Strange starting issue - Page 43 - Triumph Forum: Triumph Rat Motorcycle Forums
 16Likes
post #421 of 430 (permalink) Old 01-17-2019, 02:51 PM
Supernova
Forchetto's Avatar
Originally Posted by derblauereiter View Post
In the spot circled in the picture, it appears not to have the metal connectors that all the other fuses in the box have. Anybody know or can check if this is by design or if it's a newly missing piece?
It's just a "holder" for a spare large 30A fuse. There're also two positions for spares for the smaller sort of 10 and 20A, like this:
alsot likes this.
Forchetto is offline
post #422 of 430 (permalink) Old 01-29-2019, 08:38 AM
alsot's Avatar
mr Forchetto do you thinking that is ok
https://www.gearbest.com/car-gadgets...7tEkS-osejLk5A
to connect it with solenoid relay for emergency start?
alsot is offline
post #423 of 430 (permalink) Old 01-29-2019, 11:07 PM
Supernova
Forchetto's Avatar
Link is not working for me. Takes me to gearbest.com, but an empty page.
post #424 of 430 (permalink) Old 01-30-2019, 12:12 AM
Main Motorcycle: 2011 Thruxton
Jayell's Avatar
Other Motorcycle: 2002 Tiger 955i
Extra Motorcycle: Mrs. Jayell's '13 CB500F
Here's a screen shot.
via Tapatalk
Jayell: 2011 Thruxton - The Jewel, 2002 Tiger 955i - The Mule
Mrs. Jayell: 2013 Honda CB500F
Jayell is offline
post #425 of 430 (permalink) Old 01-31-2019, 03:14 AM
alsot's Avatar
alsot is offline
post #426 of 430 (permalink) Old 01-31-2019, 11:19 PM
Supernova
Forchetto's Avatar
That looks like a 50 amp/28 Volt overload circuit breaker with a reset button. I don't think it'll help with anything.
post #427 of 430 (permalink) Old 02-05-2019, 01:19 PM
alsot's Avatar
sorry for delayed answer , i make mistake i need something to close circuit not to brake
alsot is offline
post #428 of 430 (permalink) Old 04-25-2019, 03:16 PM
Main Motorcycle: T100 black (2014)
Replacing lost info
Hi all,
Sorry for reviving an old thread but I came back here looking for the thread to redirect someone else to it only to find the original photos gone (thanks PhotoŁuckit!). Well, I happened to save all of these down for my own mods journal back when I made this mod to my own bike. Hopefully the originator does not mind me reposting his great info with edited text of his explanation of the mod. All pasted below, none of my work, but I confirm that it works 100%.
>>>>SNIP WITH TEXT EDITS<<<<
1 by Andy G, on Flickr
The*clutch*switch*grounds the BLACK/ORANGE, I tapped it to supply ground for the*Starter*Relay. Begin by exposing the BLACK/ORANGE at the ECU. It's located in the 'B' connector, right side of the ECU. Here you can see the wire exposed, it's the fourth pin on the front row:
2 by Andy G, on Flickr
Clip it, here is where you add the diode (any 1A rectifier will do), which prevents stray voltage form the*starter*relay*coil being back-fed into the ECU. Observe polarity, the band goes toward the*starter*relay.
3 by Andy G, on Flickr
You may have by now snaked your new wire run into the*ECU*harness*in preparation for your final connection at the plug. Twist it together with the other side of the BLACK/ORANGE. I used a yellow wire because I had lots of it.
4 by Andy G, on Flickr
5 by Andy G, on Flickr
Close it up, tape the boot back on as you found it. The other end of the wire goes to the*starter*relay, cutting into the YELLOW/BROWN as shown on the diagram.
The result of this mod requires you to pull the clutch in to start AND bypasses the ECU signal to the*starter relay.
>>>END<<<<
Hopefully someone finds this useful. Happy to remove if the owner of the images requests it.
Andy.
Forchetto likes this.
Andy.
SAI, O2s and baffle gone, NH Togas, TTP Breathe, DNA filter, Tune#3, Hagon 2810s, Intiminators, Maund FEK, NH rearsets, LSL Clubman bars, Halcyon 830s, gel seat and cowl, custom sprocket cover, seat QR, D9 panel, EB H4 wiring, USB power
axg20202 is offline
post #429 of 430 (permalink) Old 04-25-2019, 10:19 PM
Supernova
Forchetto's Avatar
Fantastic work, thanks.
post #430 of 430 (permalink) Old 04-26-2019, 03:19 PM
Main Motorcycle: 2012 Bonneville SE
Other Motorcycle: None
Pull the enrichener knob out when you start the b ike. 1 click for a warm start and 2 clicks for a cold start. My 2012 does the same thing. Pull the kjnob out, and it starts. It`s some sort of glitch with the ECU. It doesn`t think there`s enough voltage to start. Pull the enrichener knob out and it fools it and lets it start. This has been well known for years.
blues730 is offline
Strange starting issue Sparti Speed Triple Forum 8 10-23-2008 11:33 AM
Strange Starting Issue TBSstunta Hinckley Classic Triples 6 06-10-2008 01:16 PM
Strange LCD display issue voodoo_chile Speed Triple Forum 6 10-31-2007 06:03 PM
strange starting problem twinrider Tiger Workshop (archive) 4 09-13-2006 10:01 AM
Strange exhaust issue.... markfly Hinckley Classic Triples 7 10-13-2004 01:45 PM
