Mechanical speedo options? - Triumph Forum: Triumph Rat Motorcycle Forums
 4Likes
post #1 of 12 (permalink) Old 05-12-2019, 04:19 AM Thread Starter
Beardychops's Avatar
Extra Motorcycle: Yes please
Been thinking for a while about swapping the gauges on my 09 T100 for a single unit. Seen loads of cool ones but the are all digital. Anyone know of one that works with the speedo cable? As always, any pics would be good. Thanks all 👍🏻
Beardychops is offline
post #2 of 12 (permalink) Old 05-12-2019, 01:47 PM
Main Motorcycle: Triumph Scrambler
Kiwi Tiger's Avatar
Not sure what is your single unit.?
But the 2007 has the spedo only, cable drive.
Illegitimi non carborundum - Sons of arthritis - Ibuprofen Chapter :-)
Kiwi Tiger is offline
post #3 of 12 (permalink) Old 05-13-2019, 05:38 AM
6t
Main Motorcycle: The one that I am on
6t's Avatar
Other Motorcycle: 2002 Bonneville America
Extra Motorcycle: Honda RC30
The ratio that you need is 2240:60. If you have EFi you will need to get one with the idiot lights in it or gear up separate lights.
2002 T100 Anniversary. Lucifer Orange no more, "Scrambled"
Brakes and suspension, various Scrambler parts, speedo/tach in headlamp .
6t is online now
post #4 of 12 (permalink) Old 05-14-2019, 02:03 AM Thread Starter
Hoping to find something that has speedo and revs all in one? Have seen a few but no idea if they would work?
post #5 of 12 (permalink) Old 05-14-2019, 04:05 AM
Main Motorcycle: 2009 Bonneville
Flash Nick's Avatar
Other Motorcycle: Kawasaki Super Sherpa
This one runs off a signal generator plugged into your speedo cable drive at the wheel. As you can see it has a built in tacho (run a wire from the coil). I am super pleased with it, the quality is superb. Removing the speedo cable allows you to centre the speedo for a better look.
FN.
DaveM, Baltobonneville, 6t and 1 others like this.
Flash Nick is online now
post #6 of 12 (permalink) Old 05-14-2019, 09:38 AM
Main Motorcycle: 09 Bonnie EFI
FN.
Any pictures of the sensor at the wheel?
TheSquid is offline
post #7 of 12 (permalink) Old 05-14-2019, 05:51 PM
Flash Nick's Avatar
Looks just like your speedo cable.
post #8 of 12 (permalink) Old 05-14-2019, 07:51 PM
6t
6t's Avatar
I was looking at those once upon a time for my 2002 T100. They were rather large, maybe 5.5inches diameter, and the tach was for a Harley firing order which wouldn't work (so I was told) with the T100 pulses. Ended up going a different route.
6t is online now
post #9 of 12 (permalink) Old 05-14-2019, 11:03 PM
Flash Nick's Avatar
From what I understand both use wasted spark technology. Each coil on a Harley would therefore fire once per revolution, as does the single coil on a T100. Others may know more.
post #10 of 12 (permalink) Old 05-19-2019, 01:32 AM Thread Starter
Why are these little changes never straight forward? I may ride with the tach covered, see if I actually need it? Then I could just use the original speedo but on its own.
Speedo cable length tjkoko Classic, Vintage & Veteran 20 08-18-2017 10:16 AM
Speedo drive rubbing on hub - what's wrong? mmanasas Classic, Vintage & Veteran 2 05-26-2017 02:21 PM
Mechanical Speedo Conversion Mr*Beaver Air Cooled Twins Technical Talk 10 06-11-2015 03:43 PM
HUGE news - TuneECU now for EFI Twins! DEcosse ECM and FI Tuning - Help, Tips & Tricks 285 11-18-2010 12:10 PM
Broken speedo drive? 95TBird Hinckley Classic Triples 4 11-11-2005 06:19 PM
