NewBonneville low cafe bar vs. Superbars - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 9 (permalink) Old 04-09-2019, 12:34 PM Thread Starter
Main Motorcycle: 2010 Bonnevill T100
StevenAB's Avatar
Question NewBonneville low cafe bar vs. Superbars
Hello All,
For various reasons I need to replace my stock T100 handlebars with something that puts my riding position a little forward and bent over. I had narrowed my choice down to the NewBonneville Low Cafe Bars. However, when I went to order them today I noticed the Superbar. The measurements that are important to me, rise & pullback, are similar:
Low Cafe Bar measurements:
rise: 2.5
pullback: 5
center: 4.75
width: 32.5
Superbars measurments:
Rise: 2"
Pullback: 5"
Center: 6.5"
Width: 29"
Searching through the archives I can't find anything really comparing the two. I did find one post that mentioned that on the Superbars the throttle tube will have an over hang of just under an inch, the solution is to live with it or trim the throttle tube. One other person thought the Superbars were too wide. Well on the face of it the Low Cafe bars are wider, though another poster said they cut them down to match the stock handle bar width at 28.5". I guess with the center width smaller on the Cafe Low bars and the overall bar being wider, that would allow you to trim some off the bar without worrying about mounting your controls.
Does anyone have any experience with the two, either personal or interested observer. I have to say I do like the price of the Superbars, especially after shipping costs and converting U.S. $ to Canadian. I also want as little buyers remorse as possible. As usual, all comments and help are appreciated.
______________________________________________
Steven, Un piloto de motocicletas
2010 Bonneville, TORs, Progressive 440s in back, Ricor Intiminators in front, modified airbox, TTP Breather and Tune #2, AI & O2 Sensors removed.
StevenAB is offline
post #2 of 9 (permalink) Old 04-09-2019, 01:18 PM
Main Motorcycle: 2011 Bonnie SE
Loco85's Avatar
I do not have experience with either. I can tell you that different brands use different measuring points. So your 5" pullback may be different, and remember that if you cut them your pull back is going to change. I changed bars 3 times (feel lucky, others have tried more and still are looking) before finding the ones I liked. Do not remember the models or brands but 2 of them had similar pull back and rise measurements on paper and where actually very different. Hope this help.
cali
Loco85 is online now
post #3 of 9 (permalink) Old 04-09-2019, 06:09 PM Thread Starter
StevenAB's Avatar
Originally Posted by Loco85 View Post
... I can tell you that different brands use different measuring points. So your 5" pullback may be different, and remember that if you cut them your pull back is going to change...
Good points to consider. Thanks.
StevenAB is offline
post #4 of 9 (permalink) Old 04-09-2019, 07:23 PM
Main Motorcycle: 08 Bonneville T100 C/S
wenzel850's Avatar
I've been using NB Superbars since 2005. I didn't like the height of the stockers, so I tried NB Superbars. Had them on 2 different T100's.
I also wanted a lower bar to get my head and torso lower into the wind. The Superbars do this very well for me.
I'm 5'9" just for a point of reference. Shock length and seat heights are all stock.
Ride safe,
Quentin
wenzel850 is offline
post #5 of 9 (permalink) Old 04-10-2019, 12:19 PM Thread Starter
StevenAB's Avatar
Hi Wenzel, did you have problems with re-attaching the throttle like I read in a post?
StevenAB is offline
post #6 of 9 (permalink) Old 04-10-2019, 12:38 PM
wenzel850's Avatar
No I didn't. All I did was spray the handle bars with Windex and slid the throttle on. The Windex will act as a lube and then dry and act like a glue to keep your throttle on the bars.
Ride safe,
Quentin
post #7 of 9 (permalink) Old 04-10-2019, 03:07 PM Thread Starter
StevenAB's Avatar
I should have been clearer from the start. Here is the link, https://www.triumphrat.net/air-coole...t-reviews.html and this is what was said, "...getting your throttle tube to fit and function properly on the Superbar is an entirely different story. I have tried every conceivable angle and it simply will not work. Either you have a little under an inch of overhang or the throttle sticks. I have now read that some people put up with the overhang, or even cut down their throttle tubes. I think its silly to have to do that."
Did you encounter this?
StevenAB is offline
post #8 of 9 (permalink) Old 04-10-2019, 07:16 PM
wenzel850's Avatar
Not that I remember.
Ride safe,
Quentin
post #9 of 9 (permalink) Old 04-14-2019, 11:06 AM
Main Motorcycle: 16 ThruxR
Adamantium's Avatar
Other Motorcycle: 72 CB450
Extra Motorcycle: 07 FXDB
Renthal low, or ultralow bar. Renthal's website has all the measurements to compare.
------------------fight the good fight-----------------------
16 THRUXTON R -72 CB450-09 Mag-72 CB350
13 Thruxton-08 FXDB-11 XL1200N
12 Daytona 675-1975 CB360-80s KnightRider BigWheel
Adamantium is offline
Sissy Bar - High or Low? batcycle Air Cooled Twins Talk 14 07-04-2019 01:41 PM
Problem..Triumph bar end/mirror into Renthal bars. Help! SKANK Speed Triple Forum 3 12-30-2008 02:09 PM
low cafe bar ends? Murphy Air Cooled Twins Technical Talk 11 11-06-2007 09:29 AM
Low cafe bars w/bar-end mirrors: too wide? Nathan Air Cooled Twins Technical Talk 8 07-11-2006 10:55 AM
