Crankcase breather relocation, free power! - Page 25 - Triumph Forum: Triumph Rat Motorcycle Forums
 12Likes
post #241 of 246 (permalink) Old 06-02-2019, 03:03 PM Thread Starter
Supernova
Forchetto's Avatar
Originally Posted by TILL_PT View Post
You are a lucky man!! I have no choice in the rain and my closest garage is in Portugal, so I have to think of this kind of things XD
Any idea if the Bonneville has a diaphragm before the hose like other bikes? and if they do is it a common occurrence for it to get clogged? finding hard to explain my all over oil leak when the temperature goes up
The breather went through a major change of design in 2006, I think. The one we have now is of the labyrinth separator type with no valves or moving parts at all.
TILL_PT likes this.
Forchetto is offline
post #242 of 246 (permalink) Old 06-03-2019, 06:21 AM
Main Motorcycle: Triumph Bonneville 2008
TILL_PT's Avatar
Other Motorcycle: Yamaha DT MX 125cc 1980
Extra Motorcycle: Yamaha TDM 850cc 1998
Huummm the plot thickens, something is causing an increase in oil pressure inside my engine. if there are no valves on the breather system since 2006, I should rule out the breather system, but I'll give it a check anyways since I'll be removing it from the airbox
08 Bonnie
+ Tec Sprint Exhausts / TTP EFI Remap Map #6 / Breathe Airbox Intake / DNA Air Filter / NGK Iridium Sparkies
- Air Baffle / Snorkel / O2 Sensors / AI System
TILL_PT is online now
post #243 of 246 (permalink) Old 06-05-2019, 01:35 PM
Main Motorcycle: 2015 Triumph Thruxton
Other Motorcycle: 2016 Triumph Street Twin
Extra Motorcycle: 1978 Bonneville T 140V
Hello All
I did something different on my 2015 Triumph Thruxton. I decided to utilize the Air Injection system to evacuate crankcase pressure. I removed the AI relay and placed a piece of aluminum tubing I turned on my lathe in place. I disconnected the breather connection to the airbox and plugged the airbox opening, I also plugged the connection on the airbox going to the AI system. I used the hose that came to the top of the airbox after I cut it and using pieces of tubing in two places to get the routing I wanted then using a piece of aluminum tubing I turned on the lathe and I connected it to the breather. I had connected a vaccum gauge to the hose and noted 7 psi of vaccum. The system uses two reed valves one connected to each cylinder head exhaust port to create the vaccum. I have been running the bike but not much it only has 5460 miles on it but I have not noticed any ill effects.Here are some pictures.
Juan
[IMG][/IMG]
Forchetto likes this.
Juan is offline
post #244 of 246 (permalink) Old 06-05-2019, 02:44 PM Thread Starter
Supernova
Forchetto's Avatar
Good idea to keep the reed valves there, otherwise the crankcase would have a direct connection to the exhaust ports. Here's a thread with some useful discussion about this method of aiding the breathing:
https://www.triumphrat.net/air-coole...ather-mod.html
post #245 of 246 (permalink) Old 06-05-2019, 02:59 PM
Main Motorcycle: 2008 Triumph Bonneville
Other Motorcycle: 1996 Harley Dyna
Extra Motorcycle: 1973 Triumph Tiger 750
Originally Posted by Slinky View Post
Interesting. Do you suppose that both pistons falling together meet a significant resistance, with the crankcase having to breathe thru a small tube? Same goes for the upward movement I guess, they would be be leaving a partial vacuum behind.
This would presumably rob power too.
Proper and efficient venting of the crankcase is always preferred. However, consider that any energy absorbed in compressing the crankcase air on the downward stroke of the pistons in a 360 degree engine is largely returned to the crank on the upstroke as the air, essentially acting as a "spring", decompresses.
Bob
bobscogin is offline
post #246 of 246 (permalink) Old 06-05-2019, 05:39 PM
Hello Forchetto
I read the posts in the link. I was also a drag racer in the late 70`s and ran a 1971 chevrolet Camaro in the National Hot Rod Association super stock division at the time Moroso racing equipment was selling a crankcase pressure evacuation system which had a couple of anti backfire valves you would weld to the exhaust headers. The valves were connected to the breathers in the valve covers. I did many runs shifting at 8,500 Rpm on my 5.7 liter engine and it never blew a seal or show any sign of leaks that is where I got the idea to use the AI system on my Triumph for crankcase pressure evacuation. The anti backfire valves were just reed valves.
Juan
[IMG][/IMG]
Juan is offline
Crankcase breather mod... Flaco Air Cooled Twins Technical Talk 9 04-21-2009 06:46 AM
Crankcase Breather 2ManyToys T3 Sport / Touring Forum 1 12-01-2007 09:35 PM
T140E Crankcase Breather Relocation Rockfish Classic, Vintage & Veteran 5 08-08-2007 09:48 PM
crankcase breather 6string Hinckley Classic Triples 4 06-22-2006 04:04 PM
Crankcase breather ??? danbike Air Cooled Twins Talk 5 04-15-2006 03:36 PM
