Time to replace chain/sprockets, help requested! - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
 10Likes
post #21 of 32 (permalink) Old 02-24-2019, 08:49 AM
Main Motorcycle: 2007 T100
Other Motorcycle: 06 Scrambler, 01 Bonnie
I have 25,000 miles on the original chains and sprockets on an 06' scrambler and they still look good. I am getting ready to change the tires and thought I would replace them but think I could easily get 5,000 more miles from them so will leave them fitted.
menzies is online now
post #22 of 32 (permalink) Old 02-24-2019, 08:45 PM
Main Motorcycle: 2005 T100
Sal Paradise's Avatar
Other Motorcycle: 1974 Yamaha YZ
Riding around NYC you will hate the 19T front.
I hate it and I'm 60 miles north of you. Makes for slow take off.
Go with the stock 18T front - Triumph knew what they were doing when they built the bike.
BonnieJon likes this.
Sal Paradise
Sal Paradise is offline
post #23 of 32 (permalink) Old 02-25-2019, 05:58 PM
Main Motorcycle: 2015 Triumph Thruxton
yrunvs's Avatar
To each their own. I love my 19t but then again I know how to synch the clutch and throttle for quick take offs.
TTP Tune#3, NH Toga's.
I'm no Gynecologist but hey I'll take a look.
yrunvs is offline
post #24 of 32 (permalink) Old 02-25-2019, 06:31 PM
Legend
Main Motorcycle: 2008 Bonneville Black
Driftless Admin
BonnieBlack's Avatar
Other Motorcycle: Spousal 2009 Bonnie Black
The 18T is already a "step up". It was a 17T with the 790 motors pre-2007. When they went to the 865 they stepped up that sprocket to handle all those extra HP.
IIRC.
BonnieBlack is offline
post #25 of 32 (permalink) Old 02-25-2019, 07:59 PM
Pylot7's Avatar
The motor is a buzzy little devil and if you look at the torque/hp curve they are both pretty linear and close to parallel.
If you increase the front sprocket to lower rpms you are lugging the motor a bit. Probably not enough to hurt much but the Triumph motors are not famous for low end torque.
I just use better ear plugs and forget about the buzzy motor.
But while we are on the topic, do aftermarket sprockets come with a rubber damper built in or are they solid metal?? Reason I am asking is the Triumph engineers put that damper in there to protect the output shaft from excessive banging from an undampened sprocket. At least I assume that.
For those of you with an aftermarket undampened front sprocket can you feel the difference? Anyone out there with a lot of miles on an undampened front sprocket?
Also, I have not taken mine apart yet but is the rear sprocket mounted in dampers too?
Pylot7 is offline
post #26 of 32 (permalink) Old 02-25-2019, 08:20 PM
yrunvs's Avatar
The aftermarket front sprockets do not come with the rubber damper. I believe the rubber damper is for sound dampening. I have run a 19t for years I can feel no difference. It is such a pleasure to cruise 70mph and not be wishing for another gear. With proper throttle clutch control there is no lugging.
yrunvs is offline
post #27 of 32 (permalink) Old 02-25-2019, 10:19 PM
Main Motorcycle: 2011 Thruxton
Jayell's Avatar
Other Motorcycle: 2002 Tiger 955i
Extra Motorcycle: Mrs. Jayell's '13 CB500F
Originally Posted by Pylot7 View Post
...is the rear sprocket mounted in dampers too?
No.
Edit: Wait a second... are you referring to the cush drive?
via Tapatalk
Jayell: 2011 Thruxton - The Jewel, 2002 Tiger 955i - The Mule
Mrs. Jayell: 2013 Honda CB500F
Jayell is online now
post #28 of 32 (permalink) Old 02-28-2019, 02:33 AM
Main Motorcycle: '12 Bonneville T100
Just to add my 2 cents . . . Yes, it's 36mm on the sprocket & yes, you'll need at least an 18" breaker bar & yes, keeping chain attached while mashing on the rear brake is an excellent tip.
I got 25k miles out of my chain and could have gotten more, but was coming on a long road trip, better safe than sorry.
Went with the 19t front sprocket. Haven't noticed any appreciable loss of zip, but the speedometer now reads true. Didn't replace the rear sprocket b/c unlike the front sprocket, there was no appreciable wear on it. Looked brand new. Makes sense to me. The rear sprocket makes approximately 1 revolution to 4 for the front one. Ergo, the front sprocket should wear out 4 times as fast!
Big proponent of regular chain maintenance. I use the DuPont teflon lube about every 350-400 miles. Doesn't sling dingle berries all over the bike & the chain & sprockets do great.
HTH
Back2-2 likes this.
When you get where you're going, there you are!
gunny_hiway is offline
post #29 of 32 (permalink) Old 02-28-2019, 11:11 AM
Legend
Driftless Admin
These are good tips. I bought an electric impact wrench for the job and now I'm glad I have it in the garage. It was a good investment, use it quite a bit. Makes removing this, and the nut holding the clutch basket, a breeze
post #30 of 32 (permalink) Old 03-01-2019, 06:26 PM
Main Motorcycle: Triumph Bonneville T120
nhwstormin's Avatar
Other Motorcycle: BMW R 1200 R
Extra Motorcycle: Street Triple R
Tim:
I had a 2012 T-100 and never changed the sprockets and chain and the dealer did the 24K service and the chain was fine. I traded the bike in a few thousand miles later on a T-120 but that's another story.
The one major mod I did was after the first year I replaced the OEM shocks and springs with Hagon shocks and Progressive springs. It was like a new bike with a real suspension. If it were me, that's where I'd put your money. Otherwise, I agree with most of the prior posts.
nhwstormin is offline
Coils and when to replace all or just one TrevorThrift Hinckley Classic Triples 4 04-08-2014 03:11 PM
955i Overhaul Time gonzojournalist Speed Triple Forum 14 02-11-2012 12:29 PM
*BOSTON*Looking for someone to help with some maintenance. Will pay for time NickBoston Maintenance & Workshop Talk 2 08-22-2011 10:53 AM
Time for chain/sprockets.. parts listed for other models that bolt up? 520 conv? Travster Hinckley Classic Triples 5 05-16-2010 01:07 AM
Chain/Sprockets one more time Maintenance & Workshop Talk 6 04-22-2005 12:03 AM
