Tire recommandation for T100 with sidecar? - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
  • 1 Post By Unkle Krusty
post #1 of 5 (permalink) Old 04-04-2019, 01:13 PM Thread Starter
Main Motorcycle: BMW R1100RT
Other Motorcycle: Triumph bonneville T100
Living up north I decided to acquire a sidecar to extend the riding season. I got a nice velorex sidecar now attach to my 2002 centennial bonneville t100, and i’m looking for tire suggestions for the motorcycle.
I know some put block tire on them for better durability, but since I will still use the motorcycle for solo ride quite often this is not a possibility for me. So I’m looking for the most durable tire possible wich mean a dual compound with Harder center part. Someone suggested to buy the cheapest russian or chineese tire, since sidecar wear the tire pretty fast and the compound is harder, and should last longer, but i’m not sure i want to go this way. Any idea?
Thanks for your help!
Rob
Umilik is offline
post #2 of 5 (permalink) Old 04-04-2019, 01:43 PM
Main Motorcycle: TT900
Unkle Krusty's Avatar
Other Motorcycle: SV1000, XS11, XS400.
Extra Motorcycle: XS1100 Trail90
I have a side car attached to my 79 XS1100. I use regular Dunlop tyres for normal riding. I ride Yami without the car often enough. I had read about using more rugged tread tyres, something like the old Trials Universal. I put one on the front, and did not notice much difference. For a bit of snow, the more heavily treaded tyres would be better, as the street tyres have zero traction. I decided regular tyres would work better at 130 kph with the car attached, and for solo riding. I also set the toe in for 130 k.
UK
Unkle Krusty is offline
post #3 of 5 (permalink) Old 04-05-2019, 11:48 AM
Main Motorcycle: '03 Triumph Bonneville
Originally Posted by Umilik View Post
Living up north I decided to acquire a sidecar to extend the riding season. I got a nice velorex sidecar now attach to my 2002 centennial bonneville t100, and iím looking for tire suggestions for the motorcycle.
I know some put block tire on them for better durability, but since I will still use the motorcycle for solo ride quite often this is not a possibility for me. So Iím looking for the most durable tire possible wich mean a dual compound with Harder center part. Someone suggested to buy the cheapest russian or chineese tire, since sidecar wear the tire pretty fast and the compound is harder, and should last longer, but iím not sure i want to go this way. Any idea?
Rob
I used to have a Motorvation Engineering Spyder sidecar that I did the same as you want to... ride in both two and three wheeled modes...
One tip I'll give you... the stresses put on the front tire with the hack on, are totally different than when in the two wheel mode.
If you are going back and forth between two and three wheel modes, you need find a tire "tough enough" to handle the three wheel mode and still be compliant and supple enough to have the feel that you want in two wheel mode.
My preferred combo was a Michelin Pilot Activ rear and their Commander II tire on the front. If Michelin made the Com II in a size that worked on the rear, I would have gone that route. But they don't... and any way, The Pilot Activ is a great tire on its' own. The Com II is a touring tire that is built with higher loads in mind and has a tougher carcass. LOVED it whether riding two or three wheeled. No handling or grip "penalty" in two wheel mode when compared to other sport touring class tires. Great tire and I regularly got 22k to 25k miles out of it. 7k to 9k miles out of a Pilot Activ rear was my normal...
Metzeler ME888's are also a good option. I used to run the then ME880's on my Bonnie, in both modes, and they worked fine... Why did I switch? Metzeler went a bit crazy with their pricing... I tried the Michelin's... and liked them better...got more mileage out of them and saved money to boot!
One combo that I tried that didn't work out was the Continental or Conti Go! line... good tire in two wheeled mode... but a 600 mile three wheeled weekend just ruined the front tire's handling... never felt the same...
I hope that the info helps... and have fun!! Sidecars are a hoot... and if you've never ridden a rig... you're in for an "interesting" experience... As a fellow that was in the sidecar business once told me... "how do you ruin a perfectly good motorcycle?? Put a sidecar on it!" That's a bit cheeky... but there is a lot of truth to it... Totally different ride.. totally different inputs needed... totally different feedback/responses from the rig... If you don't have someone to coach you... find a LARGE open area and practice.
I will give you one other tip... if you ever find yourself in a tank slapper with the hack on... Don't... I repeat... DO NOT hit the brakes!! Go counter intuitive and hit the gas... UNLOAD the front tire/wheel by accelerating, even if just for a second... regain control, recover and then do whatever your next move is... ask me how I know... =;-)
SCbonneville is offline
post #4 of 5 (permalink) Old 04-05-2019, 03:30 PM
Main Motorcycle: 2014 Bonneville
Mike K.'s Avatar
Other Motorcycle: 2007 Ural Patrol
Extra Motorcycle: 2008 KLR 650
I've been thinking about putting the sidecar from my Ural onto my Bonnie too. Many motorbike tires are made with 4 plies of fabric, but a few have 6 plies so they would be more appropriate for sidecar use. On my Ural, I found Shinko 705 gave good service, but my favourite tires from www.cokertire.com for a Model A Ford. Car tires are the best for use with a sidecar because the sidewall and tread are much thicker so hold up much better over time and improve tracking.
Mike K. is offline
post #5 of 5 (permalink) Old 04-06-2019, 02:04 PM
Thank you for the info. I will consider this when Yami stays with Inder full time. The tyres from Yami can go on the Midnight Special when I get it running. These are Yamaha XS1100 bikes, 79 and 80. Inder is a made in India sidecar. Had some terrible machine work on the swing arm and axle.
My Triumph is a 96 Trophy 900.
UK
Mike K. likes this.
How To Properly Check Your Motorcycleís Tire Pressure Motorcycle.com News Room - Homepage 6 03-05-2016 02:45 PM
Why You Should Consider A Sportier Front Tire On Your Motorcycle El Fenix Biker Hang-Out 21 01-12-2016 07:23 PM
Tires? enoch2012 Air Cooled Twins Talk 72 03-31-2009 11:51 PM
Dark Side pawpawfrank The Rocket Science Forum 17 11-09-2007 07:53 PM
Amazing the differences in recommended tire pressures ohiorider Air Cooled Twins Technical Talk 1 10-22-2007 08:09 PM
