Busted spokes - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 4Likes
post #1 of 67 (permalink) Old 05-09-2012, 10:08 PM Thread Starter
Main Motorcycle: 2012 Phantom BLK Thruxton
Hilts's Avatar
Other Motorcycle: 1966 Norton Atlas
Extra Motorcycle: 1966 Triumph 120 R
Busted spokes
I'm the original owner of a 2002 Bonneville and have suffered three broken spokes on the rear wheel, all of which have resulted in a punctured tire. I've read that this is a common problem with the early models (2001-03, I think), so I had the entire wheel re-laced with new spokes from Buchanan's (for a hefty sum). Today, one of the Buchanan's broke and punctured the tire (I was going 70 km/h in heavy traffic at the time), which wasn't fun.
Does anyone know the cause of these breakages? I can't blame it on the spokes, because both brands broke; nor on the bloke who laced it because they've broke before. Is it the rim? The hub? Anyone else have this problem?
I'm starting to feel unsafe on this thing.
Hilts is offline
post #2 of 67 (permalink) Old 05-10-2012, 04:04 AM
Main Motorcycle: Thruxton
plodalong's Avatar
Other Motorcycle: 08 Bonneville efi
Its the design of the hub/spoke (or maybe the huge power) . the bend in the spoke is a stress point and usally where they break. The later hubs from 2010 have straight spokes and a diffrent design on the hub to allow their fittment, but of course Triumph would never admit there was a problem. Haven't had any break myself but have cable tied the spokes together at the point where each pair of them cross close to the hub which may prevent a punture if they break, or not.
07 thrux,Ram air ark, TPUSA manifolds Predator pros, 40mm Mikuni flatslides, ttp +3 ignitor,yss emulators,hp springs, Bitubo shocks,pingle steering damper,D9 layflat,2" rise clipons,shorai battery,Changes daily.
plodalong is online now
post #3 of 67 (permalink) Old 05-10-2012, 04:31 AM
Main Motorcycle: 2007 Bonnie T100
bonza's Avatar
Other Motorcycle: Jeep Wrangler
there were some good threads regarding this topic a few years back and the outcome was as plodalong states.
also, important to routinely check the tension of spokes so that ALL of them share the load. thats what I do and havent had any break
2007 Tuxedo T100.
Dom Tourers, TTP breathe, DNA filter,baffle gone, 40/140/1 shim 3 turns, TTP igniter tune, Hagon Nitros, Thruxton Bars, Halcyon bar end mirrors, Pingel fuel valve, Monza gas cap, Burton seat, Avon Roadriders
bonza is offline
post #4 of 67 (permalink) Old 05-10-2012, 04:35 AM
Main Motorcycle: Bonnie T 100
Crackon's Avatar
Other Motorcycle: Norton P11
Extra Motorcycle: 1957 Matchless G3C
A rim tape is fitted?
Crackon is offline
post #5 of 67 (permalink) Old 05-10-2012, 09:28 AM Thread Starter
Hilts's Avatar
Thanks for the replies and the advice. Yes, I've fitted rim tape, but that didn't seem to help. Once I replace the spoke and the tire, I'll check for tightness, but I think they're all pretty good...
Anyone fit any other wheels/hubs to alleviate this problem? The new SE aluminum ones are expensive!
Hilts is offline
post #6 of 67 (permalink) Old 05-10-2012, 01:32 PM
Best solution is a used rear wheel that's after the 2007 model year, it's a drop in replacement and has been redesigned with straight pull spokes.
Second best solution is to zip tie your spokes where they cross, this will prevent the broken spoke from swinging around and hitting the caliper. The spoke that seems to break the most is the rear wheel left outer.
joeswamp is offline
post #7 of 67 (permalink) Old 05-10-2012, 06:42 PM Thread Starter
Hilts's Avatar
The other solution is the one I am now seriously considering: selling the Bonnie and buying a Speed Triple.
Four broken spokes and punctured tires is enough for me. A new wheel, when all's said and done, will be about $1,000, which is too much. This is a serious safety issue and Triumph should have initiated a recall imo.
Hilts is offline
post #8 of 67 (permalink) Old 05-10-2012, 08:08 PM
Main Motorcycle: '15 Ducati Hypermotard
'08 T100's Avatar
If you ditch the Bonnie, take a look at the Street Triple "R". I have always admired those bikes immensely, and if I ever got another bike, that would be the one.
'08 T100 is offline
post #9 of 67 (permalink) Old 05-10-2012, 08:43 PM
Main Motorcycle: 01 Triumph Bonneville
Other Motorcycle: 01 HD Night Train
Extra Motorcycle: 87 Honda Super Magna
This is the first I have heard of a Buchanen spoke breaking. I just received a set from them and am currently having my local mechanic lace and true the wheel for me.
My 2001 Bonneville ate three spokes around 20,000 miles. I replaced them with "Triumph" spokes and nipples at about $8.00 each. 29,000 miles later I broke three more spokes not the same ones as before though. None of them punctured the tube. Buchanen had there spoke kit instock...it was $145 with expedited shipping. Thats half the price of Triumph. Give Buchanen a call...maybe they can sell you one spoke.
I had considered doing the later wheel swap, but unfortunately none where available...and I can't have my bike down for more then a few days.
DUCKMAN is offline
post #10 of 67 (permalink) Old 05-10-2012, 11:05 PM
A brand new rear wheel runs about a grand (which is crazy expensive), but a used ones on ebay come up from time to time. If you're patient you should be able to get one for a few hundred bucks. Why not ziptie or wire the spokes together until then?
The real problem with that rear wheel is the hub, not the spokes. When Central Wheel lost the Triumph wheel contract to an overseas firm, an employee from CW spoke to a member of one of the Triumph forums and said they never liked that hub design and recommended that Triumph not use it. If you get a "lemon" hub with too much machining variation, certain spokes seem to fatigue quickly.
IMHO the best wheels for the Bonneville are the aftermarket ones based on Talon hubs. These hubs are machined from billet, employ straight pull spokes, and are significantly lighter than the OEM models. They are expensive, but actually a little cheaper than the OEM models from the dealer.
http://www.bellacorse.com/bcc203-4.htm
joeswamp is offline
Busted off key Fixins13 Speed Triple Forum 5 03-19-2013 10:37 PM
Busted 76K Mark62 T3 Sport / Touring Forum 0 06-17-2011 08:39 PM
Got Busted!! MAR Club Cafe' 9 04-11-2008 01:47 PM
She busted! TucsonBill Tiger Chat 20 10-08-2007 11:44 PM
Busted Cooling Fan miker Speed Triple Forum 3 08-20-2004 03:33 AM
