HELP - Wiring Issue - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 11 (permalink) Old 03-31-2012, 07:01 PM Thread Starter
Main Motorcycle: '01 Bonnie
sethmcalister's Avatar
HELP - Wiring Issue
I started my DIY fender eliminator this morning. Things went really well until it came time for wiring the brake light I picked up from Dime City Cycle. There was no wiring diagram provided with the brake light so I had to attempt to figure it out on my own. There were three wires, black, yellow and red. The old wiring harness I pulled from the stock headlight had black, red and blue.
If I looked at the wiring diagram from my manual correctly, black is the ground, red is the tail light and blue is the brake light. I played around with the wiring form the light to the harness and ended up connecting black to black, red to red and yellow to blue.
I found that with this combination the tail light worked, but when I hit the brake light, the other filament didn't light up - I'm assuming that it should have. I then tried black to black, red to blue and yellow to red and this netted the same result. I ended up with the first method; black to black, red to red and yellow to blue.
I connected everything and taped. When I blew two fuses I realized that the heat shrink wrap that I had used didn't fully protect all the metal so I taped everything separately and then re-wrapped the harness.
I got everything ready for a ride, started the bike up and then found that my tail light wouldn't light up. My brake light worked, but that was it. I pulled the wiring apart again and tried black to black, red to blue and yellow to red to no avail. I pushed the bulbholder out from the DCC light and found that yellow was the ground and black and red were connected to the nodes. I rewired my black from the harness to yellow on the light and tried the other positive combinations and still nothing.
Now i was back at ground zero. I ran and grabbed the old light and connected everything back up the way it was when I cut it, black to black, red to red and blue to blue. Even that didn't give me a tail light - only a brake light. I'll post some pictures, hopefully that will help you guys visualize what I'm seeing.
I don't have a clue what is going on? How does the tail light work and then all of a sudden it doesn't? Is it possible I blew the relay or something? I was thinking the relay was for the brake light though, not the tail light. Any help would be appreciated it.
ID:	47561   Click image for larger version
ID:	47562   Click image for larger version
ID:	47563   Click image for larger version
sethmcalister is offline
post #2 of 11 (permalink) Old 03-31-2012, 08:25 PM
Main Motorcycle: '07 Black
Easy13's Avatar
First, check fuse #10. It's for the taillight and parking light and probably got cooked while you were sorting out the wiring. Once that's good to go, try it again the way you had it when the brake light was working.
"Cognito Ergo Wrenchum"
Easy13 is offline
post #3 of 11 (permalink) Old 03-31-2012, 08:29 PM
Main Motorcycle: 2012 Sherco 2.9 trials
Bron-Yr-Aur's Avatar
Other Motorcycle: KTM 200 XC 2T
Usually better not to just start connecting stuff. Maybe this can help figure it out. Might wanna look close at the filament. Sounds like you might have started out with a faulty bulb?
https://www.triumphrat.net/twins-talk...ail-light.html
Check Forchetto's post
Bron-Yr-Aur Garage
Bron-Yr-Aur is offline
post #4 of 11 (permalink) Old 03-31-2012, 08:45 PM Thread Starter
Thanks for that post. I will double check that tomorrow by placing the wires on the positive terminal. Should I put the ground (of the light) on the negative terminal or the frame? The yellow wire on the light is soldered to the spring on the bulbholder. I'm right in saying that's my ground for the light right?
Sent from my ADR6400L using Motorcycle.com App
post #5 of 11 (permalink) Old 04-01-2012, 07:47 AM
Easy13's Avatar
Yep, that sounds like the ground lead. Connect it to the ground wire on the harness, not the frame. Should be good to go.
Easy13 is offline
post #6 of 11 (permalink) Old 04-01-2012, 08:46 AM Thread Starter
There is no ground connected to the frame. The ground is on the spring if the bulbholder. I tried to take a picture....blurry close up of the yellow wire. It worked fine before so why is it bad now?
Unless you're referring to the common ground somewhere in the harness?
post #7 of 11 (permalink) Old 04-01-2012, 09:09 AM
My bad. I apologise for that link. I read your post wrong and didn't realise that the light had 3 wires. (reading on my phone) Please disregard that and never listen to me again...
But if you're feeling brave I know that in the wiring harness, all of the black wires are grounds, 2 for signals, one for brake
Have you tried finding a schematic for the light on the manufacturer's website? You didn't mention the type of light you have. Post and maybe another member has had the same problem?
Bron-Yr-Aur Garage
post #8 of 11 (permalink) Old 04-03-2012, 11:50 PM
Main Motorcycle: 2007 Bonnie
monks_point's Avatar
I am having the same issue with an after market tail light.
If I come up with a solution before anyone else does, I'll post it here.
monks_point is offline
post #9 of 11 (permalink) Old 04-04-2012, 11:26 AM Thread Starter
Monk,
I have to admit that my issue was.completely stupid. I was looking at my haynes manual and read blinkers and brake light and just assumed that it was my tail light too. Didn't realize that position meant brake light. Popped in a new fuse and was good to go!
post #10 of 11 (permalink) Old 04-08-2012, 09:54 PM
I got mine working. Thanks for all your help.
Sent from my mobile communications device.
Wiring issue 08Bonnie Air Cooled Twins Technical Talk 0 06-24-2010 09:58 PM
Rear brake light switch wiring issue, ABS model b85chevy Thunderbird Twin - Technical Talk 4 12-20-2009 10:54 PM
Poke's wiring issue on a 64 Bonnie chop poke Classic, Vintage & Veteran 4 04-26-2009 11:29 AM
PLEASE HELP...wiring issue!!! BonnieBlack07 Air Cooled Twins Technical Talk 1 11-27-2008 09:47 AM
