Engine cuts out - Error code P1698 - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 17 (permalink) Old 04-18-2010, 08:31 PM Thread Starter
Newbie
Hi,
I have a 2009 T100 Bonneville. Tried to carry a passenger tonight and the engine would cut out. Error code was P1698 - Sensor supply Vcc Malfunction. Bike seems to run ok without passenger. Any ideas?
jc_09Bonnie is offline
post #2 of 17 (permalink) Old 04-19-2010, 12:09 AM
Main Motorcycle: Triumph Street Triple.
Other Motorcycle: Aprilia RS125
Is it the extra weight on the seat causing a sensor malfunction?
S.
2010 Street Triple. Black.
"Just because you're breathing, doesn't mean you're alive"
Sp00ky is offline
post #3 of 17 (permalink) Old 04-19-2010, 03:52 AM
Supernova
Forchetto's Avatar
P1698 is a code for "Voltage control circuit malfunction". Sounds like a problem with the rectifier/regulator. If you have a multimeter measure the voltage at the battery with the engine running at a fast idle. Should be over 13 volts but no more than 14.8 or so.
I can't see what difference having a passenger makes, but can could happen is that the ECM supply relay could be slipping out of its socket. This is the small (1"x1") black box under the seat, between the barometric sensor and the tip-over cut-out switch. Its mounted on a floppy rubber mounting and might have slipped off it.
Forchetto is offline
post #4 of 17 (permalink) Old 04-19-2010, 10:13 PM Thread Starter
Newbie
Found problem. Pinched wire under seat was rubbing against frame. Bit of tape and she's all set to go. Thanks all for the tips.
post #5 of 17 (permalink) Old 08-30-2016, 02:56 PM
Hi JC,
I got the same problem with my Bonneville P1698, by reading your post I realized that anytime I got the problem my girlfriend was on the bike.
Could you tell me how did you identify the pinched wire I checked and I could not find anything, so I have taped everything but the light is still on.
Thanks in advance
Luca
Misterpinty is offline
post #6 of 17 (permalink) Old 05-16-2019, 09:29 AM
Main Motorcycle: Speedmater 2009 EFI
Speedy92's Avatar
Originally Posted by Misterpinty View Post
Hi JC,
Thanks in advance
Luca
I have the same problem , but everything was fine until one time while I was riding I swich on and off lights ( short and long distance light ) and bike turned off, then I could not turn it ON again, later I connected it to OBDII cable and see this alarm ( 1698 ) , rectifier is showing good resistance, crankshaft position sensor is also good ( resistance 615 Ohms at 20C ), but only thing that is confusing me is that while the bike is running , battery is showing 12.5 V, when I add throttle and leave it on 3500- 4000 rpm it still stays at 12.6 Volts, not going up or down
Anyways, if you have any ideas what else to check for this stupid alarm, thank you ... ( maybe it has something to do with this swiching headlight long and short beam ,like giving a signal to another bike or a car, I don't know what is a word for this one, sry )
Speedy92 is offline
post #7 of 17 (permalink) Old 05-16-2019, 08:26 PM
Main Motorcycle: 69 Bonneville project
Other Motorcycle: 07 salvage Bonnevilles
Extra Motorcycle: '78 CB750
Charging system.
HayMike is offline
post #8 of 17 (permalink) Old 05-17-2019, 01:12 AM
Speedy92's Avatar
Originally Posted by HayMike View Post
Charging system.
But rectifier/refulator is showing ok when I test it , its shoing 0.610 on miltimeter on all 3 pins, ok I will try it one more time to see if the battery voltage will go up to 14.5 when I rev it 😕
Speedy92 is offline
post #9 of 17 (permalink) Old 05-17-2019, 01:26 AM
Main Motorcycle: 2009 Scrambler
So if the voltage out of regulator is low, have a check for what output the stator is giving, these are the 3 wires supplying the regulator, be careful though as these are a.c., I think at idle they should be around 25,30volts a.c. and as you rev should steadily increase can't remember what they go up to off top of my head but I'm thinking 70vac this should be even across each pair that you measure, there is a thread on here some where that goes through step by step for stator and regulator checks
Ade-955i is offline
post #10 of 17 (permalink) Old 05-17-2019, 07:20 AM
Supernova
Forchetto's Avatar
I think you must mean this definitive one by @DEcosse :
https://www.triumphrat.net/speed-tri...r-upgrade.html
error code? triumphtimes Daytona Deliberations 3 11-05-2008 10:59 PM
s4 error code t8 Justice Strike Triumph SuperSports 0 03-29-2008 05:01 PM
tt600 error code xdvst8x Triumph SuperSports 5 03-16-2007 12:04 PM
Engine error code with tuneboy roadkill Speed Triple Forum 4 02-13-2007 09:36 AM
'02 S3 error code help - P0462 Granitsky Speed Triple Forum 3 10-22-2005 02:32 PM
