Stock Handlebars? - Triumph Forum: Triumph Rat Motorcycle Forums
 21Likes
post #1 of 18 (permalink) Unread 08-27-2019, 11:10 PM Thread Starter
Newbie
Stock Handlebars?
I stumbled across this bike on Craigslist recently and the owner insists these are Triumph handlebars, stock from the factory. Has anyone seen this? How hard would it be to swap in something else?
rrmiller is offline
post #2 of 18 (permalink) Unread 08-28-2019, 02:57 AM
Gyp
Main Motorcycle: R1200R Sport
Other Motorcycle: Street Scrambler
Extra Motorcycle: R80RT
Welcome to the forum!
The bike looks lovely and I suspect those bars/riding position would suit me perfectly, however, if you're looking to change bars, it's always easier to go from higher bars (longer cables) to lower bars (shorter cables) as it's far easier to hide excess wire than lengthen it.
In very simple terms it would require bars, shorter brake line, shorter clutch cable (both of which should be easily obtainable either from Triumph or aftermarket) and a couple of hours waving spanners
guitargeek62 and rrmiller like this.
Gyp is offline
post #3 of 18 (permalink) Unread 08-28-2019, 09:16 AM
Main Motorcycle: 2011 Bonnie SE
Loco85's Avatar
Greetings and welcome. This looks like a 2009 or 2010 Bonneville SE. These do not look like the bars that come with this bike, believe the original bars are lower. Swapping the bars it is not hard just look for what you want, size is either 22mm or 7/8". I have a 2011 SE and have tried 2 other bars before the ones I am happy to have now. Only problem with other bars is that they are not drilled for the controls, you need to decide how to deal with this. I got rid of the pins and happy others drill the new bars. Where are you located?
rrmiller likes this.
cali
Loco85 is offline
post #4 of 18 (permalink) Unread 08-28-2019, 07:49 PM Thread Starter
Newbie
It's a 2010 SE, the price is withing striking distance for me but the owner claims it is 100% stock and that it came from the factory with these bars - something I haven't come across in any of my research. I was wondering if this was a factory option or.....?
I'm in Whistler, BC Canada.
rrmiller is offline
post #5 of 18 (permalink) Unread 08-29-2019, 12:12 PM
Main Motorcycle: Triumph Bonneville SE
mick 85's Avatar
They look like these ones ?
https://bellacorse.com/shop/highrise...onversion-kit/
Born to be mild
mick 85 is online now
post #6 of 18 (permalink) Unread 08-29-2019, 12:55 PM
Main Motorcycle: 2017 Triumph T120
Not like my 2015 stock bars. Probably extended cables as well. I knew I guy who did this to his SE. Some like them.
Anyway, getting stock bars should be easy enough here in the classifieds. If you need shorter cables, might have to get them from Triumph.
Mhoffm is offline
post #7 of 18 (permalink) Unread 08-30-2019, 02:55 AM
Main Motorcycle: 2010 Bonneville T100
Ridgy's Avatar
Other Motorcycle: 1975 Norton Commando MK 3
The seller can insist all he likes. They are not stock.
Dogs are the best people.
Ridgy is offline
post #8 of 18 (permalink) Unread 08-30-2019, 08:39 AM
Migs's Avatar
Other Motorcycle: Kawasaki Z900RS SE
I have a 2010 SE. Those look a little higher than the bars that came with mine (though I bought used). Here's the bars I took off mine when I replaced them.
ID:	654008   Click image for larger version
Migs is offline
post #9 of 18 (permalink) Unread 08-30-2019, 08:51 AM
Legend
Main Motorcycle: 2008 Bonneville Black
Driftless Admin
BonnieBlack's Avatar
Other Motorcycle: Spousal 2009 Bonnie Black
Hey I've seen those handlebars before! They are not stock though.
rrmiller and AusSimon like this.
BonnieBlack is offline
post #10 of 18 (permalink) Unread 08-30-2019, 10:50 AM
Main Motorcycle: '03 Bonneville T100
coachconnor's Avatar
Other Motorcycle: 74 Honda 450 long gone
Those look exactly like the western bars I bought from Bella Corse a few years back. For those of us with musclo-skeletal problems they are much easier on the bod.
BonnieBlack and rrmiller like this.
19t, BC Sleepers, 42 pilots, Thrux needles & springs, 135 mains, K&N, Dart screen, air box bafflectomy, Barnett greens, TEC shocks
Wonderous apparitions - provided by magicians. J Fogerty
coachconnor is offline
