt seals sitting in it. It is a 10 minute fix that redefines simple but this bike is WAY too new...the dealer should do it
P-twin is offline
post #8 of 21 (permalink) Old 05-01-2013, 07:11 PM Thread Starter
Why would the dealer have put wrong parts in the bike? The bike is brand new and came directly from the factory. They would have no reason to take anything apart before selling be the bike.
RussAlan is offline
post #9 of 21 (permalink) Old 05-01-2013, 07:15 PM
P-twin's Avatar
It could have come from the line this way as well...mistakes happen but the symptoms you are describing makes me think you have the old style seals in there. This is not something you would know unless you are riding the bike down the road and the weep starts
P-twin is offline
post #10 of 21 (permalink) Old 05-01-2013, 07:20 PM
P-twin's Avatar
Here is something on youtube explaining exactly what we are talking about here. Pretty cool as this is about the only mechanical stuff I have found on the modern Bonnies with youtube but it explains this weeping you are asking about
P-twin is offline
Normal engine noise? Denzil Tiger Workshop (archive) 2 05-09-2011 03:41 PM
engine smoke is this normal? sandslinger17 Speed Triple Forum 8 06-28-2008 12:48 AM
Normal discount on brand new S3? Max_NYC Speed Triple Forum 31 07-20-2007 12:41 PM
Normal engine temp? glw The Rocket Science Forum 3 09-28-2005 09:12 AM
What is a normal engine temp? Sprint Forum 6 05-24-2004 03:28 AM
