DYI brake fluid replacement/bleeding - Triumph Forum: Triumph Rat Motorcycle Forums
 8Likes
post #1 of 15 (permalink) Old 09-09-2019, 09:00 PM Thread Starter
Main Motorcycle: 2013 Triumph T100
I Bought my 2013 Bonneville a year ago, and got to thinking, has the brake fluid EVER been changed? It was looking pretty amber colored. Front pads needed changing, so I thought, let’s get it done.
New pads in, on to bleeding out the old and in with the new. Bleeding out the front is fairly simple, as you can reach the lever with one hand whilst working the bleed screw.
The rear? With the pedal and reservoir on one side and the caliper on the other, I couldn’t figure how to do it. YouTube to the rescue- Delboy’s Garage showed a clever trick to make this easy for one person to do. Using a 24” slide clamp, ( $7.00 at Harbor Freight) clamp it onto the brake pedal with the slide part extending vertically. You may need to tie back the foot peg. Then simply push forward what is now a lever to put pressure on the pedal, whilst working the rear bleeder! Works perfectly! Fresh brakes feel so good! Thanks Delboy!
See photo
Back2-2 and BonnieJon like this.
Andrevb is offline
post #2 of 15 (permalink) Old 09-10-2019, 02:03 AM
Main Motorcycle: Triumph Scrambler
Kiwi Tiger's Avatar
Well done.
I agree those Delboy's garage videos are great.
BonnieJon likes this.
Illegitimi non carborundum - Sons of arthritis - Ibuprofen Chapter :-)
Kiwi Tiger is offline
post #3 of 15 (permalink) Old 09-10-2019, 12:13 PM
Huh. That's a cool way of doing it! I've always sat on the floor behind the bike, stretching myself out to hold the bleed screw wrench with one hand, while I push on the pedal with the other. Not comfortable.
Lone Commuter of the Apocalypse
2012 Bonneville T100
2013 Honda CB1100
Gone in 60 is online now
post #4 of 15 (permalink) Old 09-10-2019, 01:27 PM
Main Motorcycle: Bonneville T100 SMQ SE
Tornado99's Avatar
Other Motorcycle: 1974 Norton Commando 850
My solution was even simpler/cheaper! I just tied a length of rope to the brake pedal and run it under the bike so I could on pull it (creating a downward pull on the brake pedal) from the left side while messing with the caliper bleed nut.
vitesse likes this.
2013 T100 Steve McQueen; +NH Togas; -SAI; -O2; +Breathe; +TTP#3; +Avon RoadRiders; +Iron&Resin Sidebag; +Kisan Auto-Off Indicators & BrakeLight Flasher; +MatchlessClueless LED Brake & Indicators; +LED 3000 Lumens Headlamp; +DeCosse Keyless system
Tornado99 is offline
post #5 of 15 (permalink) Old 09-10-2019, 01:50 PM
Tornado99's Avatar
Originally Posted by Kiwi Tiger View Post
Well done.
I use to be fan of the Delboy but got banned from his comments section for asking how to deal with ABS brake bleeding due to the need to cycle the solenoids etc. He thought I was sounding "incredibly pious" and blocked me from future postings.
Since then he's really gone off the deep end IMHO with his content and trying to get other channels taken down b/c they criticized him.
Check out:
PapaSmurfMC and Boy Racer like this.
post #6 of 15 (permalink) Old 09-10-2019, 01:56 PM
Main Motorcycle: 2014 Bonneville T100Black
cajunbonnie's Avatar
You all are more talented than I am. I have to say "Hey babe, want to do something fun?". By the time she figures out it's not that much fun, the rear brake is pretty well bled.
Tornado99 and jmassengill like this.
cajunbonnie is offline
post #7 of 15 (permalink) Old 09-10-2019, 05:06 PM
Good move, Cajun, but that trick only works once...
2013 Honda CB1100
post #8 of 15 (permalink) Old 09-10-2019, 07:19 PM
Legend
"Remember when I [cleaned your car, took it for an oil change, hung that painting on the dining room wall] for you? Now I need some help for a few minutes. I'll give you gloves and a seat, and some rags, all you have to do is hold the reservoir and pour fluid into it without spilling it."
She's a good sport about it, and I appreciate it.
I've had enough practice with the front brake that I don't need help with it anymore.
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes RC, no snorkel, inlet enlarged, 118/40/NBZT needles/1 shim/3 turns, Ikon 7610s, Ricor Intiminators, Barnett green clutch springs, Michelin Pilot Activs, D9 gauge panel, tachometer.
Baltobonneville is offline
post #9 of 15 (permalink) Old 09-10-2019, 07:56 PM
Main Motorcycle: 02 Sprint RS
Steve Ford's Avatar
Other Motorcycle: 06 Tiger
Extra Motorcycle: a few others
That's too new tech for me.
I wrap a sock around the brake pedal and use a monster box wrench as a lever.
Steve Ford is offline
post #10 of 15 (permalink) Old 09-10-2019, 08:06 PM
Main Motorcycle: 2014 Triumph Bonnie
Other Motorcycle: 1970 Bonnie
Check out:
https://www.youtube.com/watch?v=TS0Y9YbdL-c
I listen/watched that video for 9 min and couldnt figure out what the hell he was saying!
DougAU is offline
