MAP sensors on EFI Bonneville- Long post - Triumph Forum: Triumph Rat Motorcycle Forums
 34Likes
post #1 of 174 (permalink) Old 08-02-2010, 07:22 AM Thread Starter
Supernova
Forchetto's Avatar
I realise that some of you dislike these long posts and it's probably bad manners or poor netiquette to write them, they're a bit like Fidel Castro's 6 hour speeches, I know, but I like to tell the full and detailed story of any findings. I'd like to apologise to the mods in advance if this is a problem.
The paragraphs in red by the way, are worth remembering for future reference. A couple of surprises there, I've certainly learned something new.
Manifold Absolute Pressure Sensor (MAP sensor), sounds impressive eh?, what is it?
Some EFI systems, like our Speed-density set-up, do not use airflow measurement of the sort provided by air mass sensors (MAF) like on more sophisticated car systems to determine the base pulse of the injectors. Instead, the base pulse is calculated on manifold absolute pressure (MAP) among other sensors and fixed, calculated or estimated fuelling "maps".
The MAP sensor measures changes in the intake manifold pressure that result from changes in engine load and speed. The pressure measured by the MAP sensor is the difference between barometric pressure (outside air) and manifold pressure (vacuum). At closed throttle, the engine produces a low MAP value. A wide-open throttle produces a high value. This high value is produced when the pressure inside the manifold is the same as pressure outside the manifold, and 100 percent of the outside air is being measured. At sea level this is an average of 14.7 psi. This MAP output is the opposite of what is measured on a vacuum gauge. The use of this sensor together with the barometric pressure sensor also allows the ECM to adjust automatically for different altitudes.
The bike's ECM sends a voltage reference signal (+5 volts) to the MAP sensor. As the MAP changes, the electrical resistance of the sensor also changes. The computer can determine the manifold pressure by monitoring the sensor output voltage. A high pressure, low vacuum (high voltage) requires more fuel. A low pressure, high vacuum (low voltage) requires less fuel.
The output of the MAP sensor is fed into the ECU where it is referenced against revs, intake air temperature, barometric pressure and a pre-calculated table that takes into account things like BMEP (brake mean effective pressure), a measure of engine efficiency determined during development. These inputs, plus the fixed estimated table, allow the ECM to calculate the engine's mass intake air flow, enabling it to provide the appropriate fuelling and ignition timing.
The MAP sensor provides information to the ECM which is only used at shallow throttle angles (very small throttle openings, up to 6% and 2-3k rpm) to provide accurate engine load indications to the ECM. This degree of engine load accuracy allows the ECM to make very small adjustments to fuel and ignition which would otherwise not be possible from throttle angle data alone. The throttle angle data is provided by the TPS (throttle position sensor).
Where are they fitted and how are they connected?
We have a pair of them roughly situated three inches on top of the right hand throttle body, they're attached to the chasis and connected to the two intake manifolds by equal length tubes. These tubes are of a rigid PVC type material rather than rubber, to prevent possible collapse by the vacuum acting upon them. The ends that connect to the manifold and sensor ports are flexible rubber and the one for the right cylinder also has a neoprene sleeve over the rigid PVC pipe to protect it from heat and abrasion by the rear cylinder head bracket. More details about these couplings later in this post.
What is it used for on OUR bikes, exactly?
We have a 2 way Manifold Absolute Pressure sensor (that is two MAP Sensors are fitted), these can have three functions:
1. Accurate fuelling during low speed running. More sensitive control at lower engine speeds. By lower engine speeds I mean 2-3000 rpm and up to 6% of throttle opening. After that the engine relies on other fueling maps derived from other sensors like the TPS, crankshaft position sensor, etc.
2. On some bikes (The Rocket III for example) they also act as cam position sensors. Crank sensor is able to sense 2 revs out of 4 stroke cycle. Map sensor differentiates which cylinder is on compression by using vacuum from each throttle body. This allows system to use sequential sparking, over wasted spark. On our Bonnies the ignition is of the wasted spark variety so this feature is not used.
3. Throttle body balancing. The two MAP sensors electrical signals can be read and monitored individually using the factory diagnostic tool or software like DealerTool, Tuneboy or TuneECU. This enables throttle body balancing in a quick, easy and accurate manner without the use of vacuum gauges which would be very difficult to use on our systems. Disconnecting the MAP sensors to connect the vacuum gauges would cause havoc unless a proper set-up using tight-fitting "T" pieces as shown by JohnyC's post Nš5 later on this thread.
These ilustrations pinched from Triumphs training manual show the working range of these sensors:
What problems can a faulty or poorly connected MAP sensor give?:
Anything that interferes with the MAP sensor's ability to monitor the pressure differential may upset the fuel mixture and ignition timing. This includes a problem with the MAP sensor itself, bad electrical grounds or open circuits in the sensor wiring, and/or vacuum leaks in the intake manifold or hose that connects the sensor to the engine.
Typical driveability symptoms that may be MAP sensor related include:
* Surging, snatching and poor low-speed behaviour.
* Rough, uneven idle or, in extreme cases, no idle at all.
* A rich fuel condition, which may cause spark plug fouling and stop the plug/cylinder from firing altogether.
* Detonation or pre-ignition due to too much spark advance and a lean fuel ratio.
* Loss of power and/or fuel economy due to retarded timing and an excessively rich fuel ratio.
A vacuum leak will reduce intake vacuum and cause the MAP sensor to indicate a higher than normal load on the engine. The computer will try to compensate by richening the fuel mixture and retarding timing -- which hurts fuel economy, performance and emissions. In some cases, specially with leaking sensor hoses, the cylinder won't be able to burn the excessively rich mixture, fouling the plug with raw fuel.
This, of course, is the opposite of what would happen if there was a vacuum leak on a carburetted engine. On those it would merely run a little leaner at idle, creating idle instability and stalling and a little off-idle acceleration hesitation or flat spot. An air leak on a MAP sensor vacuum line is a lot more problematic.
Conversely, a restriction in the air intake (such as a dirty and blocked air filter), may produce higher than normal vacuum readings. This would result in a load-low indication from the MAP sensor and a lean fuel condition.
Notice that, once more, this is the opposite of what would happen with carburetted engines, where a blocked air filter would create a rich mixture condition. Very confusing, specially for those that believe that EFI and carburation are essentially the same...
The fitting of big, lumpy hot cams with large valve overlap specs can cause pressure fluctuations in the intake manifold at light load. These fluctuations are known to confuse MAP sensors. You'll find that vacuum drops at low rpm and the engine will run too rich. Not likely to happen with mild road cams though.
BonnieJon and Wishbone_09 like this.
Forchetto is offline
post #2 of 174 (permalink) Old 08-02-2010, 10:56 AM
Main Motorcycle: 2010 Speedmaster
Lonerider60's Avatar
Other Motorcycle: 2008 FZ1
Very informative thread, especially the conditions that will affect EFI and carbureted bikes in opposite ways. When we understand our machines, we can be more informed why it's sometimes difficult for a technician to remedy problems when they occur. In most cases, it's been my experience that the process of elimination will locate a fault in the most effective manner, especially when the fault is intermittent. I am sure that a lot of small shops don't even have all the spare sensors and electronic parts on hand for diagnosing a lot of complex problems and I'm sure the average backyard mechanic can't aford them. I've seen many threads where owner's bikes don't seem to run well at low to mid-throttle riding after doing some pretty extreme modifications. It's a bit esier with this kind of information to see how these mods can cause the electrical mechanics of our EFI ECM's to mis-judge the load/fuel requirements of the engine. Good Job!
Riding for the pure enjoyment of two wheels.
Lonerider60 is offline
post #3 of 174 (permalink) Old 08-02-2010, 11:24 AM
Main Motorcycle: '09 Sprint ST
braindead0's Avatar
This topic deserved a long post, I appreciate the details. Thanks.
'09 Bonny SE, '09 Sprint ST
braindead0 is offline
post #4 of 174 (permalink) Old 08-02-2010, 11:27 AM
Main Motorcycle: my Triumph Speedmaster
Thanks Forchetto! You sure are very resourceful. It's also pretty obvious that you know damn well what you're talking about and that you enjoy to know exactly what's going on and how it's done, etc.
Thanks for sharing these gems of information.
pjvenda is offline
post #5 of 174 (permalink) Old 08-03-2010, 06:43 AM
Main Motorcycle: Triumph
johnyC's Avatar
vac' gauges on efi
Forchetto,
It's possible to attach vacuum gauges for adjusting the throttle butterflies with the little adjusting screw between the throttle bodies. I had to do this after partially stripping the assembly because of a sticky rhs throttle (Scottish winter, road salt) The plastic tubes pull out ok from the top of the rubber connector and I put my tee pieces in between them. You wouldn't normally run the engine with the MAP sensor lines sharing the signal with the gauges, but it's adequate for the short time the bike has to run to adjust the vacuum readings to balance, see pics below:
lhs connection:
rhs connection:
balanced ok, shown running on fast idle at 2,000rpm:
johny. the boy's happy, leave him alone.
johnyC is offline
post #6 of 174 (permalink) Old 08-03-2010, 07:12 AM Thread Starter
Supernova
Forchetto's Avatar
Good post. I have edited the original post to point this out.
post #7 of 174 (permalink) Old 08-03-2010, 12:57 PM
Supernova
DEcosse's Avatar
Good job on the continuing education process Forchetto!
I believe there is progress going on in the TuneECU development for Twins - when it's released you will have the ability to balance the throttles directly off the TuneECU software - there is a screen for that in Tests, where both MAP sensors will be displayed.
This feature works well in the Triples - no need to connect anything mechanical (Tee pieces, tubes, vac gauges etc), just read & match the pressures in digital display.
(My gen has a Sagem ECM however which does not utilize a MAP sensor - so I use a Morgan Carbtune)
HANGOUT likes this.
DEcosse is online now
post #8 of 174 (permalink) Old 08-03-2010, 06:47 PM
Main Motorcycle: 03 T100
mikeinva's Avatar
Map sensors can go bad with age and not be calibrated right.Do they give you a spec for what they should put out at what vac?If so that would be a real good thing to keep a eye on when the bike gets a few years on it.Some ofthe driveably test for cars give you that.You hook a vac pump with a gauge to the map sensor and see what it reads on the ecm.I know you guys think I like to pick on the efi bikes the reason I do is because I spent alot of time doing efi work on cars for a living and have seen them at there worst.Nothing can beat them when there right but they can be hell when the gerlins start up.Time will tell on these systems cars start at about 5 years old.
mikeinva is offline
post #9 of 174 (permalink) Old 08-04-2010, 04:20 AM Thread Starter
Supernova
Forchetto's Avatar
Mike's right. When all those sensors start playing up we're gonna have some fun...
Can't get much out of the EFI manual but I have this chart of voltage readings v pressures on a typical MAP sensor that is likely to be similar to ours. On the bottom right of the image just hidden under the forum watermark it says: IDLE / DECELERATION
HANGOUT and Wishbone_09 like this.
post #10 of 174 (permalink) Old 08-04-2010, 09:31 AM
Hyates's Avatar
Great Stuff!!
Good information here. WOW! This is excellent material.
H.
2010 Speedmaster Black w/ New England White. AI Removed. TTP Breathe, TTP O2 Sensor Kit, TTP Tune 2, DNA Air Filter, Trident Exhaust (toned down w/ Acousta-fil and custom unvented earplugs).
Hyates is offline
1970 Bonneville dead; long post-help please! realoldguy Classic, Vintage & Veteran 21 04-25-2011 10:57 PM
T120 Help........Long post endeavour Classic, Vintage & Veteran 15 02-10-2010 01:26 PM
Long time, no post! Skiandclimb Daytona Deliberations 3 11-26-2007 05:30 PM
Saying Hi and a few questions (long post) TrOjAnUK Air Cooled Twins Technical Talk 9 07-01-2007 05:04 PM
Long ride, Southern Cross Rally (advice please....)>> Long post zaqtronic Air Cooled Twins Talk 0 03-29-2007 06:22 AM
