The Bonneville Side Stand switch in just 1477 words (!) - Page 6 - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 9Likes
post #51 of 58 (permalink) Old 08-19-2019, 04:00 PM
Main Motorcycle: Triumph Bonneville T100
Gibble's Avatar
Originally Posted by sqeeezu View Post
Any doubts on your sidestand switch; put a temporary short-circuit between the two cables that go to it, (see my post above) for diagnostic purposes only, I'm not suggesting it's a good idea to go around bypassing safety items willy-nilly. That way you'll be able to eliminate the possibility of a faulty switch if your problem clears up.
Ahhhh! That makes sense. Thanks for the great suggestion, Squeezu! I will try that next.
Gibble is offline
post #52 of 58 (permalink) Old 08-20-2019, 01:11 PM
Main Motorcycle: 2012 base bonneville
Other Motorcycle: 2013 victory hammer
speedfoos, i am interested in exactly how you removed + permanently bypassed the switch, i hate those troublesome nannys, thanks in advance for any info on the procedure.
rodhotter is offline
post #53 of 58 (permalink) Old 08-20-2019, 01:25 PM
Gibble's Avatar
Thanks again Forchetto and Squeezu.
I did the bypass and that fixed the issue. So the problem is the kickstand switch. Thanks so much for the help on this.
Longterm solution: would you recommend bypassing the switch longterm? Or put in a new kickstand switch??
NOTE: I already cleaned and lubed the plunger, and that didn't fix it. It only worked after bypassing the switch.
Gibble is offline
post #54 of 58 (permalink) Old 08-20-2019, 11:43 PM Thread Starter
Supernova
Forchetto's Avatar
Personally I'd replace it. Even if you have an iron discipline and fold it before you set off, you will get distracted one day and ride off with it deployed causing nasty surprise at the next LH bend.
sqeeezu likes this.
Forchetto is offline
post #55 of 58 (permalink) Old 08-21-2019, 05:25 AM
Main Motorcycle: 2004 Thruxton
speedfoos's Avatar
Other Motorcycle: 76 Ironhead
Unplugged the kickstand switch at the harness, unbolted the leftside engine cradle/downtube to swing it out, physically removed the switch. Jumpered pins 1 and 3 in the female side of the harness the switch was plugged in to (bent paperclip piece), heatshrinked it up so the paperclip piece wouldn't fall out. Job done.
I'm not much for forgetting things like a kickstand or always pulling in the clutch when I start the bike so I'm not too concerned about it. Plus resale on a 2004 Thruxton with as many major modifications I have done to it won't be affected by a couple missing "safety" features.
BonnieJon likes this.
The Ted Thread
Mods: 16,000 linear feet of pipe wrap. Wetted daily for maximum oxidization. It's like I ride a fiberglass q-tip.
904cc / ZX-6R front end / Misc. Supporting mods
speedfoos is offline
post #56 of 58 (permalink) Old 08-21-2019, 01:05 PM
thanks speedfoos, so thinking i could just cut off the female end + connect the wires from pins 1 + 3 together. would leaving the switch installed but not working as its wires are dead be ok?
post #57 of 58 (permalink) Old 08-21-2019, 04:13 PM
speedfoos's Avatar
It would be just fine, however, a little cumbersome to reverse if you ever change your mind or a future owner wants to reinstall it.
The Ted Thread
post #58 of 58 (permalink) Old 08-22-2019, 01:19 PM
for sure, like when i cut the wiring on my 13 vic hammer like i did on the bonnie to bypass handlebar clutch switch, it limited my rpm but ok on the bonnie. i cut where i could reconnect it + later found out it only works on 07 back, some new nanny in the newer ecu i guess!
98 TBS Side Stand Switch? crowbgood1 Hinckley Classic Triples 11 06-20-2010 03:37 AM
side stand switch trtwotoo Air Cooled Twins Technical Talk 3 02-21-2009 12:43 PM
Side Stand Switch?? HOOPLA Air Cooled Twins Technical Talk 9 06-25-2008 09:26 PM
Side stand switch fix keef Air Cooled Twins Technical Talk 3 03-24-2007 10:44 PM
Side stand switch BillBo Hinckley Classic Triples 2 06-08-2004 04:29 PM
