Igniter, pickup coil or spark plug coil? - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 28 (permalink) Old 05-13-2012, 09:06 AM
Main Motorcycle: 2008 Bonnie Black Special
triumphrat.net Vendor
PieMan's Avatar
Originally Posted by oddsteven View Post
It's not a fueling issue. I did the ARK a year and a half ago and have sussed out the jetting. It has 10-15K miles on it with the current jetting and this just started. It has happened at various throttle opening positions.
Fair enough.
Mike (UK)
https://www.triumphtwinpower.com
PieMan is offline
post #12 of 28 (permalink) Old 05-13-2012, 09:14 AM Thread Starter
Main Motorcycle: 2008 Bonneville Black
oddsteven's Avatar
Originally Posted by PieMan View Post
Fair enough.
Are you The Pieman that reprograms igniters? Once it starts to go bad doesn't it have to be replaced entirely, reprogramming wouldn't work if the thing is dying, correct?
"The possession of power inevitably spoils the free use of reason." Immanuel Kant
That explains why the sportbikers are driving like lunatics . . .
oddsteven is offline
post #13 of 28 (permalink) Old 05-13-2012, 09:23 AM
PieMan's Avatar
You are correct, once they've gone, they've gone. Re-programming doesn't generally bring them back to life.
Mike (UK)
PieMan is offline
post #14 of 28 (permalink) Old 05-13-2012, 10:57 PM Thread Starter
oddsteven's Avatar
One more piece to the puzzle. Today after gassing up I started it, put it in gear and it stopped running - sidestand switch, except the sidestand was up. Put it in neutral and it started, put it in gear and it ran. Could the sidestand switch be the intermittent problem? If it was only for a split second it should be the same symptoms otherwise. Time to try the paperclip trick.
post #15 of 28 (permalink) Old 05-14-2012, 10:21 AM
Legend
Here's an old thread on cleaning the sidestand switch:
https://www.triumphrat.net/blogs/twin...weak-items-37/
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes RC, no snorkel, inlet enlarged, 118/40/NBZT "Thruxton" needles/1 shim/3 turns, Ikon 7610s, Ricor Intiminators, Barnett green springs, Michelin Pilot Activs, D9 gauge panel, tachometer.
Baltobonneville is offline
post #16 of 28 (permalink) Old 05-14-2012, 07:11 PM Thread Starter
oddsteven's Avatar
Thanks for the thread. I found the connector behind the left side cover as advertised. Dern if I can disconnect it to see about bypassing it temporarily to check my theory. It appears that somehow after 62K miles it's fused into a solid piece of plastic. I know I can always just clip the wires and solder them together but I was interested in testing it first to check. Oh well, I did lube the mess out of the switch itself with WD40.
post #17 of 28 (permalink) Old 05-15-2012, 07:12 AM
pz1
Main Motorcycle: 2005 bonnie black
pz1's Avatar
did you check the little black rubber caps on the carburetor, could be sucking air through them if they are old and dried out, i replace mine pretty regular.
2005 bonnie black, 790cc, sleeper exhaust, airbox cutup,unifilter pods , ai removed, green springs, CR carbs, 118 mains, 55 pilot, clip on 2nd notch, progressive suspension front and back, marine corp emblem.
pz1 is offline
post #18 of 28 (permalink) Old 05-15-2012, 10:51 PM Thread Starter
oddsteven's Avatar
No I did not because it's an obvious ignition issue...worth looking at all the same.
I did finally get the sidestand safety switch bypassed. It seemed to work much better without it. I'm not 100% sure that it was the problem as it may have misfired once en route home, but usually it does it 3 or 4 times on the trip. I will check the bypass connection tomorrow morning if I have time before I head to work to make sure that the high tech jumper (aka paper clip) hasn't gotten a little loose.
post #19 of 28 (permalink) Old 05-16-2012, 09:29 AM
Main Motorcycle: Two wheeled
Retro-Racer's Avatar
Other Motorcycle: several
Extra Motorcycle: next one
I don't want to start-up another round of Coilgate, but I do not think the ignitor module is the 'likely' source of your problem.
If you have had your carbs apart at some point (and who hasn't?), there is a possibility that the vacuum piston is not seated properly into the carb body and/or the spring spacer (aka: spider) has one of its legs blocking the bleed orifice at the bottom of the piston. These would cause the engine of misfire. Worth checking.
/M
"With integrity, nothing else matters. Without integrity, nothing else matters."
Retro-Racer is offline
post #20 of 28 (permalink) Old 05-16-2012, 11:32 AM Thread Starter
oddsteven's Avatar
Originally Posted by Retro-Racer View Post
I don't want to start-up around round of Coilgate, but I do not think the ignitor module is the 'likely' source of your problem.
/M
yabbut -I've put something like 10,000 miles on it since I fooled with the carbs, and the problem popped up very recently. It certainly doesn't act like a fueling problem.
Spark Plug, Coil, Plug Wire Questions kawasakis3 Hinckley Classic Triples 4 08-17-2011 06:49 PM
New Ignition Coil, Spark Plug Wires and Iridium Spark Plugs...better performance? brownbomber Air Cooled Twins Talk 15 10-27-2009 03:25 PM
spark plug coil caps dawson Speed Triple Forum 1 04-08-2009 03:39 PM
Wanted- Spark Plug/ Coil Wires Roverdrive T3 Sport / Touring Forum 2 10-03-2007 01:21 PM
Accel coil and spark plug wudstoc Classic, Vintage & Veteran 2 01-31-2005 12:47 PM
