Indicator frustration - Triumph Forum: Triumph Rat Motorcycle Forums
 4Likes
  • 1 Post By Forchetto
  • 2 Post By Ripper
  • 1 Post By Dan_
post #1 of 8 (permalink) Old 02-17-2019, 11:28 AM Thread Starter
Main Motorcycle: 2009 custom Bonneville
Dan_'s Avatar
Just wondering if anyone can advise or diagnose my indicator issue before I start taking my bike apart.
The issue
Right indicator flashes quickly at higher rpm but fine whilst idling and lowish rpm.
So Ive got the Motone bullet indicators and the Motone plug and play wiring kit and it was all working fine for the first few months however recently Ive noticed the aforementioned issue.
Could this simply be a loose connection or are we potentially looking at some sort of electrical issue with on of the components? I understand it could one of many things so Im not looking for a definitive answer but any help/guidance is very much appreciated.
Cheers,
Dan
Current bike Triumph Bonneville (2009), TEC 2-1, O2 Delete, SAI Delete, TTP Tune.
Favorite riding routes, anywhere in the Peak District.
Dan_ is offline
post #2 of 8 (permalink) Old 02-17-2019, 12:23 PM Thread Starter
Dan_'s Avatar
This should probably be in the air cooler twin technical talk section. Apologies.
Dan_ is offline
post #3 of 8 (permalink) Old 02-17-2019, 02:36 PM
Supernova
Forchetto's Avatar
There's a member (also in Staffordshire, funnily enough) that's an authority on stuff like indicators, etc.
With a bit of luck we should be able to summon him like a genie by doing this: @Ripper
He'll get a notification when he goes online next.
LapinAgile likes this.
Forchetto is offline
post #4 of 8 (permalink) Old 02-17-2019, 08:20 PM
Main Motorcycle: 09 Bonnie EFI
This may sound odd but check your fuses. I had a semi-blown fuse cause this exact same issue. The fuse was blown just enough to mess with the current on my blinkers.
TheSquid is offline
post #5 of 8 (permalink) Old 02-18-2019, 05:54 AM Thread Starter
Dan_'s Avatar
Thanks for the quick responses. I'll have a look at the fuses this week.
Dan_ is offline
post #6 of 8 (permalink) Old 02-23-2019, 07:38 AM
Ripper's Avatar
The issue
Cheers,
Dan
My money is on the flasher relay, its the middle one under the left side panel. Just unplug it and replace it. The relay you want is the CF13GL-02 (available from fleabay). It is not load dependent so should fix the fast flashing problem. You can download my PDF on flasher systems which may be of help in describing why you are having this problem.
Forchetto and Back2-2 like this.
Arrow 2-2, Snorkel/Baffle removed, DNA filter, TTP Tune#3, TEC piggy back gas shocks, 5.5" risers with drag bars, LED Lighting, Hazards, Oberon Footpegs, Burton Seat, D9 bracketry, Hands Free Keyless ignition.
Ripper is offline
post #7 of 8 (permalink) Old 02-24-2019, 03:26 AM Thread Starter
Dan_'s Avatar
The issue
Right indicator flashes quickly at higher rpm but fine whilst idling and low’ish rpm.
So I’ve got the Motone bullet indicators and the Motone plug and play wiring kit and it was all working fine for the first few months however recently I’ve noticed the aforementioned issue.
Could this simply be a loose connection or are we potentially looking at some sort of electrical issue with on of the components? I understand it could one of many things so I’m not looking for a definitive answer but any help/guidance is very much appreciated.
Cheers,
Dan
I’ve found this issue guys, it’s the internal wiring of front right bullet indicator. One of wires seems to have snapped but it’s still touching slightly which is why there isn’t a problem whilst idling. The vibrations from higher rpm is obviously breaking that connection. I’ll get in touch with Motone as they’re only 7 months old. Hopefully they’ll sort something for me.
Thanks again for the suggestions.
Back2-2 likes this.
Dan_ is offline
post #8 of 8 (permalink) Old 02-24-2019, 05:48 AM
That's no good. At least you were able to find the issue. Hopefully they'll take care of you.
TheSquid is offline
