scrambler valve tap - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 2 (permalink) Old 02-28-2013, 02:04 AM Thread Starter
Main Motorcycle: 09 Scrambler
scrambler valve tap
Put your hand up if your scrambler valves sound like they are about to implode
Is it me or do the 270 deg sound worse than the 360 because of the offbeat nature meaning two sets of noises instead of one with the 360's??
warnzie is offline
post #2 of 2 (permalink) Old 03-01-2013, 01:31 AM
Askari's Avatar
Noise
Havent spent a lot of time listening to 270, but they are all a bit noisy. 4 valves, ohc etc. If you have stock mufflers then all the bikes do sound noisy.
The 360 has 2 sets of noises as well. 1 piston is 2 strokes behind the other.
All aside depending on the mileage might be worth a check, if in doubt. They have to be quite loose to rattle a lot.
Checking is easy, if you are in to DIY. Shim changing a bit more involved, but you can outsource if you need to.
Askari is offline
adjusting valve clearance drop a valve shim button GRANDPAamerica Air Cooled Twins Technical Talk 25 06-27-2012 10:35 PM
Valve springs and valve spring retainers jfn Air Cooled Twins Technical Talk 9 04-08-2009 09:16 PM
valve/valve guide question GrayMitchell Classic, Vintage & Veteran 4 06-03-2007 01:22 PM
Just checked valve clearances - not waaay off! Any Valve Experts out there? ohiorider Air Cooled Twins Technical Talk 6 07-28-2006 10:37 PM
Camshaft/valve noise from Scrambler? Happnin Air Cooled Twins Talk 3 05-19-2006 01:39 PM
