Engine cuts out - Error code P1698 - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 17 (permalink) Old 05-17-2019, 09:55 AM
Main Motorcycle: Speedmater 2009 EFI
Speedy92's Avatar
Thank you guys very much, currently I have 2 problems to check
Without any reason , while checking rectifier if its good or bad ( i disconnect it from the stator plug, and check by multimeter) and realise that it is good, also checked all fuses and they look good, I put back everything back in place try to start it, realise that neutral swich is gone bad, so I have to check that one and the stator.
Speedy92 is offline
post #12 of 17 (permalink) Old 05-17-2019, 11:25 AM
Main Motorcycle: 2009 Scrambler
Originally Posted by Forchetto View Post
I think you must mean this definitive one by @DEcosse :
https://www.triumphrat.net/speed-tri...r-upgrade.html
Yes that's the one, very informative
Ade-955i is offline
post #13 of 17 (permalink) Old 05-18-2019, 05:54 AM
Speedy92's Avatar
Ok, neutral switch was disconnected , probably bumpy roads or something , now thats ok, but still the battery remains on same voltage ( i.e. 12.05V ) while engine running on 900rpm or 4000rpm 😕 now I'm going to check stator connection and see what it will show me
Speedy92 is offline
post #14 of 17 (permalink) Old 05-18-2019, 08:06 AM
Speedy92's Avatar
All in all its rectifier...any suggestions on which one to buy or order OEM from triumph site?
Speedy92 is offline
post #15 of 17 (permalink) Old 05-18-2019, 08:23 AM
Speedy92's Avatar
If somebody can please find instructions on how to put rick mosfet r/r , because I would like to put that one..and link on ebay or some other site so I can order it ? Thank you very much in advance!!
Speedy92 is offline
post #16 of 17 (permalink) Old 05-18-2019, 10:58 PM
Supernova
Forchetto's Avatar
The Rick's part number for the Speedmaster would be 10-004H:
https://ricksmotorsportelectrics.com...ulator-10_004H
Instalation should be straight forward, as it fits with the same two bolts and it's provided with a suitable connector that plugs into the existing one.
Order direct from makers or Amazon:
https://www.amazon.com/dp/B004AGMDUA...gateway&sr=8-1
Ebay has them as well, although in the end they all come from the States:
https://www.ebay.com/sch/i.html?_fro...-004H&_sacat=0
Do at least check that the connector that joins the stator to the main loom and it's attached to the thicker of the two cables that exit from the alternator triangular cover is OK. Many have burned or melted and fitting a new regulator will be no good, see the link provided earlier which has among other useful diagnostic tips a photo of a burned connector on post 7:
Forchetto is offline
post #17 of 17 (permalink) Old 05-20-2019, 12:05 PM
Speedy92's Avatar
Thank you very much!
Just ordered one from ebay, as soon as I test it I'll let you know 😄
Speedy92 is offline
error code? triumphtimes Daytona Deliberations 3 11-05-2008 10:59 PM
s4 error code t8 Justice Strike Triumph SuperSports 0 03-29-2008 05:01 PM
tt600 error code xdvst8x Triumph SuperSports 5 03-16-2007 12:04 PM
Engine error code with tuneboy roadkill Speed Triple Forum 4 02-13-2007 09:36 AM
'02 S3 error code help - P0462 Granitsky Speed Triple Forum 3 10-22-2005 02:32 PM
